#1835 |
Thx wanta5th
#1836 |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Tires used on the pass: MT 305 SS Street DR
Performance Mods (if any): Whipple, LTs, LT4 Fuel, Water/Meth, E55, DRs, Rotofab Category submitted for: Please List the Category or Category # R/T.......... .285 60'............. 1.551 330'........... 4.398 660'........... 6.729 660’ mph... 105.72 1000'.......... 8.738 1320'.......... 10.445 1320’ mph… 131.75 Name of the track: Spokane County Raceway Date of pass: 3/31/2019 Weather conditions: Include Density Altitude if known. DA 2,100 |
#1837 |
Way to go Rob, we are both making progress. What did you add to run the E?
#1838 |
Tactical Garage
I added a flex fuel kit (skidmark) and did the tuning. No pump e85 here, so I got a 55 gallon drum of E85 and mix it to e55 for the track. Then switch back to pump gas when I leave the track.
#1839 |
Great idea. I like that idea. Do you have any other low side fuel system besides the lt4 intank pump?
#1840 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Apr 2019
Tires used on the pass: Hoosier 28x10
Performance Mods (if any):Roto Fab dry, 103mm TB, Ported MSD intake, ARH 2" headers, full ARH 3" system, flex fuel tune by me, e70 for this run. Category submitted for: 3,11 R/T...........9735 60'............. 1.63 330'...........4.70 660'...........7.22 660’ mph...97.97 1000'.......... 1320'..........11.22 1320’ mph…123.05 Name of the track:US 41 Date of pass:4/26/19 Weather conditions: DA 1200ft Left lane. Car #68. Last edited by NickeyMatt1LE; 05-02-2019 at 07:12 PM. Reason: Circled the timslip |
#1841 |
Good pass 1le.
#1842 |
![]() Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
Figured id post this
2017 SS all stock .
#1843 |
Wow, a 1.67 60 ft all stock is very impressive. Congrats
#1844 |
#1845 |
Tactical Garage
No just the lt4 intank, lowside never dropped below 41psi. Will add a boost a pump later if needed but it is holding good for now. I also switched back to the 3.5 upper pulley to lower the boost to 9psi for the street.
#1846 |
Good job Rob. I will at some point go to E, probably before Camaro Fest.
#1847 |
41 psi is not what I would call holding good...I would do the boost a pump now.
#1848 |
I'm sure his high side is staying in the 2900 to 3000 psi range. Mine drops to about 48 psi at 14-15 lbs of boost on VP109 and that's with a 70mm or 2.8 inch pulley, but I'm also spraying meth/water for additional fuel. I might be able to drop down to 10 lbs of boost and run E50 or E60. I am tired of paying 14 bucks a gallon for race fuel.
