Old 01-16-2020, 09:56 AM   #169
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by OB0001 View Post
just got mine installed sounds awesome! no rattle or drone and no rust stainless steel don't rust
Certain types of Stainless will in fact show surface rust. Flowmaster uses that type of stainless(409). It's not pure stainless...a magnet will stick to the mufflers and pipe but not the tips.
Old 01-16-2020, 11:21 AM   #170
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
it will took mine a while befor it started to rattle.
Old 01-16-2020, 11:44 AM   #171
6spdhyperblue
Drives: 2SS 1LE
Did you guys cut the tabs in your npp actuators per the rattle tsb?
Old 01-16-2020, 11:48 AM   #172
JCunningham
Drives: 2017 2SS M6
? cut what
Old 01-16-2020, 11:54 AM   #173
6spdhyperblue
Drives: 2SS 1LE
If you haven’t done this you might be good to go.
This cleaned up all my rattle, it’s nuts
https://www.camaro6.com/forums/showthread.php?t=556061
Old 01-16-2020, 03:35 PM   #174
KingLT1
KingLT1's Avatar
Oh damn, I am going to try that. Thanks for the heads up!!
Old 01-17-2020, 01:31 PM   #175
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
Tips are 304, rest of Exhaust is 409S
Most modern factory exhaust systems are made from 409 stainless steel. It is strong and will last 8-10 years in a moderate climate. 409 stainless steel will rust on the surface. However, this is not a concern for most people because it is hidden under the vehicle. Surface rust can be cleaned with a wire brush.
304 stainless is the highest quality material used for exhaust parts. It will last 10 years or more in a moderate climate. However, it is the most expensive. It will not rust for many years. But, it will turn a golden brown color after being exposed to heat.
OB0001 is offline   Reply With Quote
Old 01-17-2020, 08:26 PM   #176
KingLT1
KingLT1's Avatar
Yep I agree.
Old 01-23-2020, 02:03 AM   #177
Coded4SS
Drives: 23 Zl1
This post is why I come to the forums.
Coded4SS is offline   Reply With Quote
Old 01-29-2020, 08:22 PM   #178
6spdhyperblue
Drives: 2SS 1LE
U guys have any luck?
Old 01-29-2020, 11:33 PM   #179
KingLT1
KingLT1's Avatar
No not yet...probably won't mess with it till spring when I get the car out of hibernation.
Old 02-05-2020, 03:21 PM   #180
SmurfMaf1a
SmurfMaf1a's Avatar
Drives: 2016 Camaro 1SS M6
I welded my secondary cats back in made it about 20% quieter and got rid of most of the drone. I also pulled the npp fuse and rattle is gone forever. It also sounds better because you dont hear it open and close from when your revving in neutral. I think the flowmaster npp sounds fine without any other mods and is not too loud to make any neighbors angry.
SmurfMaf1a is offline   Reply With Quote
american, axle, dual, flowmaster, npp
