Old 02-15-2021, 10:16 AM   #155
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
Zayden:
I don't know why someone said it looks like you're going body to body in that pic. The only thing I can see is the NEG body lug next to the fusebox, and that's exactly where SSDan originally said he put it. Since no one can see the other end of that cable in that pic, not sure why would anyone think it's body-to-body?
KLG:
Good stuff on the pic of the OE block connection, but just checking it's tightness doesn't mean it's a good connection. You (we all) should remove the bolt and clean both the block boss and cable terminal. There could be corrosion on that connection making it a poor electrical connection.
In fact, it wouldn't be a bad idea to remove and clean the body lug and cable(s) there too. The body lug is painted (?) with the rest of the car before the OEM cable and post-nut are installed, and I wouldn't be surprised if that's part of the issue. Painted threads and base at the sheet metal beam; cable terminal will not make a good connection at base; post-nut won't make a good connection on painted threads. Only "good" connection is cable terminal to post-nut, which gives you nothing.
WRT galvanic issues, are you talking about galvanic corrosion? That's a non-issue. Galvanic corrosion occurs when two dissimilar metals are immersed in an "electrolyte". The typical scenario (besides a battery where it's intentional) is a boat with a Stainless Steel propshaft and a bronze propeller. Seawater (more specifically saltwater...doesn't happen as much in freshwater) acts as the electrolyte and sets up a current between the shaft and prop. Bronze being less noble than SS causes it to slowly dissolve. It's easily remedied by putting a zinc anode on the shaft, zinc be less noble than either SS or bronze, so the zinc slowly dissolves. There's another issue with boats called stray current corrosion which is different but is sometimes misrepresented as galvanic corrosion, or just misdiagnosed in the first place.
Regardless, neither of those things are going to occur on the Camaro with the cable attached anywhere on the engine, as long as the connection provides an electrically solid path back to the starter.
I like the sound tube mount idea. It looks like a larger bolt than the water pump? Anyone know if the cable can be attached there with the sound tube still in place, like just removing the bolt and putting the terminal on and reinstalling the bolt with whatever sound tube hardware still in place?
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 02-15-2021, 11:22 AM   #156
KLG
KLG's Avatar
Originally Posted by TP2SS View Post
KLG:
Good reminder about cleaning the connections. I had to make sure I was down to bare metal when I was making those two new connections to the body. I did clean the OEM frame lug connection since I had it apart. The connection at the block I decided not to mess with since it looked good with no signs of corrosion, it was tight and it is kind of a PITA for me to access.
You got it right on the galvanic issues, I was referring to galvanic corrosion issues.
The OEM sound tube mounting bolt is a 10 mm with a 1.5 pitch. Takes a #50 torx. When I removed my sound tube years ago, I left the two mounting bolts with grommets in place. So, I used the closest OEM bolt when I did my first pass at adding a secondary ground. I think it might just work with the sound tube still in place, since the sound tube mount slips over the grommet that is held in place by that bolt. Below is a picture of the OEM bolt assembly that I used.
--KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 02-15-2021, 11:37 AM   #157
grampa_ss
grampa_ss's Avatar
Zayden:
Look closer. It's just below and to the right of the top lug connection.
Old 02-15-2021, 01:36 PM   #158
TP2SS
TP2SS's Avatar
Damn you got a good eye! I would not have even looked down there without someone directing me to it, which wasn’t in the original post with that pic! Plus the glare off the copper makes it not look like copper unless looking even closer.
I think you need to change your forum name to EagleEye from Grampa. You don’t have grampa eyes 👀. This is coming from someone who wears contacts and needs readers
Hyper Blue/Ash Gray
A8
Dual Mode Exhaust
Navigation
Old 02-15-2021, 05:23 PM   #159
grampa_ss
grampa_ss's Avatar
I think you need to change your forum name to EagleEye from Grampa. You don’t have grampa eyes ��. This is coming from someone who wears contacts and needs readers
To be fair, I had to stare at that pic for a few minutes to figure what spot he was referring to. Lol.
Old 02-17-2021, 10:21 PM   #160
Choda
Drives: Turbo 6.2
just ordered. Im going a bit of a different route than using the water pump bolt. Im going to run it from the frame to the back of the passenger side head.
Custom Battery Cable Marine Grade | By The Foot
Select Gauge: Tinned Copper Wire: 1/0 AWG ($5.24/ft)
Select Wire/Cable Color: Black
How Many Feet of 1/0 AWG Wire: 2 ft
How Many Inches of 1/0 AWG Wire: 10 in
End 1 (Top): Conector: Tinned Copper Lug - 1/0 AWG
End 1 (Top): Stud Hole Size: For 3/8 in Bolt (M10)
End 2 (Bottom): Conector: Tinned Copper Lug - 1/0 AWG (Bottom)
End 2 (Bottom): Stud Hole Size: For 3/8 in Bolt (M10)
End 1: Top Heat Shrink Tubing: Black
End 2: Bottom Heat Shrink Tubing: Black
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 02-18-2021, 11:58 AM   #161
fxdxron1
Drives: 2016 Camaro 1SS
Just thought I would chime in again looks like everyone that has added an additional ground strap has seen Improvement in the hot start of these cars including myself I wonder if the original ground straps have a poor connection or insufficient cable size.
fxdxron1 is offline   Reply With Quote
Old 02-18-2021, 01:42 PM   #162
Kemo Savy
Drives: Make it a 6 speed in SS trim.
I guess my eye is good to because I seen just what he seen.
Kemo Savy is offline   Reply With Quote
Old 02-20-2021, 04:40 AM   #163
Johnnyb2016
Drives: 2021 2SS 1LE
Been looking at this too.
On my car I have stud extension coming off the thermostat housing as opposed to just plain bolt heads.
Johnnyb2016 is offline   Reply With Quote
Old 02-20-2021, 10:02 AM   #164
oldguy0130
oldguy0130's Avatar
Drives: 2021 2SS red-line Camaro
looks like enough room to add 2 nuts to it and sandwich the lug between them.
oldguy0130 is offline   Reply With Quote
Old 02-20-2021, 11:49 PM   #165
MackSteelPrivateEye
Thats not a good ground...too much plastic contact.
Old 02-21-2021, 09:52 PM   #166
GroundhogSS
GroundhogSS's Avatar
He could always back one of the bolts out and put the connector between the bolt head and the block, then through the t-stat housing.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 02-21-2021, 10:25 PM   #167
TP2SS
TP2SS's Avatar
Why bother when there’s this just a few inches away.
Hyper Blue/Ash Gray
A8
Dual Mode Exhaust
Navigation
Old 02-25-2021, 12:43 PM   #168
Choda
Drives: Turbo 6.2
Got my additional ground strap. 34 inch. 1/0 gauge. 8mm ends. Hopefully this helps with the weak cranking issue a lot of people have commented on.
