Old 01-13-2024, 11:46 AM   #169
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Originally Posted by Msquared View Post
Dave, it helps to think of squat as the car's suspension actually trying to pick the rear tires up off the ground rather than as the result of weight transfer. In most situations in most RWD cars, squat is caused by both. But the result is always the same: squat actually unloads the rear tires as it happens, rather than loads them. Once the suspension reaches "full squat" (static), then the full tire loading from the weight transfer occurs - but until the suspension stops moving. In any car with less than 100% anti-squat (almost all of them), you can set the parking brake and try to accelerate and the rear will still squat, even if the car doesn't roll. That's the suspension trying pull the tires up into the wheel wells, and it hurts drive traction. In cars with more than 100% anti-squat, the back end will lift up instead. That's what drag racers really want. You'll never see a serious drag racing car squat on launch - you mostly notice the front end rise.
Ahh, ok. I was definitely thinking about that incorrectly. I thought squat would help weight transfer and load the rear tires but it's the other way 'round. I'm definitely not a drag racer.
I forgot to mention that I own a copy of Race Car Vehicle Dynamics and actually did read it cover to cover. The world would be a better place if everyone did that! My son has it now.
Ordered!
Old 01-13-2024, 05:45 PM   #170
clyde
clyde's Avatar
Drives: broken
I have this book.
Of course, what I really need is "Race Car Vehicle Dynamics for Dummies."
And if you're up for some really light reading next, there's "The Shock Absorber Handbook."
clyde
Team WTF?!
what are you gonna do? :dunno:
clyde is offline   Reply With Quote
Old 01-13-2024, 08:38 PM   #171
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
The closest thing I know to that is Think Fast: the Racer's Why-To Guide for Winning, by Neil Roberts. It's an uber-practical guide to how and why to set up a car. Neil is a friend of mine from college, and after getting his aerodynamics engineering degree, he went on to become a very successful motorsports engineer. His last (maybe longest?) gig was working at Honda Performance Development. When Indycar adopted rules that let Honda and Chevy develop their own aero packages, the first Honda package was designed by Wirth in England, and it was a hot mess. Neil lead the team that created the second-gen package, which was immediately successful. He also led the team that created the IMSA DPi Acura car that Penske and then Wayne Taylor Racing and Michael Shank Racing campaigned through last year, too. But this book is really down to earth. It makes a nice book-end to the Milliken tomb, and it's good to have both on your shelf.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 01-13-2024, 10:39 PM   #172
Badmojo
aka BeastZL1
Badmojo's Avatar
This is true. However, that still doesn't change the fact that neither springs nor dampers can change the lateral or longitudinal weight transfer of a car during any direction of acceleration.
Springs, dampers, and suspension geometry control how the chassis moves relative to the tire's contact with the road. The stiffness and dampening of the system control the movement dynamically. Imagine the direction of the car's center of gravity (CG) during a corner. The position of the CG influences the tire load distribution based on vehicle weight and g-force, which constantly goes forward during braking, rear during acceleration, and left/right during cornering. Dampening speeds or slows down that movement. An ideal suspension system maximizes the tire load across all four tires since the friction plateaus at a specific load point.
Shock tuning alone isn't a miracle, and it's a small part of the overall system.
Grassroots Motorsports had a recent article (probably in the last 18 months) testing the degrees of stiffness of a suspension and lap times. Even racecars need some level of compression and the ability to absorb curbs, uneven surfaces, and transients to maximize grip on all four corners. Otherwise, the fastest cars would have go-kart suspensions without springs or shocks.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 01-14-2024, 08:38 AM   #173
Msquared
Msquared's Avatar
None of that really addresses what I wrote, either to refute it or concur. If your point is that suspensions improve grip when the road is uneven, I agree. And of course they can be used to adjust both transient and steady-state handling. My point was to rebut wenlyone's assertion that dampers somehow reduce weight transfer. While I agree that weight transfer is undesirable in lateral acceleration or braking (it's generally good for acceleration in a RWD car), I am pointing out that damping (and springs, for that matter) don't change the amount of weight transfer that takes place at a certain magnitude of acceleration in any particular example. They can affect the rate at which the transfer is applied to the contact patches, however.
Matt Miller
2020 SS 1LE
Old 01-14-2024, 12:08 PM   #174
Badmojo
aka BeastZL1
Badmojo's Avatar
From an academic standpoint, static or steady-state methodology and concepts on a dynamic system are inaccurate. I assume that Wenlyone is considering it a dynamic system, and he is correct that the most lateral grip is achieved when the load is more evenly distributed across the four tires. I interpreted your reply to dispute that. Perhaps we are using terminology differently.
My main point to the readers of this thread is that shock tuning won't usually produce measurable results without considering the entire suspension system, including the tires. It is only one piece of the somewhat complicated puzzle.
Bringing this back on topic, several people on the forum have contacted me regarding my experiences with the DSC Sport Controller. My best advice is not to get one if you expect "plug and play" measurable lap time improvement.
2019 Camaro ZL1 1LE
Old 01-14-2024, 12:23 PM   #175
Msquared
Msquared's Avatar
No, I fully agree on that. That's literally the entire basis for chassis tuning. Again, my only point was to rebut the assertion that dampers reduce weight transfer due to acceleration.
Matt Miller
2020 SS 1LE
Old 07-09-2024, 05:17 PM   #176
wenlyone
Drives: Chevy camaro
Would you happen to know the difference between v2 and v4?
I am getting a v2. Could I still benefit from your settings?
What alignment kits would you recommend also?
Thanks!
Originally Posted by DOHCVTEC View Post
2018 ZL1 with the DSC V4 controller in there for a couple of months now..
Starting to understand it a little better, learned a few interesting things and found a few bugs. Overall I like this controller very much!
it also occured to me while doing some slight tuning, that we can share tuning parameters and maybe save each other some time.. Sort of like, this worked, this didn't, this made the car faster, slower, and so on. For example, in a few minutes I was able to tune out that way too soft ride you get in touring and even sport mode when you are not throwing the car around.. very simple fix.
I also discovered a few bugs in the system and waiting for a call from an engineer to verify. One may really interest some of you... so it appears that the suspension only changes when you switch the chassis settings, but not the independent suspension settings on your stereo screen. so if you are in touring chassis mode and race suspension mode, you may feel no difference and it appears this is why. I noticed it while data logging the current level going to chocks.
There is another thing but I can share if anyone has interest in tuning your controller..
hope there are more of you out there!
wenlyone is offline   Reply With Quote
Old 07-10-2024, 04:00 AM   #177
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
My DSC V4 controller is for sale if anyone is interested send me a PM.
UPDATE: I sold mine. Now running MCS 2-way RR coilovers
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87
dsc controller, dsc sport, mag ride, zl1
