Old 07-19-2016, 06:55 PM   #169
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
What does the new box fitment look like against the hood liner? Because your last box size butted up against the SS vent opening in hood. And could you show us a comparison from your first box opening to the new like you did the stock opening versus your first? Thanks
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 07-19-2016, 07:27 PM   #170
tbis
tbis's Avatar
Drives: 2016 1SS Summit White
Is the sound tube delete an option or come with the whole package?
[SIZE="100"]
tbis is offline   Reply With Quote
Old 07-19-2016, 07:30 PM   #171
Hyper1SS
Hyper1SS's Avatar
Looks like they have not done the sound tube delete yet. Probably still working on tooling.
Order ID: TDHQMS
Old 07-20-2016, 10:10 AM   #172
Roto-fab 1
Roto-fab 1's Avatar
Our air box still runs along the hood vent opening and the inlet is still the same. We increased the air box size by extending the air box toward the drivers side fender, this allowed us to run a larger filter than before which will be benefit those of you adding more power mods.
The sound tube delete kit is an option, we have the tooling finalized and now we need to texture the mold before we post pics.
Old 07-20-2016, 10:23 AM   #173
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Originally Posted by Roto-fab 1 View Post
We made it back on the dyno with our latest version. This configuration yielded solid gains across the RPM range. Peak gains were 12 HP and 13 ft/lb tq over stock. The big difference here is gains carried from start to finish. Our previous version showed great top end gains but we weren’t satisfied with low and mid-range performance. On the dyno, AFR readings were about .3 rich as compared to most of our data logs, so we are confident the gains stated above are on the conservative side.
It’s important to note that we tested this intake after 500+ miles of driving under various load conditions. As discussed earlier in this thread, these cars are slow to adapt to changes in the MAF configuration. We have tested a competitor’s intake which experiences this exact issue. To date, there is definitely a general lack of independent testing results with the 2016 Camaro CAI systems. Realizing we don’t fall in the “independent testing” category, we will wait and see what others post…it will come out! In the meantime, we may post some comparisons against the competition which can be easily verified or disputed by others...IATs, filter size, etc.
Dyno numbers provide useful information when forming an opinion on a CAI system. However, they only tell part of the story. A CAI should provide IATs (air intake temperatures) as close to ambient as possible. To achieve this, the intake MUST prevent radiator and engine bay heat from entering the filter. Our system does this. If you or one of your friends have a system currently on the market, we strongly encourage you to remove the lid and see for yourself how effectively they have sealed out hot radiator and engine bay air. This is a huge factor if you are staging at the drag strip or simply sitting at a traffic light beside a Dodge Challenger! With an inadequate air box design, intake temps absolutely skyrocket when not moving. The IAT’s will come down during higher speeds, but not quick enough. You will already be much of the way through that ¼ mile or looking at the tail lights of that Challenger. Maybe not the latter, but this is a very important aspect of an air intake system since much of your performance driving may directly follow an idle period. We will be posting a detailed comparison of this with the Roto-fab CAI and a couple of our competitor’s systems. It’s a real eye opener! We will wait a couple weeks to post this pending some changes to our air box design. The changes don’t affect the sealing of our air box; however, we wouldn’t consider it as credible to post such a comparison using a pre-production air box. This takes us to the next topic….
We have decided to increase the air box size which not only increases air box volume, but allows us to use a filter which is 2” longer than the one we tested with. It was a very tough decision to re-tool a product which is complete and performing well, but we feel it’s best for the long term. We may gain a little more on stock cars, but certainly will increase performance tremendously on modified cars. As many of you know, a large portion of our business comes from tuners and speed shops who do their own testing and aren’t caught up in marketing hype. We’ve already received feedback on the currently available 2016 CAI systems from multiple tuners and we think this change will separate us from them by even more.
We already have over 7 months of R&D invested in this project. Therefore, we’ve decided a couple more weeks added to our target release date to make this change is time well spent. We don’t normally like to post target release dates, but our goal is to have this wrapped up and in production this month. The production version will be the system with the configuration as tested above along with the air box and filter size increases.
Thank you Jordan and the team at JDP Motorsports for your time and efforts!
We can't WAIT for the production parts!!!! It is awesome to work with someone that is as OCD as I am and this system will be worth the wait!! It was great having you guys at the shop and we appreciate the support!!
Kind regards,
Jordan Priestley
801-545-4215
JDP Motorsports is offline   Reply With Quote
Old 07-23-2016, 01:00 AM   #174
archer1965
archer1965's Avatar
Dudes, I've been calling and emailing you guys almost every week the past month. GET R DONE!
Please call me when you're ready to ship. A couple people there have my number.
Thanks,
Chad N.
Lake Stevens, Wa.
2SS Nightfall Grey / Black Rally Stripes / Sunroof
NPP / MRC /1LE Suspension / Nav / M6/ Xpel'd / CAI
archer1965 is offline   Reply With Quote
Old 07-23-2016, 11:25 AM   #175
enzia35
Drives: '16 Garnet Red 1SS
How would that K&N filter hold up in dusty conditions like Lubbock?
'16 Camaro 1SS
'18 Miata GT
Old 07-24-2016, 01:27 AM   #176
Phidelt59
Phidelt59's Avatar
Drives: 2016 Camaro SS
Take my money
Camaro 2SS
Hyper Blue Metallic/Kalahari
6M, NPP, MRC, NAV
Black 5 Spoke
Phidelt59 is offline   Reply With Quote
Old 07-24-2016, 01:15 PM   #177
tbis
tbis's Avatar
Carbon fiber finish like the 5th gen would be cool hope it's available from day 1 of the release
[SIZE="100"]
Old 07-24-2016, 02:00 PM   #178
ponchss
ponchss's Avatar
Drives: 2016 Camaro 2SS, 2006 corvette
I have had multiple cars with K&N filters and I live in the El Paso, TX area (windy as hell). They hold up good but just have to clean them out more often due to the dust/sand.
ponchss is offline   Reply With Quote
Old 07-24-2016, 06:13 PM   #179
2006Moy
Drives: 2016 SS Convertible Hyper Blue
2006Moy is offline   Reply With Quote
Old 07-25-2016, 01:11 PM   #180
archer1965
archer1965's Avatar
wanting to give you money
Old 07-25-2016, 10:01 PM   #181
Picks
Drives: 2016 Camaro 1SS
All I want to know is when the hell can I buy it. I feel like an inmate waiting to be released from prison after a 20 year stint. You guys should get started on the gen 7 now so it's available the day it's released.
Picks is offline   Reply With Quote
Old 07-25-2016, 10:35 PM   #182
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
