#16969 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Added the gen5diy rapid fire third brake light harness today. Bought from the Black Friday sale, previously had this on my 2018.
https://youtu.be/u11Ysp1RhMw?si=HtmsIn7I9rAqBK-h https://www.gen5diy.com/products/16-...-light-harness Sent from my iPhone using Tapatalk Pro
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#16970 |
Drives: Camaro ZL1 Join Date: Oct 2025
#16971 |
![]() Drives: '22 Camaro ZL1 1LE A10 Join Date: Jul 2021
Haha, fairoint but there were. Show started around 1400, pics taken around 2200. Luckily judges came by early when it was still clean, haha
#16972 |
![]() Drives: 2016 Camaro 2SS Join Date: May 2025
Spent the morning pulling the front bumper off, have some cosmetic work I have to do. There's a small crack and deformed bit at the bottom where a tow truck driver didn't care what he was doing and damaged prior to me purchasing the car. Also broke the lower grille. I'm going to repair and respray the broken spots, and replace the grille with the 50th anniversary edition grille in red. Also ordering ground effects for it, but haven't decided which setup to go with. Figure I'll take advantage of the fact that the car is put away for the winter. Any suggestions for anything I should do while I've got the front end off?
2016 Black 2SS purchased in May 2025, 6 Spd.
GM Performance Strut Tower Brace, Mishimoto Oil Catch Can, MRR M017 wheels, powder coated in satin black, Continental Extreme Contact DSW06 285/30R20 in the front and 305/30R20 in the rear. |
#16973 | |
#16974 |
![]() Drives: 2016 Camaro SS Join Date: Oct 2025
Had a pair of resonators welded in today and when they cut part of the stock pipe off they found a big crack in it. Anyone ever seen this?
2016 Camaro SS A8
Borla ATAK Tuned Drag DR77 Wheels |
#16975 |
![]() Drives: 2024 Camaro 2SS Join Date: Aug 2023
Killer looking car. What wheels do you have on there?
2024 2SS - J6H BCD SCJ NPP F55 5VM SB3
#16976 |
#16977 |
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
You're supposed to post a sound clip with any exhaust mod!!
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold |
#16978 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Well done my friend! You have an awesome build for sure!!!
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#16979 |
Powder Coated my water pump and dressed up with some ARP SS 12-points... in preparation for the motor going back in...
#16980 | |
Moderator
#16981 | |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit |
#16982 |
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
I looked at mine under her cover. We had another blizzard yesterday:(
