#169 | |
![]() Drives: 2016 SS Join Date: Jan 2013
#170 |
They should both be considered the same, if your replace the stock converter with an aftermarket converter or you replace the stock clutch with an aftermarket clutch assy, then neither are stock and would have to be considered the same mod. It doesn't matter if its a wear item or not. Unless you put the same clutch in from the manufacturer its still an considered after market and not stock just like the converter. Neither should be considered internal, they should be considered aftermarket and not stock they are just links from the flywheel to the transmission.
#171 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
#172 |
![]() Drives: Camaro 2SS A8 NPP Join Date: May 2015
Back to the topic plz
Sent from my SAMSUNG-SM-G920AZ using Tapatalk
Mosaic Black 2SS A8 NPP
12.08@115 MPH |
#173 |
![]() Drives: HyperBlue 2SS 6M NPP MRC Nav Join Date: Dec 2015
Stock M6 with stock tires.
2016 HyperBlue 2SS 6M NPP MRC Nav
#174 |
Hey, we disagree and its still all good. Have a good Memorial weekend.
#175 | |
![]() Drives: Slow Join Date: Mar 2016
If you're talking ease of installation, some people might be able to "bolt on" a procharger quicker than they can drop a trans and swap the converter. Personally, I throw a stall in the same category as a cam...
2016 Toyota 4Runner
2017 Camaro ZL1 |
#176 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
THIS NOT A CHAT THREAD OR BENCH RACE THREAD! KEEP THE IDLE CHAT UP AND I WILL CEASE TO UPDATE IT. ![]() It's up to you Guy's now. Take your pick? Fast List's just updated.
#177 | |
In The Circle
LT's CAI Converter Gears PTB Axels Driveshaft Tune Diff Swap Clutch Exhaust Mod's Line lock 2 step or other electronics UDP Intake Manifold Race Fuel or E85 Tune NO CAM OR HEAD SWAP! Like it or not, fair or not that's the way it is on Camaro 5 and 6 Fast List's and the rules will not be changing anytime soon. ![]()
#178 |
![]() Drives: 2016 1SS 6speed Join Date: Mar 2016
Tires used on the pass: Hoosier D06 28x10-17
Performance Mods (if any): tires only Category submitted for: #3 bolt ons only no internal Mods R/T............ .358 60'............. 1.860 330'........... N/A 660'........... 7.811 660’ mph.... 92.08 1000'.......... 10.105 1320'.......... 12.042 1320’ mph…. 116.06 Name of the track: Byron Dragway, Byron, IL Date of pass: 5/15/16 Weather conditions: Sunny and clear. Slight crosswind.
#179 |
![]() ![]() ![]() ![]() Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
How much boost are you running with your heartbeat blower?
#180 |
In The Circle
This is not a dissscusion thread, try a PM to member.
#181 |
![]() Drives: 2020 Elkhart Lake Blue 1LT Z51 C8 Join Date: May 2009
Tires used on the pass: Stock
Performance Mods (if any): None Category submitted for: Bone stock A8 R/T .250 60' 1.826 330' 5.235 660' 7.997 660’ mph 89.30 1000' 10.359 1320' 12.352 1320’ mph 112.59 Name of the track:Byron Dragway, Byron IL Date of pass:5/30/16 DA was 2575, hot 84 degrees. Rear tires were at 21psi
Ordered-Hyper Blue 1SS, A8, NPP, 56W wheels Built 1/20/16
Delivered 2/12/16!! Sold 9/17/19 :( 2020 C8 ordered!! "The greatest sound in the world is a Rolls Royce Merlin over 100 inches" www.timadamsphotography.com |
#182 | |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
