12-28-2016, 10:10 AM | #183 | |
Moderator.ca
Changing the gearing does not change the maximum speed the engine rotates at, just how fast its turning when you're driving a particular speed. And making more power does not make the engine spin faster either. It can make the car go faster in its top gear, but the maximum possible speed of the engine will not be changed if all you do is add more power. Think flooring it while in neutral. Without getting too deep into the physics of it all, the maximum speed an engine an turn at is closely related to the strength & weight of its internal components*. The stronger they are, and the lighter they are, the faster it can spin without destroying itself. Regular V8s have large counterweights on the crankshaft which allow it to run very smoothly, but make it more difficult to spin fast. Crossplane V8s do not have these and so they free to spin a lot faster. *yes, yes ... there is a lot more to it than that. But without delving into the sources and effects of inertia and vibrations for V8 engines and the ways they're managed, the simple answer is 'strength & weight' because those are the two most important contributors
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
12-28-2016, 03:56 PM | #184 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
This is what I was saying since the beginning of the year.
LT5, DOHC, 90s ZR1.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
12-29-2016, 03:20 PM | #185 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
But gearing can affect how fast an engine spins. Which engine will spin faster to 5000 RPM, the one that is geared with 4.10's, or the ones with 2.73's? "Faster" can mean different things.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
12-29-2016, 03:55 PM | #186 |
Drives: 1999 Corvette C5 Join Date: Oct 2013
You can work magic with transmission ratios and number of gears.
12-29-2016, 11:01 PM | #187 | |
Moderator.ca
Getting to a particular engine speed in a certain amount of time is an acceleration measured in something like RPM/second. As soon as you talk about speed over time (instead of revolutions over time), you're now talking about acceleration. In essence, the speed of speed or the fastness of fastness. But to use the word faster in this context, you need to specify. As you just did. To say that faster has different meanings is like saying hockey has different meanings, because there is hockey, field hockey, and street hockey. No ... hockey is a team game where you try and put a round piece of rubber into a goal by whacking it with a stick & trying to prevent your opponents from doing the same. If you just say 'hockey', people will assume (rightfully) that you're talking about the one played on ice. And if you just say faster (without reference to anything else), it means speed -not acceleration.
12-29-2016, 11:25 PM | #188 |
Drives: 2004 Pontiac Grand Prix Join Date: Oct 2010
You know, if that list was completely accurate (which it wasn't) then the Camaro isn't going to get a LT5 engine.... the only listed engines were the engines that the car currently has.....
Also if you were to believe that list then the Cadillac CT6 is getting the LT4 V-8 engine..... and no 4.2TT V-8 engine..... Now we know that the CT6 is getting a 4.2L V-8 engine, this has been talked about by Cadillac marketing team for I think over a year now. This engine is suppose to pack in the upper 400BHP range (probably something like 480BHP). |
12-30-2016, 08:38 AM | #189 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
12-30-2016, 09:15 AM | #190 | |
There is also serious question if a 6.2L DOHC engine would actually fit under the hood of the Camaro, not only is it a good deal taller it is also a good deal wider. Not only that but if I remember correctly before the LT1 engine was shown off this same list from then had the LT1 engine written down as OHC however no one believed it as we already knew at that point that it was going to be OHV. There are just a number of things that do not line.... firstly the rumors have suggested that the ZR1 will be more powerful then the Z06 Corvette. If that was so then where is the supercharger or turbocharger? it is extremely unlikely that GM will produce a 6.2L normally aspirated V-8 that makes about 700BHP. However if they were to do this then they lock themselves out of selling this vehicle in the European market a move that the Corvette team seems unlikely to do. Though if this is the engine that I think it is then no AFM would make the LT5 engine a not for European market as well. If this is for the mid rear engine Corvette which would make the most sense then it would likely pack around 550ish BHP and would fit. That would mean that the first rear mid Corvette can't be sold in Europe something that to me makes no sense as Europe has always been the real push to produce a rear mid Corvette. You see the issues here is you now have rumors that do not add up and even on the list there are obviously spotted errors. Such as the fact that the LT4 based on the engine part of that list is slated for the CT6 however on the VIN part it wasn't on there. Meaning there are contradictions on the list, so we will have to wait and see what is going to happen. |
12-30-2016, 12:19 PM | #191 | |||
12-30-2016, 03:26 PM | #192 |
Drives: 2017 2SS Hyper Blue Join Date: Dec 2016
I suspect the Z28 and mid engine Corvette will get an engine from GM's existing portfolio.http://www.chevrolet.com/performance...lt376-535.html
12-30-2016, 04:02 PM | #193 |
Don't think that's whats coming in the Z/28.
12-30-2016, 04:28 PM | #194 |
SABIO
I think the shift is away from Europe. Its all about Arab and Chinese (Asian) money. They pay large for these cars...lots of them. I would hazard a guess there are more Corvettes and Camaros, etc out in those markets than in Europe.
12-30-2016, 07:05 PM | #195 | |
They looked at the 3.6L TT V-6 engine (LF4 engine found in the ATS V) for the C7 Corvette however the LT1 beat it in fuel economy and is something like 10 pounds lighter then it. Actually I don't think the rear mid engine Corvette will be called y body as there is going to be production overlap and that would complicate logistics. The info IMHO just doesn't line up well (as well as with other products on that list), someone pointed out that based on that no more 2.0T and 3.6 V-6 engine in the Camaro. It is completely possible that what was seen is accurate, though I honestly have some serious questions about it. |
12-30-2016, 07:06 PM | #196 |
You would probably be correct, though I haven't seen any evidence of a shift as far as Tadge is concerned. Though maybe Corvette sales havn't taken off in Europe as much as they thought so they are saying screw it.
