Old 02-06-2019, 12:38 PM   #169
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
Originally Posted by Can'tHave2MuchHP View Post
Are you tracking your ZL1? If not, there's reason why the standard oil won't work just fine. Eventually, GM will probably recommend the 0w40 for 2017-2018s.
No track time yet. Drag racing every weekend May-September.
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 02-11-2019, 03:21 PM   #170
SWZL11LE
SWZL11LE's Avatar
Drives: '19 ZL1 1LE
So what is the definite answer on this. I read 13 pages of replies and I am a bit more confused. Too many varying answers throughout the replies.
Is the 0W40 ESP okay to use on cars that are tracked or not?
SWZL11LE is offline   Reply With Quote
Old 02-11-2019, 03:33 PM   #171
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Yes it is perfectly fine...Is it as heavy track-duty as the 15W-50? No. Will it matter? Well, if GM/Mobil 1 both say it's track capable in the faster C7 Z06 and the ZL1, that's good enough for me. At operating temperature, the weights are 40 vs 50 and both of those are capable. The difference is at cold temps, 0w is easier on the engine. 15w is heavier and the car should be carefully warmed up before aggressive usage.
Old 03-24-2019, 03:28 PM   #172
Fatty1707
Drives: 2019 ZL1 A10
Mobil1 ESP 0w40 $6.98 qt! Best price I've seen!
https://www.gmpartsxperts.com/oem-parts/gm-oil-19370233
Fatty1707 is offline   Reply With Quote
Old 03-24-2019, 07:51 PM   #173
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
That would be great except they apparently don't ship...only option was local pickup in New Jersey.
rlarsen462 is offline   Reply With Quote
Old 03-26-2019, 10:04 AM   #174
Fatty1707
Old 03-26-2019, 09:31 PM   #175
TVM1LE
Drives: ZL1 1LE Summit White
Is there anyway to easily check the rear diff fluid level? I had the service performed at a dealership last night and on my receipt it shows "1QT Fluid Rear Diff Service" and I was billed for a single quart of fluid. This has me concerned as I'm not confident in the service performed.
TVM1LE is offline   Reply With Quote
Old 03-26-2019, 10:36 PM   #176
Can'tHave2MuchHP
Drives: Fast
It's been too long since I've had my head under mine to remember...I don't believe so...Perhaps there is a sight window on the side? Maybe I'm picturing a different car/diff.
If you have a Convertible, it takes about 1.2 quarts. If you have a Coupe (eLSD) it takes about 1.6 quarts. It's possible they didn't bill you for the extra/had some remaining or, like most dealer fluids, they order in bulk and use a tank of it without going by individual quarts. The only real way to fill it is to fill until it overflows...If the tech had any experience at all he'd probably know this. I wouldn't be too worried. But you can always order the fluid and pump, pop the cap and add some til it overflows if you can't find a way to check the level.
Old 03-27-2019, 10:56 AM   #177
TVM1LE
Thank you for the reply!
My car is a 1LE so eLSD equipped.
I will get the fluid and pump to verify the work, I greatly appreciate the advise.
Old 03-28-2019, 11:10 AM   #178
Cleancoupe
Drives: 18 ZL1 1LE
Just take out the refill plug on the upper side of the diff. The fluid should be level with that. When you change the diff fluid you put in the diff fluid through that fill hole and don't stop adding it until the fluid starts pouring out of that hole then it is full.
Cleancoupe is offline   Reply With Quote
Old 06-25-2019, 01:10 PM   #179
kms0567
Drives: 2018 Camaro ZL1 Auto
So, Since I bought used 2018 ZL1, with 1000 miles on it, I just changed the oil last night.
And for 1500 miles, I need to do an oil change and diff fluid?
kms0567 is offline   Reply With Quote
Old 06-26-2019, 10:01 AM   #180
Can'tHave2MuchHP
Drives: Fast
I suppose you could wait until 2000 miles to be roughly the same interval. It's more important that you get it changed than worrying about which odometer mark. But to answer your question, yes.
Old 06-26-2019, 02:03 PM   #181
kms0567
And 0w40 mobil 1 ESP is one to use for the motor oil?
Old 06-26-2019, 02:10 PM   #182
Can'tHave2MuchHP
Drives: Fast
Yes. All part numbers in the original post for everything.
