#155 | |
![]() Drives: 2016 Camaro Convertible 2SS Join Date: Nov 2016
#156 |
![]() ![]() Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
How long does diagnosis take? I saw the TSB, the diagnosis with picoscope etc.
I made sure to bring a written statement as required by the local lemon law since it looks like GM isn't really fixing the issue. OK law says 4 attempts for the same issue during the manufacturer warranty period. So 5/60k.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
#157 |
It took my dealer about 3 hours for 18-NA-355.
Opened at 7, and called at 10 to say it was done. Well, I guess it was done since they didn't say "we can't detect the shudder". Now we all wait. The only 2019s A8 GMs with a shudder were built in 2018 that I can find so far( colorado's).
#158 |
![]() ![]() ![]() ![]() Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
Got her back with the new fluid, transmission feels definitely different, it’s sharper. I feel more confidence in it in sport mode. In tour I do notice it’s more of softer shifting. No shudder in V6 mode, slight shudder in V4. Yet again it’s only been 20 miles.
#159 | |
#160 | |
You told them TSB 18-NA-355 right? They should be able to pull it up with no issue it was published on January 12th or something like that. They shouldn’t give you a hard time because they get paid by GM at the end of the day. My dealership loves warranty work becaus they get paid more (don’t know if this is true) by GM compared to getting paid by a customer. |
#161 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Jun 2016
Wondering about possibly getting this done prophylactically. I don't have the shudder problem so far, 8k miles. I know it wouldn't be covered by warranty - does anyone have any idea how much it would be out of pocket, or if a dealer would actually do this?
#162 | |
Told by adviser: It takes way over the 1.5 hours to do it, more like 3 hours, we have to hook up a picoscope and and find the problem, and then do a triple flush. I said the new TSB says one flush and he said that THEY do a Triple Flush. SAW on dashcam: Time between first starts and moving the trans flush machine away from the front, and then leaving the bay: 1 hour 20 minutes. Car was running for 4 minutes, on accessory mode for 12 minutes. No footage of any driving during that time. Invoice says 20 quarts of blue label fluid per 18-NA-355(so no triple flush),and road test (after flush) OK. Never saw footage of the car lifted, or driving. GM requires proof of the problem on a Picoscope screenshot for the warranty work. It was cold, how did they get the trans fluid up to temp and do the pico with three minutes of running? Maybe they unplugged the cam, but even then the test drive was super short going by so little mileage difference. I forgot to take note of the mileage, but I remember it was 266- on the way there(so could have been 267- at drop off, invoice says 2674), and 2675 when I picked it up, they may have not driven it at all. I'm fine with it, plenty of evidence they did the flush(machine inches from the car, the hard shifts during pickup, smoother shifts on the way home). Just curious.
2023 Camaro ZL1 A10 Radiant Red Last edited by SnakeEyeSS; 02-06-2019 at 10:21 AM. |
#163 |
![]() Drives: 2016 SS Camaro Convertible Join Date: Nov 2018
I don't have the shudder and haven't read all the attached posts, (so sorry if this has already been covered), but was looking into changing my A8 tranny fluid and came across this guys video, maybe you have seen it?
https://www.youtube.com/watch?v=dPrP4NQZg6w[/url] this video is titled; "Camaro, Corvette, Cadillac 6, 8, and 10 Speed Auto Trans Fluid Level Check - No Dipstick" in case the link does not work Anyhow, about 10 minutes into, he notes a GM bulletin for anyone with the "shudder" to use Mobil 1 Synthetic LV ATF HP Tranny fluid. Maybe will help?? |
#164 | |
STD free
Drives: 2018 Bright Yellow LGX M6 RS NPP Join Date: Nov 2017
#165 | |
STD free
#166 |
#167 | |
And you might want to read up on it because I wouldn't be surprised if people that don't have it actually just don't notice it, less than perfect roads and even music hide it well. Find a smooth road, drive slow and easy with exhaust in stealth if you have NPP, and listen for a light rumble during shifts, and see if your tach bounces around a few hundred RPM. I'll load a video later of it, it's very subtle in early stages.
2023 Camaro ZL1 A10 Radiant Red Last edited by SnakeEyeSS; 02-06-2019 at 06:55 PM. |
#168 | |
