#169 | |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
#170 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
Looks like I haven't updated in awhile.
At the end of last season I made it to the track, only got a few runs in and broke a dss axle, I wasn't pushing it hard. Something to do with the outer passenger cv. At the beginning of this season I went to the track. I only got 1 full run in, 10.2 at something like 140 with a nice soft launch and something like 8psi. The next run I tried to hit it a little harder and the same dss axle broke again. This time the inner cv passenger side. Odd part is it broke 100' out. Still a pretty soft launch, 1.56 60'. dss is fixing the axle and upgrading both axles to "their best" cv's. Not sure why I didn't have their best all ready. They rate these things pretty high hp wise and I was no where near that number and it was a nice smooth launch. Keep in mind our local track is flooded and it is an all day affair for me to go to the track and a fair amount of money in fuel. After getting some gforce axles I made it to the track again just 2 weeks ago. NOTHING BROKE!! I only ran 1/8ths to stay out of trouble other than one 1/4 mile blast on the way out the door. I was able to add power every run and tweak the tune slightly and the car was picking up speed nicely. The speed based dome boost control works great. The linelock works great for getting however much of a burn out as you want. The 2 step works amazing for picking the rpm/boost I want to launch with. The car went strait and smooth every run. Best 60' was a 1.44 on a 5.94@122mph run. The last run I tried hitting it a little harder off the line and spun slightly and that is my 1/4 mile slip from above. My next project is to work on my 60' some and once I get that down then maybe add another 100hp or so and see where that puts me. My short term plans are some drag shocks, a drag alignment(0 camber when squatting) and some 275 pro drag radials. I am shifting around 7200, I hope to get to the dyno so I can see how high it likes to rev and may end up shifting higher. I am not locking the converter at all. I think I will at least try and figure out how to lock it in high gear. that should be good for something.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#171 |
here is some data i collected.
#172 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Jul 2017
Late to the party - But WOW!!
Awesome build - Congratulations!! |
#173 |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
update?
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
#174 |
I am always fiddling with the car but no major changes. I did redo the exhaust since the cut outs don’t seem to hold up.
A month or so ago I went to the track and had a charging issue before I was able to turn it up. Going to try again Friday. Been busy with work, family, rzr’s. I plan on doing a monster air to water intake set up over the winter with an interchiller set up.
#175 |
Looks good and wondered where you've been.
#176 |
https://www.camaro6.com/forums/showthread.php?t=561473
Thinking about upgrading if anyone wants to buy my current kit.
#177 |
Moderator
Any update for 2020?
#178 |
I dropped an exhaust valve last year and just let the car sit after that. It scored up the cylinder and took out 1 piston and a turbo. Just about a month ago I started messing with the car again.
I have been all over the place with what I want to do for a motor. It seems like shops are really busy too. Because I can’t decide just yet I went ahead and got a junkyard 5.3 to toss in there so I can sort out some of my other projects. 100% stock 5.3. Upgrading turbskis to 6766’s with the stainless 1.05ar t3 exhaust housings. Got my intercooler tank mounted and lines ran to the front. Modified the intake so the fluid lines stay under the hood. Plans are running a 2nd wideband for added safety. Clean everything up, try and make the under hood look amazing.
#179 |
hell yeah, welcome back boss
#180 |
Junkyard LS or L83?
#181 |
L83.
I am considering just building a 5.3 and hitting it with lots of boost. I think I could use the forged lt crank, I think the rods I had in my motor would work(curillo drop in). buy some pistons and some main studs. My cam, head studs and valve springs would probably all be good. Toss some quality valves in there. Buy some high end lifters. Then give it 35psi Or maybe just order a darton sleeve 427 from tsp.
#182 |
All this was $1495 including core. 2017 with 90k on it.
