#1723 | |
![]() ![]() Drives: 2010 Hyundai Genesis Coupe 2.0T Join Date: Dec 2008
#1724 |
![]() Drives: ex-500hp v6 mustang Join Date: Oct 2008
it shows up but it doesnt say anything about power levels.
#1725 |
#1726 | |
per the sae site, "this power certification process is mandatory for those advertising power ratings as "Certified to SAE J1349". " i cant see anywhere that ford has the 5.0 dohc as "412hp certified to sae j1349" |
#1727 | |
I'd certainly imagine it's correct. |
#1728 |
![]() Drives: f150 Join Date: Jan 2010
the gears the car is tested on wont affect it much.
the problem here is the dynojet, it gives higher number's. i see the 2010 camaro return 380 to 390hp in this type of dyno. a proper mustang dyno(the brand) should return accurate numbers. but theres no doubt, the engine does make 412+hp. it seems we have a WAR at our hands |
#1729 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Luminadead/01 Dakota/97 F150 4x4 Join Date: Jul 2009
Seriously they do the certification on one motor, not everyone produced, there are going to be variances anyways, while I doubt 395 they could very well have gotten one of the stronger motors off the line, I seriously still doubt 395 RWHP, but still.
#1730 |
Oh, and really who cares, you can dyno the car 50 times on 50 different dynos, that is going to tell you nothing, we need a tst as the acceleration times and MPH in the 1/4 mile will tell the true tale.
#1731 |
![]() Drives: 2006 Mustang GT Join Date: Jan 2010
every mustang ive ever seen on the dyno including mine was done in 4th just like every camaro ive seen on the dyno was done in 5th...the new 5.0 will put down around 360 on the avg the vid was just on the high end
#1732 |
aaahhhhh i forgot it is a 6 speed so yeah they screwed up it will be 360ish like i said
#1733 |
![]() Drives: 1968 Camaro, 2002 Subaru WRX Join Date: Oct 2009
As has already been indicated by a couple people in this thread, dynoing a car in a lower (ie a "shorter" gear) does not make a Dynojet read higher. In the same way that "shortening" your differential ratio will not show a positive effect on a dyno, neither will your transmission ratio.
The reason cars are typically run in the 1:1 transmission ratio is that inertial effects of accelerating the engine/flywheel/etc are minimized. A dyno sweep of 2000-7000rpm change over 2 seconds (ie a short gear ratio) takes a lot more power to accelerate the drivetrain than a 2000-7000rpm change over 8 seconds. |
#1734 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Love the one you're with Join Date: Sep 2009
Means nothing until we see one at the track. I don't really buy those numbers in the real world.
#1735 | |
Drives: 2011 Avenger Heat Join Date: Nov 2009
The L99 SS has a curb weight of just over 3900 lbs, puts 320-330 HP to the wheels and has a average 0-60 run of just under 5 seconds and an average 1/4 mile run of 13 flat. The 2011 GT has a curb weight of around 3600 lb, but we'll say 3650 with options. Estimates put the RWHP at around 350 with an automatic transmission. Figure the new GT will run from 0-60 in 4.4-4.5 seconds and run the 1/4 in 12.7-12.9 bone stock. |
#1736 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
With todays production tolerances we are going to see 30+ hp differences between motors? I sure hope ford can do better than that. For your sake. Enjoy it stew. I know its been since 1992 that a ford fan could brag about a GT. Im happy for you. The little pony can finally hold its own
| Thread | Thread Starter | Forum | Replies | Last Post |
| Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Official 2011 Mustang GT info released | nester7929 | General Automotive + Other Cars Discussion | 81 | 12-28-2009 03:13 PM |
