#17179 | |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
You're sure making it sounds like a tempting upgrade! I do feel like there is a bit of a lag in the throttle, like you said, mainly with manual rev matching. Getting rid of that sounds pretty sweet! |
#17180 |
![]() Drives: '22 Camaro ZL1 1LE A10 Join Date: Jul 2021
Added some strips and changed my center caps from black to red.
#17181 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I had the same problem with the plug. I figured out after I broke the tab that, unlike most GM plugs, you don't slid the tab outward. You're supposed to slide it toward the plug body. Like you said, it seems to hold pretty tight. Glad you got it done. I agree with everything you said about the improved performance. Very pleased.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#17182 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Started taking the wheels off and cleaning/inspecting. Drivers side done. Also ceramic coated the calipers and wheels.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#17183 |
Monterey County Camaros
Installed the JXB Performance Driveshaft Center Support Bearing Carrier. Decided to go with the track bushing for a little more firmness. Easy to do with the right tools and a noticeable feel and sound. Worth it IMO
#17184 | |
L8ap3x
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M |
#17185 |
L8ap3x
I just spent hours/whole day using iron remover by carpro and an apc to clean the rust from the pads off the drums. hosed em down, then applied a ceramic coating (carpro D quartz). Very happy with my application and removal. Did two applications on front and back on all 4 wheels. followed up with arpro reload to give them that extra shine. noticed they were still holding up from last summer so the new carport d quartz is my upgrade from quartz UK 3.0 and dlux. dlux was a pain and I wouldn't recommend it.
#17186 | ||
![]() Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
2023 LT1 M6 Coupe - Black (GBA) on Black (H1T) - Build Date: 8/22
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine - Shane Parker Current mileage: 400 |
#17187 | |
L8ap3x
#17188 |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Have you noticed less vibration and can you feel less play?
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit |
#17189 |
Definitely less play. With the BMR differential bushings and the JXB driveshaft carrier the car feels more responsive, with the pedal having no hesitation and better connected to the rest of the car.
The short drive I did resulted in no increased vibration (the cars so stiff I couldn’t tell if it had), but it did result in a nice “purr.” Not obnoxious or from a potential problem, but rather sound that complements the car. If I can record the sound I’ll post it on my journal thread.
#17190 | |
#17191 | |
Ryan
#17192 |
![]() Drives: LT1 Join Date: Apr 2024
How difficult is the install? Did you have to lower or remove the exhaust?
