08-17-2019, 06:22 AM | #1933 |
I expect that with some more practice, you'll probably lower your times. I saw your other post where you said that it went 115mph in 'D'. Mine also ran slower mph when I tried paddle-shifting, so I use 'D' on the dragstrip because of that problem.
08-31-2019, 01:40 AM | #1934 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Tires used on the pass: Hoosier 275/50/15 DR
Performance Mods (if any): DR, Front Skinnies, OTR CAI, PTB, Ported MSD intake , UD crank pulley, Headers, Rear seat delete, Front pass seat delete, lightweight battery, carbon driveshaft, exhaust dump, pump E85. Stock converter. Stock gears. Stock suspension. Category submitted for: Bolt on no internal mods (Stock Displacement) R/T.......... .4487 60'.............1.569 330'...........4.472 660'...........6.850 660’ mph...103.23 1320'..........10.669 1320’ mph…128.10 Name of track: US 131 Date of pass: 8/30/19 Weather conditions: +750 DA Last edited by ULTRAZLS1; 08-31-2019 at 01:56 AM. |
08-31-2019, 06:05 AM | #1935 | |
Drives: 2016 2SS Join Date: Jul 2016
08-31-2019, 08:03 AM | #1936 |
It’s not too bad
08-31-2019, 10:57 PM | #1937 |
Just went 9.61@144 today at WWT Raceway in Stl. Pretty hot at 86 degrees and 2900 DA. Man if I could get some cool air, pretty sure I can get in the 9.40s
09-07-2019, 10:06 PM | #1938 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Owner's Name/Handle: Mathew Everett (Lethal Camaro)
Built By: Red Barn Racing & Lethal Garage Tuner: Mike Franz, Red Barn Racing Year of the 6th Gen Camaro: 2016 Tires used on the pass: MT 275 Pro Performance Mods (if any): Supercharger, build internals, fuel system, E85, etc. Category submitted for: 5 Transmission: A8 60'.............1.403 330'...........4.117 660'...........6.332 660’ mph...111.34 1000'..........8.241 1320'..........9.854 1320’ mph…140.02 Name of the track: Famoso Raceway Date of pass: 3/24/19 DA if known: 1,680 Vehicle Weight: 4,312lbs w/driver Video: https://youtu.be/25xctROsloc - Jump to 13:24 for the run and slip.
09-08-2019, 12:51 AM | #1939 |
Just finished Saturday at the LS Fest and ran a personal best of 9.41@146 1.35 short time.
Category #5 Magnuson Heartbreaker, cam, Meth/water, 17" MT drag radials, headers stock trans and rear. 60ft 1.354 330 3.931 660 6.050 MPH 117.29 1/4 9.414 MPH 146.73 Times were at the 2019 LS Fest Bowling Green Ky on Saturday 9/6/2019 Car 3377 Temps in the mid 80's and DA upper 2000's
09-08-2019, 06:31 AM | #1940 |
Congrats guys. Glad to see the projects finally coming together for you guys.
09-08-2019, 06:34 AM | #1941 |
We will be in the 9.20s in some good air. We sure didn't have that yesterday. Temps were mid 80's and DA over 2000.
09-08-2019, 07:59 PM | #1942 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
Please update me
2017 1SS A8 Tires used on pass: DR 305-45-17 Mickeys with M&H Skinnies & Racestar wheels (dragpack) Performance parts: Procharger P1X LT4 Fuel System, Meth, Cat delete,Converter,CFDS Category or Category # 5 Power Adder Stock Displacement R/T........... .2156 60'............. 1.4633 330'........... 4.2215 660'........... 6.4867 660’ mph... 108.59 1000'.......... 8.4462 1320'.......... 10.1241 1320’ mph… 134.17 Name of the track: Mason Dixon Dragway Date of pass: 9/7/2019 Weather conditions: Include Density Altitude if known.DA around 2300 FULL WEIGHT
09-08-2019, 10:32 PM | #1943 |
Nice pass Dan and you are so close to the 9's
09-09-2019, 04:36 AM | #1944 |
Thanks , so close but 9s are not happening on the SBE for me, looked in the mirror at the end of that pass and it was a smoke show. Not a seal either smoke rolling out tail pipes and mighty mouse breather, time to regroup.....
09-16-2019, 09:40 AM | #1945 |
Drives: 2017 zl1 camaro Join Date: Feb 2019
9.90@140.11
Mods: 95mm tb jokerz full tilt blower methanol injection 9.55 lower larger hx 2 inch headers no cats 5 inch intake 18 inch drag radials skinny’s up front. On e60 fuel.
Category submitted for: 8 zl1 bolt on only R/T........... .245 60'............. 1.48 330'........... 4.18 660'........... 6.39 660’ mph... 110.42 1000'.......... 8.29 1320'.......... 9.90 1320’ mph… 140.42 Name of the track: South Georgia Motorsports park Date of pass: 9/14/19 Weather conditions: 1800da hot and humid had just rained so air very heavy and miserable. A little quicker then when was at 650 da for the 9.95 pass. Still sorting out new blower setup and trans tune as stringing it out too much. Actually hit the 1-2 rev limit and still ran this pass why the 1/8 was down 2-3 mph over some other passes that day. Car has 9.70s in it in this heat so expect 9.50s in the winter. This 9.90 was the second of 3 hot laps back to back passes.
9.52@143 first bolt on only car to reach 9.50s. First zl1 in the 9s on stock unported blower. Sbe LME heads gptuning cam typical mods jokerz prototype port blower 9.30@150 best so far work in progress. 4.70 60-130 at 3800da now in Tennessee.
Last edited by Lt4zl1; 09-16-2019 at 09:48 AM. Reason: Forgot some stuff on mods |
09-16-2019, 10:30 AM | #1946 |
Nice pass LT4, your getting there. Congrats.
