Old 05-01-2018, 07:56 PM   #169
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Originally Posted by cwoodard91 View Post
Hey this fix does work. Hasn’t failed on me one time since I’ve unlocked the car before doing the remote start. Thanks
Glad to hear that that it helped! 👍🏽
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 05-04-2018, 07:11 AM   #170
bucknut2006
Drives: 2017 ZL1 A10, 2015 C7 Z51
Mine started doing this recently as well.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
bucknut2006 is offline   Reply With Quote
Old 07-14-2018, 09:54 AM   #171
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Subscribed.
Encountered the same issue - so far identified it only in the HVAC Pop-Up lower band of the screen.
Looking forward to seeing how this story develops.
Seems to me as a Firmware / Software related bug. Changing the Hardware (Tuner module / Radio) does not seem to be the remedy.
Especially it being an intermittent occurrence and continuing to those who had their hardware replaced at the dealer's.
Old 07-23-2018, 09:45 PM   #172
SpazmXylam
Because Racecar!
SpazmXylam's Avatar
Drives: 17 SS 1LE
Add my 17 SS 1LE to this list.
leaving a track day on the weekend the event organizers ask everybody to leave "calmly" so the near by residential area doesn't complain. I ended up crawling into traffic nice and easy like because the car was stuck in loud mode.
Thought I was nuts before when I couldn't find it and simply glossed over it. Just wanting to play with the new tech I gave a huff and moved on. Finally convinced something was not right when I couldn't find it and actually had a reason to use it.
SpazmXylam is offline   Reply With Quote
Old 10-07-2018, 08:37 PM   #173
Snowbird12
Snowbird12's Avatar
Drives: 2017 2 SS vert
Add mine to 17 2SS 8 A
Snowbird12 is offline   Reply With Quote
Old 10-23-2018, 10:47 AM   #174
Spectre130
Spectre130's Avatar
I bought a used 2016 2ss Auto, NPP. I have only had the car for 2 weeks and this has happened three times. I am stuck in stealth! (not cool). this latest time, I did not remote start but my son did open the pax door and sit down before I opened the drivers door. I shut down and restarted several times but the option has not returned.
Spectre130 is offline   Reply With Quote
Old 10-25-2018, 04:03 PM   #175
L78toLT1
L78toLT1's Avatar
Originally Posted by PnCRedJwl2SS View Post
I believe this is true as well…that it only happens when you remote-start the car. I was experiencing the problem intermittently. It wasn’t really a problem for me as I don’t switch modes very often and have Fuse #51 pulled.
But I was curious, so I decided to test a theory. I was thinking the issue was happening because of timing. More specifically, I was thinking that if I remote-started the car before the car was fully awake, it might cause a miss of some of the startup sequence steps and therefore not display the driving mode menu and other associated menus that seem to be missing when this happens.
So, I started following a regular ritual Every time I remote-started my car for the last three weeks. Rather than just hitting the lock button and then hitting the remote start, I would fully unlock the car by hitting the unlock button twice, then I would lock the car with the lock button, then remote start. I ran this test for a good 3 weeks, with flawless results. I have not lost the driving mode once, nor any of the temp settings etc. in that time.
It’s working for me, hope it works for some of you! It’s not a fix, but it really helps avoid an annoying problem consistently.
I know the remote start is not the only culprit. I'm an M6 and it happened to me. Only happened once in 2 years. Cleared up when I cycled the key so I guess I can't really complain
Baby Blue
Old 10-25-2018, 05:23 PM   #176
gmw0181
gmw0181's Avatar
Drives: 2017 Camaro 2SS A8
Mine does it when I use remote start. Also, when you change fan speed or turn on or off AC the screen at the bottom is blank.
Only when started with remote so far.
gmw0181 is offline   Reply With Quote
Old 10-28-2018, 08:52 AM   #177
PnCRedJwl2SS
Howdy! Pete here...
If you are going to use Remote Start, just click the unlock button first. Then lock button, then Remote Start. Problem should not recur when following this sequence. Works 100% of the time and is a habit for me now...I don't even think about it anymore.
Good luck!
PnCRedJwl2SS
Ordered from GM
Old 12-06-2018, 01:53 PM   #178
shoe5163
Drives: 2017 50th Anniversary SS
2 Key FOBS
I have noticed a difference with the 2 key FOBS.
Key FOB 1:if I use it to start the car, driving mode will be there.
Key FOB 2:if I start the car with it, driving mode isn't there.
Like 2 is locked out of some features. Probably intentional---
shoe5163 is offline   Reply With Quote
Old 02-28-2019, 01:02 PM   #179
Spectre130
Spectre130's Avatar
My engine management button continues to go missing from the infotainment system usually when the passenger door is opened before the drivers (when car is unlocked) or when I do a remote start. This was happening before I was having other problems with the infotainment screen that the dealer replaced. Could it be a bad HMI module? They only replaced the screen itself before.
2016 2SS A8 NPP
Old 04-19-2019, 09:37 PM   #180
SavageSS
SavageSS's Avatar
Drives: 2016 Camaro SS
Any update on a recall or factory TSB? Is this covered under warranty? My 2016 2SS M6 loses the "driving mode" options every once in a while which is very frustrating. No remote start since its a manual, not sure why. shutting the car off until the head unit goes to sleep and restarting seems to work. thanks
2016 Black M6 2SS - NPP, MRC
MRR M017 1LE Replicas, Rotofab CAI
ARH 1 7/8 LTs w/ cats
Pray ported MSD Atomic AirForce Intake Manifold + TB
BMR upper/lower trailing arms and upper control arms
Pray Tuned + E85 (490WHP)
SavageSS is offline   Reply With Quote
Old 06-08-2019, 01:26 AM   #181
Blu'maro
Drives: 2017 SS
I have had this happen to me recently with the exhaust stuck in quiet mode(6MT). A day later the menu popped back up, ok cool.
I can hear the car idle is louder but now the cracks and pops are not there and if they are at about 30mph they are very feint. Anyone else experience this too?
Blu'maro is offline   Reply With Quote
Old 06-15-2019, 12:01 PM   #182
YellowLT1SS
Drives: 2016 camaro SS
Lmfso I totally thought I must have taken drugs when mine disappeared. The tach Bounces Around but it doesn’t bother me much
YellowLT1SS is offline   Reply With Quote
