Old 08-11-2022, 08:31 AM   #155
JP374
JP374's Avatar
Drives: 21 Lt1
Yeah +43 cam (I’m stuck with a +32 currently too…ugh…) and +52/+65 injectors are the meal ticket. Nothing wrong with +30s but E gobbles up fuel system headroom like PacMan on roids lol
Yea I’m gonna have to decide on upgrading injectors or just going with PI kit. Or tame it down a bit and leave it for now. Decisions lol
JP374 is offline   Reply With Quote
Old 08-11-2022, 09:36 AM   #156
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by JP374 View Post
Thank you! My tuner and I are discussing options. blending is probably the best option. Not sure yet.
Thanks King!
Does the window change from stock lt1 injectors to the +30.s ? I've heard mixed things on it. I've heard that 6.5 MS is ok?
You think it will lose much power by blending and getting the MS under 6.0? I thought about dropping psi from 12 to 10 but don't really want to do that. Don't want to run meth either.
No the injection timing doesn't change regardless of injector. Valve events have more impact on injection timing and a bigger cam will allow higher pulsewidth's but 6.5 isn't safe... it's spraying just outside the injection window and likely making the AFR look richer than what it actually is in the cylinder. A cam car I might let hover around 6.2 when it's cooler out but 6.5 in the middle of summer is going to go much higher when it cools down.
I think I have said this 100 times now but There is very little gain above E60 for most setups. When you start pushing 1200+ whp then we can start to make a case for needing 110 octane for a 10:1 compression engine on boost.
Old 08-11-2022, 09:41 AM   #157
JP374
JP374's Avatar
Drives: 21 Lt1
Ok thanks for the thorough explanation.
Sounds like I’m either gonna have to decide to blend or drop from 12psi to 10psi, maybe that would be enough to get the MS back in check
Old 08-11-2022, 09:51 AM   #158
KingLT1
KingLT1's Avatar
Aside from Injector MS, what are your fuel pressures doing? Are you sure the injectors are at the limit or is fuel pressure dropping?
Old 08-11-2022, 09:55 AM   #159
JP374
JP374's Avatar
Drives: 21 Lt1
Injectors are only at 36%. It’s the HPFP psi goes from 2400psi to 2150psi from 6200 rpm and up.
Old 08-11-2022, 10:12 AM   #160
KingLT1
KingLT1's Avatar
35% is max on duty cycle for DI...it's not like PI where 80% is common.
Old 08-11-2022, 04:50 PM   #161
JP374
JP374's Avatar
Drives: 21 Lt1
Ah ok good to know.
I put a few gallons of 93 in and got it down to e63. I did a quick pull and got to 6.1MS but my afr changed. It was only 73* outside compared to the 90’s we have had so I actually gained 1psi of boost. He’s gonna make some more tweaks but sounds like E60 might be enough for now.
Thanks JP
Old 08-22-2022, 08:20 PM   #162
JP374
JP374's Avatar
Drives: 21 Lt1
So I put a 3.9 pulley on and put e70 in it, got lamda at .82-.83 MS was 5.7. I put pump e85 back in (81% lately) and ms went up 5.9. I was seeing 12.8psi and now down to 10.5. Just updating.
Thanks for the advice guys. Now to figure out the tq tables hahaaa
Old 08-23-2022, 07:39 AM   #163
Dennis 2ss
Dennis 2ss's Avatar
Drives: Camaro 2SS 2017
Thanks for the Info. It helps me alot. I'll have very similair setup. Thinking of 3.9 or 3.85 as of now.
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT
2Forge 19" wheels daily, Forgestar D5 17" for track
Dennis 2ss is offline   Reply With Quote
Old 05-04-2023, 09:21 AM   #164
Dennis 2ss
Dennis 2ss's Avatar
Hey man how much power are you seeing with 10.5 psi? Just wondering since i'm about to order mine now. Was thinking a 3.7-3.9 size
865 WHP 743 LB FT
Old 05-07-2023, 07:37 AM   #165
JP374
JP374's Avatar
Drives: 21 Lt1
With 10-10.5psi on sbe I was at 614whp. On e30. Stock lower with 3.9” upper.
With forged internals and btr cam ect. I was at 790’s at 10.5psi. Current setup 8.25 lower and 3.7” upper (14 psi) on e70 was just under 900 whp.
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
Old 05-13-2023, 11:28 PM   #166
Sillysspeed
Drives: 22 LT1
Side note : did you guys do the standard compression drop ins or the lower 10.25-10.50 to 1’s? Thx
Sillysspeed is offline   Reply With Quote
Old 05-14-2023, 07:09 AM   #167
Dennis 2ss
Dennis 2ss's Avatar
I think most do the lowered ones but i went stock on e70-85.
865 WHP 743 LB FT
