TireRack
Old 08-27-2017, 04:12 PM   #183
maxxmoto
maxxmoto's Avatar
Drives: 2013 2SS/RS
C7 Style Conversion
I know this is an old thread, but here's my idea for my 2015 ZL1.
Does anyone out there have any experience or feedback about the DuraFlex C7 'Vette style bumper conversion for the '14-'15 Gen5s?
I envision this bumper/diffuser with the Corsa C7 Corvette center exit exhaust tip (matches the provided center space perfectly), with the side exits filled and modified with diffuser strakes and/or bottom plate as built by Aero Sport Concepts. This set-up would go with the MagnaFlow 3" SS cat-delete, muffler-delete, center exit system.
Any feedback pro or con is welcome.
Cheers!
"Dang-it Boss! I've cut it three times, and it's still to short!" Delbert Einstein
maxxmoto is offline   Reply With Quote
Old 08-27-2017, 04:17 PM   #184
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I've seen that's diffuser before. It's not my style, but the main reason why I wouldn't get that diffuser is because it made by duraflex. They've been know for figment issues and having to modify it to fit.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 08-27-2017, 04:21 PM   #185
maxxmoto
maxxmoto's Avatar
Drives: 2013 2SS/RS
Thanks! Yeah, I have heard of fitment issues with them.
Maxx
Cheers!
Old 08-27-2017, 04:41 PM   #186
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I bought the Duraflex part that is like the Havoc diffuser. I'm going to start the project this coming week. I had to order some resin and other supplies because I need to mod the openings for the NPP exhaust. So I'll be painting and all that fitment won't be an issue.
Having said that I've been around for a little while been messing with cars for thirty years. Hell i painted my first car at 15. I will tell you fibreglass parts NEVER fit out of the box. There will ALWAYS be fitting to do. That's just the nature of the beast.
If you want a drop on part plastic OEM stuff is for you...
Sent from my SM-G935V using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-28-2017, 05:16 PM   #187
Machinehead
Drives: 2012 LS
Polyurethane fits and is more suitable than fibreglass as well
Sent from my SM-G955U using Tapatalk
Machinehead is offline   Reply With Quote
Old 07-04-2019, 07:57 PM   #188
SlickbackJr
Drives: 2010 Camaro LT
Originally Posted by Aero_Sport_Concepts View Post
Couple pic of the finished product.
Sent from my XT1254 using Tapatalk
Where... would I buy this...
SlickbackJr is offline   Reply With Quote
Old 07-05-2019, 11:44 AM   #189
PapaKlutch
PapaKlutch's Avatar
Drives: 2015 Camaro SS/1LE
https://www.aerosportconcepts.com/st...en_Camaro.html
2015 2SS/1LE/RECARO/NPP/RS/NAV
PapaKlutch is offline   Reply With Quote
Old 01-11-2020, 02:30 AM   #190
Ashn4it
Ashn4it's Avatar
Drives: 2012 Ashen Gray LS3 M6 (SOLD)
Still running my Havoc Diffuser, but still thinking of going to a ZL1 diffuser with quad tips...
2012 Camaro SS/RS LS3 6Spd (SOLD)
2011 Camaro RS 6 Spd (SOLD)
2007 Subaru WRX STI (SOLD)
1997 C5 LS1 Corvette (SOLD)
1985 C4 L98 Corvette (SOLD)
1967 Camaro RS/SS 383 sb (STOLEN)
Ashn4it is offline   Reply With Quote
Old 03-24-2020, 01:02 PM   #191
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
For sale brand new unpainted buyer pays shipping.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 05-09-2020, 02:36 PM   #192
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Does anyone know where I can get this stainless steel piece that was added to the stock diffuser on this car. Apparently owner no longer belongs to this forum as he sold the car in 2018. Thanks.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 05-10-2020, 08:42 AM   #193
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You mean this??
https://www.phastekperformance.com/2...rim-102021.htm
1JEWLDSSRS is offline   Reply With Quote
Old 05-10-2020, 11:50 AM   #194
flht99b
flht99b's Avatar
Almost. I saw this in my search. The piece Phastek sells goes on the flat part of the diffuser right below where I want to cover (honeycomb area). I suppose the one on the Camaro vert was made buy owner which I'll do, just seeing if there was a commercially available piece that I could just paint semi gloss black and install. Thank for looking.
rear diffuser
WTT Razzi V8 rear diffuser for GFX rear diffuser painted SA CHEVY Local Marketplace 12 03-06-2011 01:09 PM
Hand made Quad Rear Diffuser 2SSRS@Gen5diy Exterior Parts & Accessories 131 03-05-2011 06:29 PM
F/S: INFERNO ORANGE METALLIC Factory GM side skirts and rear diffuser FINALLYSATISFIED Exterior Parts & Accessories 10 10-17-2010 02:19 AM
New Camaro Rocker Panels and Rear Diffuser compuwiz1937 Exterior Parts & Accessories 23 04-29-2010 09:33 AM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
