Old 08-25-2018, 03:32 PM   #169
chutoyy
knows nothing...
Drives: 2SS 1LE
A single 50w 3 Ohm resistor on each side will solve the hyper flash issue if you have LEDs front and rear. A 50w 6 Ohm resistor should work if you have the OEM LED tail lights and change just the front blinker to LED.
I use a 50W3rj on my car (the gold thing on bottom left)
https://i.imgur.com/3t14HJ2.gifv
'18 6MT 2SS 1LE G7Q
chutoyy is offline   Reply With Quote
Old 08-25-2018, 08:36 PM   #170
ecko04
Drives: Too many to list
New rear tail lights
I’ve gone the 50w 6Ohm resistor route, they do not do the trick for the tail lights.
I have LED bulbs with resistors built-in for the front.
I’ll give your 3Ohm solution a try.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 08-26-2018, 07:18 PM   #171
ecko04
No go on the 3Ohm solution.
I replaced the built-in resistor turn signals with regular LED 7440 bulbs. Wired in a 3Ohm 50watt resistor and reinstalled one of the lamps, hyperflash continued.
I’ll give it another go with some other combinations later this week.
Old 09-01-2018, 03:56 AM   #172
chutoyy
knows nothing...
Drives: 2SS 1LE
VLand is shipping out correct harnesses to those that ordered lights directly from them. They're "integrated" into a swappable harness with a 50w 7.5Ohm resistor. ETA is about two weeks.
'18 6MT 2SS 1LE G7Q
Old 09-01-2018, 06:59 AM   #173
ecko04
The original harness is also swappable. The 50 watt 7.5 ohm resistor addresses the backup light remaining on, similar to the Gen5DIY harness, I tested this for them. To address the hyper flashing, they supposedly changed the sequence of wiring. I’ll have my hands on the harness sometime this week as mine shipped on August 25th.
Old 09-02-2018, 05:10 PM   #174
sonikk71
sonikk71's Avatar
Drives: 2017 Summit White V6 1LE
According to one reviewer on alibabba the new harness works.
https://www.alibaba.com/product-deta...765590210.html
sonikk71 is offline   Reply With Quote
Old 09-03-2018, 08:22 AM   #175
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
So are these light good to go yet? I mean if they claim to be for the RS/SS/ZL1 and why the hyper flash issue.
warren3537 is offline   Reply With Quote
Old 09-03-2018, 08:34 AM   #176
ecko04
Supposedly. I can’t personally attest to it until I have the harness and I personally test it. I’ll also try with LED front turn signals to see if they hyperblink (which they shouldn’t if they’re on the same circuit).
From the picture they sent me of the harness, the resistor being used is a wirewound resistor that’s exposed (which means it’ll get very hot to the touch...nearly 230 degrees) during normal operation. I plan to wrap it in a fiberglass heat sheath similar to the Gen5DIY harnesses.
Old 09-03-2018, 11:01 AM   #177
sonikk71
sonikk71's Avatar
230 degrees! Yikes! Does the Vland harness not have anything to shield the heat? That makes me rather uneasy about using their product. Can you post the pic of it?
Old 09-03-2018, 11:12 AM   #178
ecko04
That’s pretty typical of resistors. They make heat...that’s how they work. Wirewound resistors should be mounted directly to metal to help dissipate heat.
Old 09-03-2018, 11:24 AM   #179
sonikk71
sonikk71's Avatar
Oh yeah I am familiar with how resistors work. I was more commenting on the fact that it sounded like they didn't seem to be concerned as evidenced by their lack of heat shielding. Looking at the Gen5DIY harness they wrapped their harness...
Old 09-03-2018, 11:49 AM   #180
ecko04
Very few companies wrap them because they’re designed to be mounted to metal. Typically where they go, there’s metal nearby alleviating the necessity to wrap. Wrapping them just allows more flexibility with mounting and probably adds a few dollars to the cost of manufacturing.
Old 09-04-2018, 12:18 PM   #181
warren3537
warren3537's Avatar
So the burning question is, will the new tail lights work on an RS/SS/ZL1? I like they way they look.
Old 09-04-2018, 02:39 PM   #182
ecko04
I already replied to you. See reply from 9/3
