Old 10-21-2013, 11:56 PM   #17011
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Originally Posted by kjkjr27 View Post
Pretty sure going 2.5 is the most we can do. I believe if you go 3' it will actually cause some back pressure but I could be wrong.
Nah, that's a myth.
Originally Posted by Trentin24 View Post
Well my LM1 is 3" the "x-pipe" is 2.5". I was thinking about taking stock resonators out, replacing with straight 3" to get some of the loudness back. But maintain that low rumble.
You could try it
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 10-21-2013, 11:58 PM   #17012
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Originally Posted by lscamaro View Post
Nah, that's a myth.
You could try it
I could also try to steal an SS, but more risk than reward sometimes haha.
I just want the V6s to have a good sound. I hate hearing people bash our V6s because they sound like ricers. I hated bashing on my car when it was cold because it sounded like a fart can.
I want people to read what I say and get an honest idea. I love my car to death, but god its just depressing sometimes.
Trentin24 is offline   Reply With Quote
Old 10-22-2013, 12:16 AM   #17013
lscamaro
lscamaro's Avatar
Like I said before, the example is in the exhaust thread so you can hear it.
yea, when my car is cold it sounds tinny but it only takes a few seconds for it to warm up and its fine after that.
Old 10-22-2013, 12:20 AM   #17014
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
No, it takes a while to get rid of that sound with the exhaust I had.
Old 10-22-2013, 12:25 AM   #17015
lscamaro
lscamaro's Avatar
Yea, my exhaust is significantly quieter than yours so my mufflers can tame that sound better. Reason it goes away so fast.
Old 10-22-2013, 12:30 AM   #17016
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Do you have a video??
Here is mine:
You cant tell me at start up it doesn't sound like a V8.
But you can hear that rasp when it hits 4K, then its like that until 7K
Old 10-22-2013, 12:41 AM   #17017
lscamaro
lscamaro's Avatar
Sorry but no that's not what I envision when I think v8. Obviously our v6 will never emulate the v8 sound but that's not what it sounds like to me. Again, sorry.
If I had to pick some exhausts that I think are close they'd be these.
http://www.camaro5.com/forums/showpo...&postcount=505
http://www.camaro5.com/forums/showpo...&postcount=389
These two I think sound "v8ish". But I also think that every v6 camaro sounds terrible when they just rev. I think it's all in the idle and slight acceleration. That's just me though
One of the best exhaust setups I ever heard was a buddy's v6. I forget his exact setup but I know he had long tubes, the res x pipe and either magnaflow or flowmaster I think. In person it sounded great!
Old 10-22-2013, 12:44 AM   #17018
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Well, I was meaning as it is a V6, but that Idle sounds more V8 than V6. Not that if you started a V8 you'd hear my car. V8s with stock exhaust have a better rumble than mine. Im just saying its pretty close.
Old 10-22-2013, 12:48 AM   #17019
Trentin24
Trentin24
Trentin24's Avatar
Drives: 2011 2SS/RS
Ls, just listened to those vids, and I don't hear a V8 like sound except at idle. We all have different opinions. But they both sounded somewhat like my exhaust.
Old 10-22-2013, 06:48 AM   #17020
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Nah, that's a myth.
Where did you hear that?
If you go up to a 3 inch exhaust you could actually lose back pressure (the opposite of what Kevin said) and that can lead to power loss up top and can even lead to misfires at start. If you don't believe you can look it up all the sponsors we "praise" on this site will say the same.
Old 10-22-2013, 07:03 AM   #17021
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I heard that's a myth too. A lot, actually.
Sent from my HTC One using Tapatalk 2
[B]
CamaroDreams07 is offline   Reply With Quote
Old 10-22-2013, 07:14 AM   #17022
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Here's a pretty good read. found it on another car forum.
Back pressure: The myth and why it's wrong.
I. Introduction
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Hondas need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
II. Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
III. Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
IV. So how did this myth come to be?
I often wonder how the myth "Hondas need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
V. So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
VI. Conclusion.
SO it turns out that Hondas don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
Turbo Exhaust Systems:
Some of you asked for a better explanation about restriction in a turbo exhaust, so here 'goes. To sum it all up, on a turbo car, the tighter and more restricted the exhaust housing of the turbo is, the faster you're going to spool your turbo... because the restricted gasses escape through the exhaust housing with more velocity (much like the garden hose description quoted above)... but with this restriction comes the downside. Less exhaust volume will be able to fit through that turbine housing once the turbo is spooled and starts squishing more air through the intake.
This is where the wastegate comes into play. The wastegate is actuated BEFORE the exhaust wheel in the exhaust housing. When it opens, whatever the diameter of your wastegate is gets added to your exhaust piping. Effectively increasing the capacity of the exhaust provided that everything downstream is large enough in diameter to handle it the extra flow. The main reason it does this is to prevent over-spooling the turbo. Once the turbo reaches its efficiency, it doesn't need to flow all the extra gasses through the turbine wheel, so the wastegate allows you to route the exhaust around the turbo... if it can't route enough exhaust around the turbo (restricted wastegate) then too much exhaust gas will be forced by the exhaust wheel and BOOST CREEP will occur as your turbo over-spools.
One way to prevent boost creep is to port the wastegate housing (if you have an internally gated turbo) or to replace the wastegate with a bigger unit. If that still doesn't work, then the problem is likely going to be a restriction in the exhaust downstream from the wastegate. Many overboosted car owners prefer to vent their wastegate dumps to the atmosphere. Not only is it illegal to bypass your catalytic converter, but it's loud as hell, gets your engine bay filthy, and clogs up your K&N like nobody's business; however, it nearly eliminates boost creep. It's a cheap and easy solution that fixes boost creep on a race car.
The best solution to boost creep is to route your wastegate dump past the catalytic converter and back into the exhaust. It will be a custom setup. Nobody makes this. Make it look clean and you'll pass emissions because they don't run your car hard enough to open the wastegate when doing emissions testing. You have to reach full boost for the wastegate to open, and since the exhaust runs through the cat until the wastegate opens, it all gets "cleaned" before it reaches the sniffer. With this setup, the wastegate will also be much quieter because it still runs through the muffler, and you won't trash your engine bay with black caustic funk.
Putting a separate catalytic converter on your wastegate dump is a stupid idea because you'll never get it hot enough to "light off" and start converting the carbon monoxide... so don't get any crazy ideas and create unnecessary exhaust restrictions.
Once compressed air comes into the mix with an engine, exhaust tuning has much less to do with making power. So what if you can milk another 3-5 hp out of a car with a tuned exhaust... the benefits of making an engine sustain an insane final compression ratio (boosted air x compression in the combustion chamber) has much more affect on making power if you can just get rid of the extra gasses it produces. Bigger is almost always better on a turbo setup. The only place where it isn't good is on the exhaust wheel where too big can = no chance of spooling your oversized turbo any time this year.
Old 10-22-2013, 07:26 AM   #17023
X-Factor
Chick Racer
X-Factor's Avatar
Drives: 2017 50th 2SS
Post a video?
So sorry, I don't have one. :(
X-Factor is offline   Reply With Quote
Old 10-22-2013, 07:55 AM   #17024
menendez1293
Well after reading what appears to be a small book on my iPhone I stand corrected.
