Old 04-23-2013, 02:57 PM   #1709
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
I think anywhere on the hash marks is good.
Old 04-23-2013, 02:58 PM   #1710
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Ok so I need to add some then. Thank you.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
CamaroDreams07 is offline   Reply With Quote
Old 04-23-2013, 03:04 PM   #1711
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Originally Posted by KMPrenger View Post
How hard is it to pull the spark plugs on this car? I've done plenty of spark plug and wire changes on other cars, but this one is a bit different. I think I'd like to take a look at the plugs sometime just cuz.
Thanks for viewing my rambling. This is a "lounge" so I'm talking!
VERY Easy. When my MAF sensor went out on my way back from RX, Tracy thought it might be my plugs. So when my car died in Tallahassee I was forced to check the plugs. I bought a basic ratchet and extensions and did them all in a Pep Boys Parking lot. Oh and prior to that I had never touched spark plugs. Since then I've changed my plugs and the gaping a few times.
I try and keep it at the top hash, since these engines eat oil.
BaylorCamaro is offline   Reply With Quote
Old 04-23-2013, 04:00 PM   #1712
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
Guys I just figured out how I could get a turbo by next month.
I just need every one of you to lend me a couple hundred or maybe a couple grand or so. I promise I will pay you back in 10 or less years. Sounds good to me.
Thanks guys
nikos30 is offline   Reply With Quote
Old 04-23-2013, 04:03 PM   #1713
nikos30
HT5 EastSide
nikos30's Avatar
Originally Posted by lscamaro View Post
Have you thought about seafoaming your engine? Also, what intake do you have?
the stupid g5cr intake. I didnt know about this forum when I bought it... I think somebody proved that it actually makes the car slower when its hot compared to the stock one...lmao Im an idiot!
Old 04-23-2013, 05:53 PM   #1714
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yea, I'd definitely look into swapping it out
It never ends huh?
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 04-24-2013, 09:50 AM   #1715
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Looks like my can will arrive friday, so my intake manifold install is a go!
Can anyone help list what I need because one of the threads on the install I had bookmarked is gone...
It has the mace 25mm spacer already installed without a gasket, it looks like it was rtved on. I bought it from usafboy and mace installed the spacer so I think its on there good. Do I reuse the stock gasket on the bottom?
I mainly need to know what tools I need though, something about a 13mm swivel wrench?
DarkneSS is offline   Reply With Quote
Old 04-24-2013, 10:10 AM   #1716
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Just dropped off my car to get my NS-1 stripes installed!!! Woot
Old 04-24-2013, 10:20 AM   #1717
jewel25
Mother of PWA Babies
jewel25's Avatar
Drives: 2011 RJT 2LT/RS
Pretty!!!
jewel25 is offline   Reply With Quote
Old 04-24-2013, 10:25 AM   #1718
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Sweet be sure to post up some pictures when you get it back
Old 04-24-2013, 10:46 AM   #1719
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
Yes, the OEM gasket is re-used. You have to cut off the locating-bosses from the top of it since there is no hole to accept them in the bottom of the spacer.
A wrench like this helps quite a bit for the two rear horizontal bolts:
http://www.lowes.com/pd_338386-25428-85707_4294707917__?productId=3387680&Ntt=ratchetin g+swivel+wrench&pl=1ĪtURL=%3FNtt%3Dratcheting%2Bsw ivel%2Bwrench&facetInfo=
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 04-24-2013, 11:20 AM   #1720
DarkneSS
Oh that looks quite useful, I'll get one today. Do I rtv the gasket to the spacer? Other than thatiI think this install should be cake.
Old 04-24-2013, 11:50 AM   #1721
pgustavson
pgustavson's Avatar
No. The OEM gasket seals just fine by itself. The gasket has two small bosses on the bottom that properly locate it to the block/heads, and to help keep it in place as the manifold is placed on top. Also - I thought I should mention - the rear bolt needs to be inserted in it's hole in the manifold/spacer before the assembly goes in. It's a little awkward, but there's no way to get it in later. You'll see what I mean when you disassemble - you won't be able to pull that bolt out by itself, the cowl is in the way. Your assembly might be a little trickier since you're installing the 1" thick piece. I hear it's kinda tight up by the cowl with that spacer installed.
Old 04-24-2013, 12:36 PM   #1722
lscamaro
lscamaro's Avatar
I have the 1" and yea it'll be a lot tighter in the cowl area. It's extremely beneficial to get the wrench because it allows you to tighten that area up easier after you get everything lined up. Since you already have the insulator rtv'd to the manifold, the install will be a piece of cake to you. The hardest part was getting everything to line up correctly for me. You have the longer bolts right?
It should be easy. Just take out the existing manifold, and replace with the one you have. Piece of cake.
