Old 06-05-2025, 12:15 AM   #155
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Released 2 days ago from the same youtuber regarding our A10's
Now the issue affects 2024 and 2025 Ford F-150's with A-10's apparently have the same A-10 we have.
Not just GM that is woefully under estimating this issue, but apparently Ford is as well.
Nate from NextGen Drivetrain = Shots fired @ Ford
Would love for him to do the same with GM.
Old 06-05-2025, 01:09 AM   #156
FlukeSS
FlukeSS's Avatar
For Clarification: Nate from Next Gen explains the difference in problems between the valve bodies between Ford and GM.
Old 06-05-2025, 05:58 PM   #157
wang970305
Drives: 2021 Camaro 2SS
just got my car back from the dealer, dont truly feel many differences.. I think I feel the car a bit jumpy at low gears... I'm not sure if my ECM FBO tune is trying to work with the updated TCM.
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 06-06-2025, 07:44 PM   #158
FlukeSS
FlukeSS's Avatar
I'd love to see your tune file, so I can compare it to my tune file see what changes they actually made to the transmission.
It would also tell both of us if any of those changes changes the TCM tune to the extent of messing with a custom TCM tune. I suspect if it does, than it will break the trans tuning some of us use and we should NOT get this update. That jumpiness you notice in lower gears can be attributed to a change in torque management values.
The reason I'm curious here is because recently my tuner adjusted my torque management values and I'm wondering if that is a symptom of this valve body issue. If there is a loss in pressure on my trans, then it might explain his need to readjust my torque management values.
Old 06-07-2025, 03:14 AM   #159
wang970305
I would send it to you if I had a HPtuner 🫠.. I thought TCM tune parameters can’t be seen but I could be wrong Maybe someone else in here can share a tune file with you
Old 06-11-2025, 03:24 AM   #160
X24amd
X24amd's Avatar
Drives: 2021 Camaro LT1
It will absolutely affect the TCM
It reprograms the TCM with stock values + the software update to detect the issue.
Then if people like us reflash our proper tunes, what are we doing?
Erasing the previous tune, and uploading our own.
Thus no software lock out.
Or at the very least we have to have our cars retuned to be inclusive of the software lockout.
I have a 2021 a10 with the recall an Im tuned by Trifecta which supposedly tunes the TCM also. Now Im worried an questioning if I should still take it in or the recall update lol
Alex
x24amd@yahoo.com
Instagram- alex24dacosta
X24amd is offline   Reply With Quote
Old 06-11-2025, 06:34 AM   #161
clg82
Drives: 2020 Camaro ZL1
When you say "supposedly" you mean, you don't know what they tuned on your car or what you paid for?
Old 06-11-2025, 12:09 PM   #162
X24amd
X24amd's Avatar
I guess it was only for the 10L90 trans which I think comes with the ZL1 not the LT1 & I say supposedly because its a controversial topic wether Trifecta can actually tune the TCM without sending it in to unlock.
Alex
x24amd@yahoo.com
Old 06-13-2025, 10:54 AM   #163
FlukeSS
FlukeSS's Avatar
So good of GM to refuse responsibility their defective part causes to the transmission.
Also noting that I have GM recorded on a phone call refusing to do the recall at all on my vehicle.
Old 06-13-2025, 10:57 AM   #164
FlukeSS
FlukeSS's Avatar
You are not alone, I'm using a custom tune myself, I do not want this update.
I really need to see someone's tune file so I can see what exactly is changed in the TCM.
Old 06-13-2025, 11:39 AM   #165
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
If a stock tune file would work, I can upload my stock tune on Thursday. Had both recall and BCM enhancement done last month
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-13-2025, 04:07 PM   #166
FlukeSS
FlukeSS's Avatar
Kewl, I'll take a look and if I'm to dumb too figure it out I'm sure one of the pros like Megahurtz or King might be able to figure it out.
Only thing I'll be looking at is the TCM side of things, and ignoring the ECM entirely.
It would be easiser if someone could provide a stock Tune file that doesn't need the TCM update, be a lot easier to decipher things.
I'll check if I still have my stock tune file I think I do.
Old 06-14-2025, 08:58 AM   #167
Roddrz
Roddrz's Avatar
Drives: 2022 Camaro V6 2LT Convertible
Performance Update: Valve Body Upgrade Kit Results
After 2,000 miles of testing, here's the review of the valve body upgrade kit that addresses more than just the standard valve wear issues identified by GM.
Performance Results:
  • Shifts are consistently firm and reliable across all driving modes, including Sport mode
  • Manual shifting using both paddle shifters and the gear selector delivers excellent performance
  • Roll racing shifts are smooth and dependable
Final Recommendation: This will be my final update on this topic - simply put, install the kit.
I've already shared detailed instructions demonstrating how straightforward the installation process is.
The only item preventing me from also upgrading to the enhanced torque converter is the current unfavorable USD/CAD exchange rate (thanks to poor economic management by Canadian leadership).
Bottom Line:
  • No issues to report
  • No need for GM TCM tuning or other tuners
  • Just install the upgrade and get back to enjoying your drive
I appreciate and understand we have many opinions on the issue
  • Keep your warranty for 15 years to have GM replace a worn valve but not a damaged transmission
  • Tuning a transmission is important to many people but tuning voids a warranty
  • Why should the consumer install the upgrade kit and void the warranty
  • We've learned the warranty is valuable until you need it
I must also say that CMP Chevrolet Calgary has been extremely good to me.
Roddrz is offline   Reply With Quote
Old 06-14-2025, 09:17 AM   #168
Hernandez3674
Drives: Chevrolet
Thanks for your update Roddrz, do you still plan for a DIY update. I plan to do this mod myself also and read your thread a dozen times to prepare. Thanks for your contribution.
Hernandez3674 is offline   Reply With Quote
