Old 07-09-2017, 07:15 PM   #169
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Thanks for the fender pic.
Are those 295/680?
seanblurr is offline   Reply With Quote
Old 07-10-2017, 01:45 AM   #170
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
You're welcome. Tires are 295/680/19 and 305/690/19. I will most likely get custom 18" CCWs as there are a lot more selection on 18" sizes
glamcem is offline   Reply With Quote
Old 07-11-2017, 07:04 PM   #171
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Originally Posted by glamcem View Post
slicks and the spare set of rear tires (NT01-325/30/19) arrived. Pirelli DH slicks mounted on the new wheels
These Michelin tire bags are great They do a good job covering the wheel lips for eliminating scratches ..etc
where do the sell the michellin ones?!
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 07-13-2017, 11:58 AM   #172
glamcem
glamcem's Avatar
This is where I got them from :
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 07-16-2017, 03:59 PM   #173
hzycamaro
hzycamaro's Avatar
Hi, thanks for your help! I've got the wheels and tires. In the end I got 19x10.5 and 19x11 wheels. For tires, there is no 305 available immediately so I went 295/30/r19 Toyo R888R all around. I did put 5mm spacers in the front to avoid rubbing. I haven't adjusted the camber yet but I feel I probably have to go with 7mm spacers to achieve the negative camber I want. I plan to take it to drag strip first to see how much more traction new tires have compared with stock tires.
hzycamaro is offline   Reply With Quote
Old 07-16-2017, 04:02 PM   #174
hzycamaro
hzycamaro's Avatar
Do you have your track tires on all the time? Previously I thought I can always switch between track wheels & tires with stock wheels & tires. But I just realized what a trouble it is to change all 4 wheels and tires.
Old 07-17-2017, 01:55 AM   #175
glamcem
glamcem's Avatar
Yes, I have the NT01s currently but it's not my DD. I drive when it doesn't rain. R888Rs should be even better for rain which may not be a problem in your case, if you live in San Diego
Old 07-17-2017, 04:00 PM   #176
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
JFYI - Doug was able to grind enough on the shock body on my car to only need a 3mm spacer.
He said I could skip the extended bolts, but since I had already ordered them, I used them.
Still got -3.0 degrees too
So it all depends how much you're willing to grind
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 07-17-2017, 04:05 PM   #177
DFW1LE
DFW1LE's Avatar
Have checked these babies out?
https://www.morenomotorsports.com/co...ber-caster-kit
Old 07-17-2017, 04:48 PM   #178
glamcem
glamcem's Avatar
glad it all worked out for you you should come to the ORP next time
Originally Posted by DFW1LE View Post
I just did thanks for sharing. I will most likely go with the ZL1 1LE suspension kit when it becomes available so adding camber should be very easy but this should be a good alternative for those who want to stick to MRCs and don't want to deal with grinding
Old 07-17-2017, 05:40 PM   #179
RideZX6R
RideZX6R's Avatar
Soon!
'12 E93 M3
'25 911 (ordered)
Formers...
Old 07-18-2017, 11:05 PM   #180
Moreno1
Drives: G5.R
Just went through this whole thread. What a nice, clean ride man... must be lots of fun at the track
Moreno1 is offline   Reply With Quote
Old 07-19-2017, 07:09 PM   #181
glamcem
glamcem's Avatar
Soon!
Thanks It's a lot of fun for sure, very predictable and forgiving car to drive at the track
Old 07-27-2017, 05:01 PM   #182
glamcem
glamcem's Avatar
UPDATE: Decided to remove the wicker bill completely
Ordered my ZL1 1LE LED third brake light to match with the dark tail lamps, cannot wait to install them it should arrive soon
