Old 03-14-2017, 01:38 PM   #183
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Originally Posted by Vintage View Post
I would kill for a new ZL1 1LE. $75k???
I debated that too...but I wanna do a G-Body drag car build instead. So the SS 1LE will be staying with me for awhile...
Old 03-14-2017, 01:47 PM   #184
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
thanks for keeping us updated. I know the wait sucks :/
like others mentioned it's good that GM stands behind their cars even for track use so hopefully it will all be left behind.. there's always a margin of error and it seems like that error happened to your car . I have a track event coming up this weekend, fingers crossed
glamcem is offline   Reply With Quote
Old 03-14-2017, 04:10 PM   #185
DFW1LE
DFW1LE's Avatar
I am so ready for my track warranty to kick in with a new engine so I can start kicking it on tracks all over the place. I really want to go to Barber and New Orleans.
So will you need another 1500 miles of <4000 rpm to consider the new engine broken in or is some of that more for other parts of the drivetrain.
Old 03-14-2017, 04:39 PM   #186
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
500 miles per page 10 in link below
https://www.chevrolet.com/content/da...2019328729.pdf
Old 03-14-2017, 05:14 PM   #187
VelvetHammer
VelvetHammer's Avatar
Drives: 2016 Hyper Blue 2SS, A8, NPP
Originally Posted by Eric SS View Post
I think the point is that this is when the engine is under the most stress (going from load to no load while still in gear) and if something is going to break, this is likely the time it will happen. Not that it will happen every time.
Exactly my point Eric SS. The load/no-load situation is when the engine is under the MOST stress. If there is a defective part in the engine from the beginning (and I think we can all agree now that there was) this is the type of situation where the failure will occur. Going from nearly WOT to part throttle/no throttle in and of itself does not cause engine failure and I never meant to imply that it did, only that certain areas of the performance envelope will expose a defective part (in Vintages case, a bad piston).
Current stable:
2016 Hyper Blue 2SS
2001 Pewter Z28
Gone but not forgotten:
1978 Dark Blue-Green Z28 w/1970 LT1 power
1978 Bright Blue Z28
1976 Light Blue RS
1973 Green-Gold LT
VelvetHammer is offline   Reply With Quote
Old 03-14-2017, 09:12 PM   #188
Gville1LE
Drives: 2006 Lexus IS350
Really wished they had told you specifics about what about the piston actually failed. Ringlands/wrist pin or C-clip/broken skirt/etc or possibly a dropped valve. I've seen pics of various LT1 damages and am slightly concerned about the motor's component QC and quality.
What are the factory pistons made up of...are they hypereutectic pistons? I read sodium-filled and nitrated valves are present, both having their advantages and disadvantages.
Wish you luck on the continuing saga; but in the end, I'm sure they'll come through with that new motor.
Gville1LE is offline   Reply With Quote
Old 03-14-2017, 09:37 PM   #189
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
Originally Posted by Glen e View Post
I would bring the general manager and service manager in on any conversations you're having. Too many times the service advisor is really not on top of the situation. I would go have a straight face to face with the general manager to get a status update. A $15-22K warranty claim is certainly on your general manager's radar already.
I swear the service managers arethe biggest useless idiots at a dealership.... I've been emailing mine about my LPO items and getting my whheels and tires swapped since my car comes in next week.... he's NEVER answered an email to the point I asked the sakes manager ( whom I used to order the car) to speak to him
aa406079 is offline   Reply With Quote
Old 03-15-2017, 09:35 AM   #190
TrackClub
TrackClub's Avatar
Originally Posted by Ryephile View Post
Exactly. I'm not sure I'm buying this "no load and BANG" theory.
The BMEP of this engine at peak torque is about 188 PSI, which is very low compared to most current turbo engines, which are upwards of 432 PSI in the M-B AMG CLA45. That's 2.3 times the cylinder pressure. If the load delta was the culprit, then those engines would be throwing pistons every time they lifted from WOT.
Two engine failures in an entire career, I'm sorry but that's not even enough data to correlate anecdotal evidence. It's an interesting theory but I'd need to see some repeatable data to give it a serious look.
+1! No motor is infallible, well, perhaps for LS6
The key here is the cause. Was it something as "simple" as a valve spring (as was a case with 02 LS6), or was it an internal component? Was it related to manufacturing, or assembly process? Etc. Vintage, if yours is indeed the first failure: have patience as GM has to figure it out and that takes time. BUT, they should be treating ya with golden gloves regarding client satisfaction. NB when that guy's GT350 erupted in flames while ON TRACK, Ford (apparently) replaced it with a new GT350R. Not a bad outcome....
Old 03-15-2017, 09:51 AM   #191
COmaro
Drives: Many
Ford has been very good about fixing Boss 302s and GT350s as long as they are not heavily modified. This crap about a catch can voiding the 1LE warranty...WTF? If you look at the Boss 302 forums, the Boss RoadRunner 5.0 is very reliable, but a few have blown. Ford worked with people who even had headers, CAI, etc. They did push back on a lot of regular Coyote 5.0s in GTs, but the Boss was built for the track, so track blow ups were covered. I would hope GM takes the same attitude toward the 1LE.
COmaro is offline   Reply With Quote
Old 03-15-2017, 10:05 AM   #192
Vintage
Drives: 2017 SS 1LE
It has been confirmed to me that my 1LE LT1 failure is in fact the 1st. This stuff happens - just want my car back in one piece to TRACK it often. Now, if I can just resist the ZL1 1LE . . . If a new Z28 comes out - I am buying one.
Vintage is offline   Reply With Quote
Old 03-15-2017, 10:45 AM   #193
Yendor
Yendor's Avatar
Drives: 2017 Camaro 1SS 1LE Hyper Blue
Good and bad. Good that it is a rare occurrence, bad that it had to happen at all. Hopefully things pick up from here on out and you can break in the new engine.
Yendor is offline   Reply With Quote
Old 03-15-2017, 11:19 AM   #194
Sleeks
Drives: None
Nothing special about the LT1 in the 1LE vs a regular SS, and some have let go in the regular SS before you.
-Brian
Hyper Blue 1SS / 1LE
Sleeks is offline   Reply With Quote
Old 03-15-2017, 11:24 AM   #195
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
That's a poor comparison IMHO. The Boss 302 is a totally different engine than the standard GT 5.0. The 1LE engine is 100% exactly the same as the SS engine so they are covering them the exact same way, which is to say better than Ford is covering their mass produced GT.
Eric SS is offline   Reply With Quote
Old 03-16-2017, 12:17 PM   #196
Vintage
Drives: 2017 SS 1LE
Received the call at 11:15 this morning - Chevy has approved the warranty claim and all new parts are shipping this week, which includes a new motor. Thank you Big Al and Chevrolet. I will be a life ambassador at the track!
I am told it will be about 2 weeks from today before I have the 1LE back depending on when all parts are received. We shall see but at least things are starting to happen now. I am very grateful for this car, Chevrolet, and the track warranty!
I did ask again what specifically failed - he does not know other than some part failure related to piston #3. Maybe GM will figure it out when they get the motor back?
