03-10-2020, 06:55 PM | #169 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Wheels: Apex ARC 8
19x10 ET20 Front 19x11 ET43 Rear Tire Size: 285/35 Front & 325/30 Rear Stock Suspension with MRC Stock Camber Concave: Deep
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- Last edited by Blackmonba6Gen; 03-31-2020 at 07:40 AM. |
03-10-2020, 09:37 PM | #170 |
Looks brutal, efficient and ready to pounce
03-11-2020, 06:49 AM | #171 |
BLUPRINT_1LE
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
03-11-2020, 07:23 AM | #172 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
Vordoven Forme 9 (Cheap knockoffs of something)
19x10.5 et22 BFG Rival S 1.5 305/30-19 They are only used for autox, so I wasn't too concerned about them being knockoffs. Car is otherwise stock, there is zero rubbing, and it looks awesome sitting on grid. I"m still waiting for someone to shoot some action shots of it. |
03-25-2020, 04:43 PM | #173 |
Drives: 2020 LT1 Join Date: Dec 2019
Verde Axis
19x10 +36 19x9 +32 Powdercoated satin poly gold Kumho Ecsta PS91 285/40 255/45 AFE springs |
04-18-2020, 08:40 PM | #174 | |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
05-19-2020, 09:37 PM | #175 |
Drives: 2016 2SS Glacier White Convertible Join Date: Jul 2016
AR blockhead 20x9 Et 20 275/35r20 front. 20x10.5 et40 with 5mm spacer 305/35r20 rear. Eibach pro lowering 1.1”
16 2SS SUMMIT WHITE / NPP / MRC / 6MT / CONVERTIBLE / TINT / SPLITTER / SPLASH GUARDS / WHITE KNEE PADS / WINDSCREEN / BLACK BOW TIES / HASH TAGS / DIODE DYNAMICS / GM SMOKED TAILS / MORIMOTO / ALPINE / HERTZ / BLENTMOUNT
05-24-2020, 10:23 AM | #176 |
Switched up to these Bremmer Kraft BR14 19x9.5 +43 with 7/32 spacers. Tires are the same 255/45 285/40. The gold ones above will be posted for sale.
05-25-2020, 01:23 PM | #177 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
https://www.camaro6.com/forums/showt...=515659&page=6
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
05-27-2020, 08:42 PM | #178 | |
Drives: 2024 2SS Camaro Nitro Yellow Met. Join Date: May 2020
Offset plays a huge part in picking the correct large tire size, so choose wisely, depends if you want your tires sitting in deep or flush with the outer wheel lip. Not sure if you have gotten your answer, since you posted this last year, I would never go more than 1, maybe 2 sizes larger tire on stock 9.5" rim, as 305/30/20 would be too large for that rim, would need to with 10.5" rim, 315 size is definitely out of the question, you'll need an 11" for that. To better help you, I have 1 2019 2SS , I just installed MRR M017 20x10 +23 w/ Cosmo Mucho Macho 275/35/20 Front, fit perfect, wheel sits flush with outer wheel lip, 20x11 MRR M017 +43 w/ Cosmo Mucho Macho 315/35/20 Rear, after I mounted the rears, I immediately checked for fitment on the backside to make sure thee was no rubbing scraping of any sort, I was very happy to see there was none!!, make sure to move your harness in the left rear wheel well as there is a chance the larger tire will rub through the liner and damage the harness. After i checked the rears, the fit was nice, but the tires sat just a tiny bit in too far, didn't match the fronts, so I took the wheels off and installed a 5 MM wheel spacer (3/16"), and it moved the wheels out perfectly flush with the outer lip, while still keeping the tires in the wheel well. Now people are going to say, do not install spacers, as it will shorten the amount of threads your lug nuts thread onto, it will, but not so much that it will not tighten fully down, I got 9 full turns starting the lugs by hand, before torquing them with my impact gun, plenty of thread. As for wheel spacer size, depending on what size wheel and the offset they have, you may not need one, my rears 20x11 +43 sat great, I didn't need a spacer, the only reason i added them, was to make the rear tires sit exactly like the fronts, If you do decide to go with spacers, I would go no bigger than 5MM (3/16") and no smaller than 3MM OR 4MM if you can find a 4MM, Good Luck. |
06-05-2020, 12:00 PM | #179 |
Drives: 2016 ss vert hot red, mrc, npp, Join Date: Mar 2016
Hey guys I have a 2016 ss convertible
I'm looking to buy new rims and tires will these fit Front 9.5x20 5x115. Rear 10 5x20 5x115. Tires 2 rear available. 305 30 20. Thanks all
2016 ss vert, mrc, npp, red hot exterior, adrenalin red interior, black top, black bowties, automatic transmission, black rims.
06-05-2020, 12:37 PM | #180 |
BLUPRINT_1LE
Try posting this in the marketplace(Member's Classified section).. You will have a better chance than this post. This post is really to share different tire sizes and fitments on various 6GEN's if any interested in mimicking the same thing.
06-05-2020, 01:01 PM | #181 |
Drives: 2013 C6Z06 Join Date: Nov 2016
07-03-2020, 09:35 PM | #182 |
Drives: 2016 Camaro LT V6 A8 Join Date: Jan 2019
Tire size
Will a 285/40/20 with a 20x10 and a +20 offset, and a 315/35/20 with a 20x11 and a +40 offset fit our cars? i have been told conflicting stories if the fronts are too tall or not.
