07-25-2022, 01:51 PM | #183 | |
Drives: 2022 1LT RS 2.0t/6spd Join Date: Mar 2022
Just like smart phones? Out here in the SW ICE vehicles are routinely on the road for well over twenty years. Given the damage heat does to batteries, not to mention living with reduced range as well due to the heat, an EV could well be looking at two very expensive battery replacements to achieve the same level of durability. |
07-25-2022, 02:08 PM | #184 |
Electrical Engineer
speaking of an EV Camaro...
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
07-25-2022, 03:20 PM | #185 | |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
I mean I actually don't use the brake pedal the whole trip. The regen braking will take you to a complete stop and apply brake hold while at a stop. Tesla actually implements a light brake wipe into the software programming just to make sure you don't get rust build up, etc. There is a battery cooling system but there is no required fluid change for it because it is not subjected to the high heat and the fluid will last the life of the car, supposedly. Same thing for the oil in the drive units, lifetime fluid and the supposedly last for a million miles. As for the batteries, they are rated to last 300,000 - 500,000 miles. They give you a 8 year 120,000 mile powertrain warranty, 4/50,000 on everything else. They use sophisticated battery management systems to keep the battery at the proper temperature. When you are planning to Supercharge, it will heat up the battery so that it will accept a charge better. The battery is very expensive, about $15k installed to replace the one I have. This is the biggest concern owning one long-term out of warranty. I was referring to smart phones for this reason. You have to be prepared to trade-in EVs fairly quickly as the innovation cycle on them is just ramping up. ICE technology is pretty much maxed out. Now, in 10 years from now as they scale up battery production, the cost should come down. They are also working on battery recycling where you sell back your existing battery and swap out with a new one. https://www.carshtuff.com/post/can-t...es-be-recycled
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
07-25-2022, 03:26 PM | #186 |
I really hope it doesn't wind up looking like that. If so, just let the Camaro die and call that thing a Malibu or something. The best part is when you take it to the car show and lift up the hood to reveal the frunk instead of the engine. I guess you can keep your beers on ice in the frunk.
07-25-2022, 04:28 PM | #187 | |
Electrical Engineer
I would, however, be interested in buying it if it looked like this... as an equivalent replacement for my Accord while keeping the Camaro SS as the tribute to ICE.
07-25-2022, 08:05 PM | #188 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
07-25-2022, 08:05 PM | #189 | |
EV batteries don't care about mileage or number of years any more than your smart phone battery does. They care about the number of recharge cycles and the duty cycle associated with those recharges. Information is already coming out that says to not charge above 80% or let them drop below 20% to maximize battery life. There goes 40% of your range. You "rarely touch your brakes"? How does the car know to slow down and at what rate? I'm sure there is hyperbole in your comment but be serious, EV's are heavy and their brakes will need servicing regardless of the presence of Regen braking. |
07-25-2022, 08:23 PM | #190 | |||
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
For the times you do need the range, yeah charge to 100%. The goal is just to minimize the times you go to 100% and below 20%. Quote:
Even if you have no interest in EV/Tesla's, go test drive a Tesla if you have a showroom near by. This part will be clarified within 30 seconds of your test drive. |
07-25-2022, 08:32 PM | #191 | |
Electrical Engineer
For the braking, do you think some of the stoppage in traffic is also the car assisting (automatically) or is it really clear that's not happening and you're simply learning how control regen aggressiveness with pedal behavior?
07-25-2022, 08:41 PM | #192 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
The ‘how often do you need that range’ is, imnsho, a stupid question.
Maybe I need it once a week (pretty close) or maybe only once a month. However many times it is, an EV goes down as a failure every time. Why turn in an ICE vehicle that meets all your needs for an EV that definitely will not? Yeah, in the future blah blah. BS! It’s not the future. Right now, the range isn’t there, the chargers aren’t there, affordability isn’t there. Without subsidies the minuscule amount sold would be even smaller. |
07-25-2022, 08:44 PM | #193 | |
Now with the latest software update issued by Tesla, they have introduced a feature where it will automatically blend in the friction brakes when regeneration braking will be limited in order to maintain single pedal driving. The two situations regeneration braking will be limited is if charged to 100%( electricity has nowhere to go if the battery is already maxed out) and the battery is too cold in the winter to accept the amount of electricity being produced by regeneration. The battery being too cold can be mitigated by preconditioning the car before leaving the house( car will warm and cabin and battery up using house power) or have the car charge right before you leave( charging the battery will naturally warm it up). By doing that mitigation, I haven't had issues with regen braking this winter and was still strong enough to stop the car. Last edited by ChevyRules; 07-25-2022 at 08:56 PM. |
07-25-2022, 09:14 PM | #194 | |
07-25-2022, 09:36 PM | #195 | |
You have to think of EVs as a platform now, much like our smart phones, cable services, gaming systems. You buy this hardware platform which will be enabled with new features as you own the vehicle. Performance boosts, ability to add new apps, etc. My Tesla UI and features have change quite a bit since I first bought it in 2019. When I first got it there was no "brake hold" so you could only use the reg braking until about 5-10mph and then you had to apply the friction brakes. Then you get an update and bam, you can enable brake hold. Initially, the car only used the backup camera for reverse, then they said why not add the two side cameras on the fenders as well for more camera angles. So, the OTA updates are not just fart noises and games but they can keep tweaking the UI and improve the driving experience. In the first year of ownership the car received two performance boost updates, adding about 30-40hp on my Model 3 Performance. It knocked about 2 tenths off the 0-60mph and 1/4 mile times.
07-25-2022, 09:41 PM | #196 | |
Each manufactures seem to program the regen a little different. Some put paddles on the steering wheel with different levels. Tesla used to have a standard and low setting but I think they just set it now and let everyone get used to it since having it one improves your range.
