#183 |
![]() ![]() Drives: 2016 2SS Hyper Blue Join Date: Oct 2015
I posted a thread specifically asking about the A8 overheating and was told they added more cooling to deal with this issue
Is that not the case? |
#184 |
![]() Drives: Camaro-future Join Date: Dec 2015
I'm in so cal and still haven't be able to test drive a v8 (limited supply) around me, but if the a8 automatic is similar to the one I had in my 2014 RAM R/T (also a a8, single cab truck) I doubt I will pass it up for a manual. If the temps stay ok around the track I'll also track it. I bet it will do just fine and hold its own.
#185 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
The 8L90 is rated at 738 lb-ft of torque in a 13,200 lb vehicle. You should be fine with either transmission. They are well suited for any type of driving/racing you want to do, and don't get pulled in by the naysayers when it comes to the overheating issue. They run them hard all day in the Nevada desert at Ron Fellows without any overheating problems, so you should be fine, too.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#186 | |
![]() Drives: 2005 Cobalt Base - 5 speed Join Date: Apr 2015
It's nothing I'd worry about. |
#187 |
![]() Drives: 2013 370Z sports Join Date: Sep 2015
#188 | |
Sent from my SAMSUNG-SM-G920A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#189 |
I'd say the A8 is a good bet, since it's the same tranny as in the Z06 that has 655 HP and torque.
#190 | |
145lb Powerlifter
Drives: 2013 Camaro 2SS RS LS3 Join Date: Jan 2014
There will be far more A8 failures than M6 failures due to the wild differences in design.
#191 | |
145lb Powerlifter
The A8 will outsell the M6, and it will do so because of necessity. Most Americans cannot operate a clutch. If every American knew how to operate a clutch, there would be a serious reduction in A8 sales and a serious increase in M6 sales. The fact is, there are huge numbers of people that will buy an A8 and really want an M6 but never admit it, and there will be hardly any M6 drivers that would want an A8 outside of maybe once or twice at a drag strip. Many Gen 6 owners will pay an extra $1500 and get two things: an A8 and Regret. Vehicle manufacturers are acutely aware of this "automatic transmission regret" phenomenon and that's why paddle shifters exist. They are some luke-warm sense of accomplishment.
#192 | |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
#193 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
![]() I owned a 5th gen, for a very short amount of time since I did not enjoy it. Too heavy, not well balanced, etc, etc. But with equal drivers, stock for stock, the automatics are slower. That is a proven fact...but you can chose to think what you want. |
#194 |
![]() Drives: 2015 Challenger SRT Join Date: Jan 2016
Based on going frame by frame in this video (just after the 4:15 mark where he's shifting with the paddles), I measured the paddle delay on the C7 A8 at 633ms:
https://youtu.be/eoBrAydXK28 So a little more than a half second: I presume the Camaro will shift at the same speed so I don't believe the delay to be as much as a full second. Might seem that way but unless the Camaro paddle shifts significantly slower than the C7 with the same transmission, it's just over a half second. A decent manual driver shifting a manual can probably shift in about half that time, but given that you can factor in the delay and plan for it in most situations and the fact that you don't really have to use the paddles, I don't see the delay as being a big factor in performance comparisons between auto and manual. Edit: did the same thing for my paddle shifting video and I get 400ms for the Challenger. Not as big a difference as I thought. Mike |
#195 | |
#196 | |
"Old School"
Might be faster to an "On Paper Racer" but at the track the slight difference in power looses out to the automatic so you can think what you want.
