Old 06-27-2020, 05:51 PM   #169
IneedAZ
IneedAZ's Avatar
Finally getting it done. Have an APPT for July 6th weather permitting. Figured I would do the elsd cal prior to the engine mods.
Old 06-27-2020, 06:08 PM   #170
Mark R
Drives: 2018 ZL-1
I had that done and noticed no difference.
Old 06-27-2020, 07:20 PM   #171
IneedAZ
IneedAZ's Avatar
Your launches were the same? What mode did u launch with? What power level were u when u last tried it?
Old 06-27-2020, 09:50 PM   #172
AZ_1LE
Drives: 2019 ZL1 1LE
Originally Posted by Krowser View Post
Most of you may not know this, but the main suspension bolts are torque -to-yield "TTY".....this means they are a one time use only!!!
Every time you align your ZL1,SS, SS 1le or ZL11Le, you should be using BRAND NEW GM bolts (if you are using stock bolts). THE BOLTS MUST BE AT THE PROPER TORQUE SPECS.
If you have your car aligned using the old bolts, you may experience irregular rear end pulls during WOT, sweeps, uneven pavement etc...etc.
The other reason you may experience unusual driving characteristics during spirited driving is the tire conditions, diff fluid, or tire pressure may be off for what you are trying to do...
...stock is 650lbs tq at the crank...that's alot for a stock car.
Just my $.01.5....
The only bolts in the suspension which get touched during an alignment and which are TTY are the ones for the rear toe. The rest are reusable.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 06-29-2020, 10:37 AM   #173
Mark R
Drives: 2018 ZL-1
On the drag strip in track mode, it launches just fine. On the street, I am always in sport mode, which is when I get a little wig-wag. I have tried turning TC off, and that helps quite a bit.
Old 07-03-2020, 06:13 PM   #174
IneedAZ
IneedAZ's Avatar
For those that had this done, can you confirm it is done thru the ecm. I was told by dealer they plug a device into obd port that communicates to gm via satellite for the download.
Old 12-10-2021, 12:33 PM   #175
manders500
Drives: 2017 ZL1 Camaro
Originally Posted by 7WSM View Post
Go to the dealership and tell them to reprogram it. The cost is fixed at 350.00. Document ID highlighted because advisors will not have a clue what the hell you are talking about.
I know that this is old, however, I took my new to me '17 ZL1 and they were still clueless. Claimed that I had to order a kit?
manders500 is offline   Reply With Quote
Old 01-27-2022, 01:59 PM   #176
brad65ford
Drives: 2018 Zl1 Camaro
Originally Posted by Alain View Post
Keep hammering on it to see if the new alignment cured the wiggle and report back to us man!
That wiggle in the rear at highway pulls is a buzz kill for me since it’s really one of the few times I beat on the car. I don’t do road course so it’s twisty back roads and highway pulls for me.
I don’t see myself keeping this car forever like I want to if I can’t figure this wiggle out.
Originally Posted by Krzfst View Post
I have been fighting this all year hard acceleration goes to the left then back to the right I have to get out of it feels like rear end is coming around I put all bmr parts in rear suspension helped but didn't cure it worse with my drag radials on need help on this one
Originally Posted by 17CamaroZL1 View Post
Same here. The 17" drag radials on the rear make it 10 times worse. With the stock rears, it barely moves and I can pretty much just keep the wheel straight, but with the drag setup (rears only) it's all over the place. I have to actually make steering corrections to keep it in my lane. The weird part is that it doesn't always do it and it's really bad sometimes and then barely wiggles others. It seems to be relative to how smooth and even the surface is. Both my local track here in London and Clay City, the rear was all over the place. Both tracks have older surfaces that is likely not nice and flat. Bowling Green completely resurfaced their strip and the car tracked perfectly straight every time during Camarofest.
If it's being caused by uneven surfaces, unhooking the front sway bar might fix it (at least at the strip). These cars are super stiff and it doesn't take much of a dip to unload one of the rear tires. So at full throttle, it makes sense that it would take way less to cause one tire to have less grip than the other. I just might have to give this a try one day and see if it helps.
Originally Posted by 6spdhyperblue View Post
I would inquire with supercharged SS guys running low 10s/9s and see if they’re experiencing the same thing. I would think it can be narrowed down the the elsd then. (Would be surprised the elsd drag cal wouldn’t mitigate) Are convertible guys feeling the same stuff? The suspension are similar I’d be surprised if the difference would be enough even between ZL1 and SS.
I have a SS with magride trapping mid/low 120 depending on weather. So it might not be fast enough or have enough torque to expose that be behavior on 17” et street ss and haven’t felt that. I do have a set of softer side walled Rs ready to go...so we’ll see
Wow came hear for multiple reason and going to leave more frustrated. Just picked up a used (unmodded 18 zl1) love the car but hate the rear wiggle / wag what ever you call it its not right feeling. Scheduled an appoint with a local dealer for this eLSD flash but no one has commented if it helped or addressed the rear movement under heavy loads. I to would think is has to do the the eLSD. Assuming only way to now if have the e diff locked sold some how and attempt the same hard runs to see if it has the same wiggle etc.. Anyone have any positive updates?
brad65ford is offline   Reply With Quote
Old 01-27-2022, 02:09 PM   #177
JSH
JSH's Avatar
Drives: '20 ZLE
Here's the link to the update info https://gm-techlink.com/?p=11978
Basically, this CCM update reduces or eliminates eLSD rear bias.
I've been trying for several months to find a Denver area dealer to do this with no luck. No one knows anything about it. You would think GM could provide this with little effort but not so.
Does anyone know of a dealer anywhere that knows this update?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 01-27-2022, 02:13 PM   #178
Mark R
Drives: 2018 ZL-1
There really does not seem to be a hard and fast consensus on an absolute cure for the wiggle. Here are the options that have been hit or miss, depending on who is posting about their experiences.
Alignment with TTY bolt replacement is a prerequisite.
Good, properly inflated tires.
Rear suspension upgrades, especially rear bushing stiffening with lock out kits or full 1LE bushings, toe rod replacement, and control arm replacement.
Then the E-diff upgrade.
Old 01-29-2022, 10:34 PM   #179
Robster
Robster's Avatar
Drives: 2017 Camaro ZL1, 6M
My car does the wiggles during a hard launch when the rears are getting old-ish. It pulls straight and steady with fresh rubber.
Robster is offline   Reply With Quote
Old 01-30-2022, 08:01 AM   #180
Z OH 6
Drives: 2024 CT5-V Blackwing
BMR cradle lockout kit will go a long ways to curing the rear end wiggle assuming you don't own a 1LE which doesn't need it.
Old 01-30-2022, 08:31 AM   #181
JSH
JSH's Avatar
Drives: '20 ZLE
Have you had this eLSD update done to your car? I'm still trying to find a dealership to do it.
2020 ZL1LE A10.
Old 01-30-2022, 05:46 PM   #182
airtroop01
Drives: 2018 Cadillac CTS-V
I have been waiting for one of you guys who got this done to come back and say wow it worked or meh not so much.
It appears to only work if you turn off traction control and ESC.
I’ve been in the camp that most of these cars need a proper alignment, those TTY bolts replaced or the rear toe arms swapped along with a carrier bushing set.
airtroop01 is offline   Reply With Quote
