Old 12-25-2020, 09:33 AM   #155
Originally Posted by shogun37 View Post
No, I just use 4th or 5th gear. I'll use 6th only >75mph on an open interstate.
I have 1LE so 3.73 gears so that might throw off your MPH assumptions.
Got it, I assumed 6th gear for a manual that has a fairly close ratio to my 8th (0.5/1.865 overall to 0.65/1.8 overall).
If you want to burn more gas by staying in 4th or 5th, more power to you (literally)
Old 12-25-2020, 02:00 PM   #156
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I personally don't see the point to keep the RPM high while cruising, either. If you need more power, just downshift. It's not hard.
I used to cruise at 2000 RPM on my old Accord beater. My RX-8 needs to be cruised at 3000 RPM or so. Neither of those have a lot of torque, however, which warrants the high cruising RPM. Even then, I could cruise at 1600 RPM on the Accord if the traffic isn't too bad.
I cruise mine between 1200 and 1800 RPM. Perfectly fine.
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 12-25-2020, 03:24 PM   #157
shogun37
Drives: none
For almost 20 years my daily was non-American motorcycles so I'm hard-wired to spin motors. I did an experiment with realtime MPG displays. The same road at the same speed was more efficient in 5th than 6th. That doesn't mean that observation holds in all situations.
I break out in hives and a panicked cold sweat when RPMs drop below 2000. It's engine abuse. Now if I was driving a semi-truck diesel, then sure I'd surf between 800-1500.
shogun37 is offline   Reply With Quote
Old 12-25-2020, 04:36 PM   #158
UnknownJinX
Well, yeah, when you have the low-end torque of a screwdriver and a redline of 13+k RPM, then you need to cruise at a higher RPM.
Realtime MPG display is not that accurate, and obviously don't lug the engine by dropping the RPM way too low.
Some manual cars actually have recommended shift points for daily driving in Owner's Manual. Not the Camaro, for some reason.
Current:
Past:
Old 12-25-2020, 05:44 PM   #159
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Fix
Or
Repair
Daily
Mustangs don’t have a backseat either.
Smaller than the Camaro to.
NYJets12 is offline   Reply With Quote
Old 12-25-2020, 05:56 PM   #160
19 2SS
Drives: 2019 camaro 2ss
Whats the main reason that mustangs are making 800whp with the 2.9l whipple? is it just them being able to take more boost? If I knew from the start that I was going to go this far and boost my car, I absolutely would've bought a 10 speed gt.. I probably would have even sold my camaro and bought a GT if I realized how much better a boosted coyote was but unfortunately I wasn't aware. like its crazy that I could be making another 200-250whp with the mustang for less money than I spent on my camaro build
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
19 2SS is offline   Reply With Quote
Old 12-25-2020, 05:58 PM   #161
Orange ss
Orange ss's Avatar
Drives: 19 camaro19mustang72 chevelle 67pon
this is very true ..also e85 conversion is easier for the coyote and much more performance .
Orange ss is offline   Reply With Quote
Old 12-25-2020, 06:00 PM   #162
Nightfall ss1le
Nightfall ss1le's Avatar
Drives: 2020 A10 ZL1 1LE
It’s not that they make more power with boost so much as it is they have a better bottom end & fueling from the factory. The Camaro can easily make the same power, but you’ll run out of fuel 1st & need a forged bottom end.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD
Nightfall ss1le is offline   Reply With Quote
Old 12-25-2020, 06:00 PM   #163
Umbriel
Drives: 2016 Camaro SS
The internals are just stronger from the factory. When I decided to boost my SS I bought a forged 416 for it, planning on 1200ish with twin turbos. Even if I could have built a Mustang for half of what I paid I still wouldn't have bought one, I just don't like them.
Sent from my SM-N986U using Tapatalk
Umbriel is offline   Reply With Quote
Old 12-25-2020, 06:00 PM   #164
Orange ss
Orange ss's Avatar
Originally Posted by NYJets12 View Post
Fix
Or
Repair
Daily
Having both the 19gt and 19ss ..I have less issues with the mustang .
Old 12-25-2020, 06:01 PM   #165
19 2SS
Obviously the camaro can make the same power, but what im saying is that it takes so much more money. like I could've maxed out my street power potential with 12k into the mustang
Old 12-25-2020, 06:02 PM   #166
Nightfall ss1le
Just curious but who tuned your SS? I had a Pray bolt-on SS before this car & had zero issues & it ran damn strong for what I had done.
Old 12-25-2020, 06:03 PM   #167
Nightfall ss1le
Oh for sure man. Definitely the cheaper car to boost
Old 12-25-2020, 06:05 PM   #168
19 2SS
honestly if someone happened to be looking to buy an already boosted ss i'd probably give mine up and buy a gt, sad to say because I have always liked chevy better
