Old 09-28-2023, 03:18 PM   #155
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Originally Posted by ZKhan View Post
What's the difference between constraint #'s 02802 and 02803?
Originally Posted by Junction65 View Post
The way I read it is the top set is Coupe and the bottom set is Convertible.
Correct.
Old 09-28-2023, 03:21 PM   #156
Green Bastard
Green Bastard's Avatar
Drives: -
What are you trying to order?
https://www.chevrolet.com/byo-vc/tiny/MKhV9Gaix3pD
Green Bastard is offline   Reply With Quote
Old 09-28-2023, 04:06 PM   #157
GearheadSS
GearheadSS's Avatar
Originally Posted by Green Bastard View Post
Ok, so your dealer would need 2 constraint allocations to place your order this week.
They would need to get an allocation for 02824 and 02802.
Old 09-28-2023, 04:27 PM   #158
g-boac
Drives: 2018 ZL1 Coupe M6
If they only had an allocation for 02802 could they still place the order as an SS? While an LT1 requires both?
If they had an allocation for ONLY the 02824 LT1, would this be an example of a “nonsense allocation”, like the one you described previously where you had an allocation for wheels unique to 2SS only, but no 2SS allocation?
Thanks for de-mystifying all this for us!!
g-boac is offline   Reply With Quote
Old 09-28-2023, 04:39 PM   #159
Z06ZLE
Z06ZLE's Avatar
Drives: 2023 Camaro ZL1 M6
It means 3 in my region.
Is your region just Texas, or does it cover a larger area?
2023 Camaro ZL1
2023 BMW i4 M50
2014 Mustang GT
2012 Yamaha R1
2011 Corvette Z06
2008 Corvette Z06
2007 Yamaha R6
Daily: 2015 BMW i3
Z06ZLE is offline   Reply With Quote
Old 09-28-2023, 05:07 PM   #160
GearheadSS
GearheadSS's Avatar
No. If they get an allocation for 02802 but not an allocation for 02824, then that's a wasted allocation for 02802 sent out by GM. 02802 and 02824 are both tied together so it makes no sense that GM separated those two and that they're both different totals.
It basically breaks down like this:
-LT1/1SS/2SS without Collector Edition need both 02802 and 02824
-LT1/1SS/2SS without Collector Edition, with 56Z needs 02802, 02824 and 02409
-LT1/1SS/2SS without Collector Edition, with Q7G needs 02802, 02824 and 02417
-2SS with CE only needs 02824
-1LT/2LT/LT1/1SS with CE are not orderable this week
I know it's hard to understand this stuff for folks that don't do this daily. It's hard for me sometimes and I've been doing it for over 20 years.
Old 09-28-2023, 05:09 PM   #161
GearheadSS
GearheadSS's Avatar
I honestly don't know if that number is for the South Central Region or if it's just for the Dallas/Ft. Worth Zone. GM does not tell us how big of an area that number is for. I just know that it's not the national quantity.
Old 09-28-2023, 05:57 PM   #162
Green Bastard
Drives: -
Im not sure if the constraints list is the same throughout all regions. If so, then it sounds like i only got one of the two necessary. He thinks it would only be good for a collectors edition LT1. That would be quite annoying as that would add 20% to the cost, while adding nothing that I want.
If its only good for 2SS CE, then thats going to be a no-go.
Old 09-28-2023, 07:24 PM   #163
WishfulSS
WishfulSS's Avatar
Drives: 17 Volt, 2024 2SS 1, 2014 Boxster S
Question
The constraints image says for production 10/23 to 10/29. Elsewhere someone says only one more allocation drop. If Camaro production is slated to go to early January, will the final allocation drop include all Camaros built through December? Or will there be allocation drops through November if allocations are about one month before production?
WishfulSS is offline   Reply With Quote
Old 09-28-2023, 07:28 PM   #164
GearheadSS
GearheadSS's Avatar
It's possible your dealer is one that get the CAMALL allocation group. This basically groups both coupe and convertible into one allocation group instead of splitting it up like mine does. The numbers for CAMALL would be 02826 for LT1 V8 Engine and 02804 for 1LZ/1SS/2SS trims.
This is what your dealer would see if they didn't have both of those allocations, with the same numbers as my screen or the ones from above with the CAMALL allocation group. If the numbers in the constraints column are red, it means that they didn't have an allocation for them. If the numbers were black, it would mean that they have an allocation for those constraints.
Old 09-28-2023, 07:30 PM   #165
GearheadSS
GearheadSS's Avatar
Originally Posted by WishfulSS View Post
Question
The dates on the image are just an estimate and not set in stone.
Production is now set to end on 12/7/2023.
Basically, you have until 10/19 to get an allocation for a 2024 Camaro coupe or 10/5 for a Convertible. If you don't have an allocation for your order by then, then your order will not be accepted.
Old 10-02-2023, 02:57 PM   #166
Green Bastard
Drives: -
Your original analysis was correct. Dealer called today saying the allocation was only good for a 2ss ce. What a bizarre choice by gm.
Old 10-05-2023, 08:44 AM   #167
GearheadSS
GearheadSS's Avatar
Getting worse folks....now 6 speed manual trans is limited availability. I can not stress this enough.....
DO NOT RELY ON A PRELIMINARY ORDER IN THE HOPES THAT IT WILL GET PICKED UP!!!
Anyone seriously wanting a 2024 needs to hit the chevy.com locator daily and try to find a car that will work. These are only going to get harder and harder to get and you better get one while you can. If you're sitting at 1100 status thinking your order will get picked up.....you're gonna miss out!
Old 10-05-2023, 12:27 PM   #168
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
That's crazy.1LE is wide open, but 1SS and 2SS are super limited. LOL. And you could get held up depending on what wheels you order too. And definitely don't order LPO (dealer installed) fuel door!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
