Old 06-24-2019, 05:33 AM   #169
Lazerbrainz2k3
Drives: 2017 Camaro 2SS - M6, NPP, MRC
It's been asked a couple times, only available for the V8s for now but they're working on others
Lazerbrainz2k3 is offline   Reply With Quote
Old 06-24-2019, 09:18 AM   #170
68Vette
Drives: 1SS Hyper Blue Metallic, MRC, NPP
Originally Posted by crankaholic View Post
Installed mine last night and got though the re-learning procedure today...
Without sounding like a noob, why do you have to do a re-learn, can't one simply disconnect the negative post of the battery before installing and once finished reconnect and it's good to go?
68Vette is offline   Reply With Quote
Old 06-24-2019, 09:23 AM   #171
Z0Tex
@texan.1le
Z0Tex's Avatar
Drives: '18 Camaro 1SS 1LE, PDR
The instructions say you can do that, but it will take longer for the ECU to learn the new throttle body's behavior. Like several "drive cycles" worth of time, which depending on how often you drive your car, could be weeks. Disconnecting the battery for that length of time clears out the memory for the TB settings and the relearn process happens much, much faster.
My new Soler TB should be delivered today. Can't wait!
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily
Z0Tex is offline   Reply With Quote
Old 06-24-2019, 09:32 AM   #172
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
What Z0tex said, and let me add that even if you change a stock TB by another stock TB, the shop manual instructs you to reset the ECM TB learned values, and do the re-learn for the new one.
Experience shows that it is not strictly necessary, most times it works just fine and when it doesn't it is not catastrophic. You might get a temporary code that you can erase and should not show up again or a little rough idle that it should learn in a few starts.
Tiffany,
Soler Performance LLC,
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-24-2019, 10:06 AM   #173
Originally Posted by vidkidZ View Post
I didn't have much luck finding the connector or the parts online. Hopefully Mike@SolerPerformanceLLC has an idea where to get these parts as I can't be the 1st or the last to have lost them to the engine bay.
vidkidz, we apologize for the mishap, we just found out about these new connectors on the 2019's.
It looks like it is p/n 2272975-5 made by Tyco Electronics (TE/Amp). See attached; could you verify?
I'll try to get the connector and terminal (pins) for you to replace it. In the meantime, if you find another solution please send us the quoted price and we'll pay it off for you.
The same goes for all other customers that accidentally broke the locking tab.
Thanks,
File Type: pdf 2272975-5 6-Pin Automotive Connector.pdf (424.9 KB, 531 views)
Tiffany,
(251) 468-9786
Old 06-24-2019, 10:17 AM   #174
MackSteelPrivateEye
Whats the Failure rate of a stock TB on a 6th Gen SS? Suppose you get a core back with 60, 70k + miles on it and you port it? Isn't there more chance of failure sooner with that type of mileage? How do we know how many miles is on the used PTB you ship out to us?
Old 06-24-2019, 10:27 AM   #175
We have seen zero mechanical failures, zero electric motor failures, and only one sensor failure in more than 100 exchanges so far.
We stock all of these spares, that allows us to give you a 1-year warranty regardless of your choice of new, exchange, or reworking your own. After that, we'll still help you if anything were to fail, for a reasonable fee. I don't see it being more than $50 for a sensor or motor replacement. These units should last a lifetime mechanically, only may need cleaning from time to time, which you can easily do.
Tiffany,
(251) 468-9786
Old 06-24-2019, 10:38 AM   #176
RyanR623
Drives: SS A8, NPP, Red Hot
If i were to buy the TB without sending mine in, do you start with a new or used TB?
RyanR623 is offline   Reply With Quote
Old 06-24-2019, 10:56 AM   #177
Brand NEW. Used ones are only for exchanges. Thanks.
Tiffany,
(251) 468-9786
Old 06-24-2019, 11:03 AM   #178
RyanR623
Awesome thanks! Will be ordering soon.
Old 06-24-2019, 11:05 AM   #179
68Vette
Thanks for the response from both of you guys, I'll be ordering one within the next week or two.
Old 06-24-2019, 12:09 PM   #180
Spedee
Spedee's Avatar
Drives: SS
Originally Posted by ZL1 1LE View Post
Wondering if you considered putting the OEM back on and sending the TM to Soler for further modification?
I did but Mike suggested modding my OEM and then try and sell the Mamo. Price is the same.
Spedee is offline   Reply With Quote
Old 06-24-2019, 12:13 PM   #181
Z0Tex
@texan.1le
Z0Tex's Avatar
My new Soler MTB arrived today. Going on a damn-near stock '18 SS 1LE. I had Mike add a little something extra to the blade. Looks great and I can't wait to get it on the car to see how much the driveability will improve.
Old 06-24-2019, 12:15 PM   #182
Grumpy1
Grumpy1's Avatar
Next will be to get in line for a PRAY ported stock IM after CamaroFest.
Sweet.............
Grumpy1 is offline   Reply With Quote
