Old 02-10-2019, 01:03 PM   #1737
laynlo15
Drives: 2022 Lt1 A10
Believe me I've been waiting on a 2650 and I work for Magnuson. I'm starting out next month with my little 2300 and hope to finally break into the 9's, shooting for 9.60s, maybe some 50's if air is good and I don't break something first. I replacec the driveshaft with a Gforce and will probably go ahead and do the axle also, then my weakest link will be the tranny. Your car is really killing it, the weight hurts for sure. Mine will be 80 lbs over because the of the 6 pt cage. What class were you running that you had to add weight? We have a long waiting list right now and guess what, I'm not on it. Our customers will get the 2650 first and maybe I'll be able to get one before the Camaro Fest. We just have some other 2650 LS projects that are coming out first since they car so close to the COPO 2650 they decided to bring that one out first.
Old 02-10-2019, 01:15 PM   #1738
Merc
In The Circle
Merc's Avatar
A supercharger swap isn’t a bolt on
Great pass
Edit... nvm I guess it is for a zl1. A sc isn’t considered bolt on for an SS. Interesting.
I have already added another member to the Bolt List ZL1 who swapped the blower out. Now we have a second to do that. I certianly don't want another list to accommodate a blower change, but on the other hand not so sure if it's fair in the long run. Working on updating list's till I ran across this issue again.
Old 02-10-2019, 06:41 PM   #1739
dadszl1
@dadszl1
dadszl1's Avatar
Drives: 18 ZL1 A10
People been swapping intakes for decades and calling it a bolt on.
2018 ZL1 Summit White, A10.
9.48 @ 147 1.35 60' Rotofab, 103TB, Whipple 2.9, Texas Speed 2" Headers, Meth Kit, Ice Box, 17" Front Conversion, Carlyle 15" Rear Conversion.
dadszl1 is offline   Reply With Quote
Old 02-10-2019, 08:58 PM   #1740
Merc
In The Circle
Merc's Avatar
In this case it's a blower change, not a intake change which is consistent with other rulings?
Old 02-10-2019, 09:08 PM   #1741
Snowblind
Snowblind's Avatar
Just a heads up Merc that my E.T. and mph are incorrect, thanks.
Old 02-10-2019, 09:11 PM   #1742
Merc
In The Circle
Merc's Avatar
My plan is to add all to that list that with a (*) to indicate a blower change.
Old 02-10-2019, 09:16 PM   #1743
Merc
In The Circle
Merc's Avatar
Old 02-10-2019, 10:51 PM   #1744
dadszl1
@dadszl1
dadszl1's Avatar
Drives: 18 ZL1 A10
We need to stop reinventing the wheel. If it bolts on the exterior of the engine it’s a “bolt on”
Heads/cam is where you draw that line.
Old 02-11-2019, 05:27 AM   #1745
ULTRAZLS1
ULTRAZLS1's Avatar
A power adder/forced induction has never been considered a bolt on. Just like nitrous. The only place that re invented anything was here.
Old 02-11-2019, 07:15 AM   #1746
dadszl1
@dadszl1
dadszl1's Avatar
Drives: 18 ZL1 A10
I didn’t add a power adder. Car has a PD blower from the factory.
Old 02-11-2019, 08:16 AM   #1747
ULTRAZLS1
ULTRAZLS1's Avatar
Lol ok
You do you. Nice times
Old 02-11-2019, 08:29 AM   #1748
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Blower swap isn't a standard bolt-on and not even close far as comparing swapping a IM. Does it bolt to the exterior of the engine yes, but swapping one out to a larger unit is effectively increasing the displacement of the engine. So it needs to be mentioned in the list or categorized differently then those cars still working with the stock LT4 1.7.
Old 02-11-2019, 09:28 AM   #1749
dadszl1
@dadszl1
dadszl1's Avatar
Drives: 18 ZL1 A10
Well you guys can categorize it however you want. I’m still on the stock engine.
Old 02-11-2019, 09:53 AM   #1750
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Sounds like the * is a mighty fine option to just let those looking know
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
