Old 02-23-2020, 11:09 PM   #155
samr350
samr350's Avatar
Drives: 2017 SS 1LE
Originally Posted by apexit53 View Post
I use a 3mm spacer. extended studs not really needed but I like the idea of stronger ones!
OEM studs are more than strong enough, the only way you'd have issues with them is by massively over or under torquing them. Many other things in the suspension including the wheel itself will fail before the studs themselves break.
samr350 is offline   Reply With Quote
Old 02-24-2020, 01:48 PM   #156
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
awesome thank you!
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 02-24-2020, 05:53 PM   #157
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Originally Posted by glamcem View Post
May I ask where you found the Stoptech rear rotors that are compatible with Gen 6 SS 1LE? Do you have some information on the weight, part numbers?
I didn't weigh them
StopTech 126.62153SR
StopTech 126.62153SL
Amazon $99, TireRack $104, to name a few
Old 02-24-2020, 09:53 PM   #158
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by carguy55 View Post
I didn't weigh them
Thanks for the info. What made you select these over the factory replacement ones?
glamcem is offline   Reply With Quote
Old 02-25-2020, 06:46 AM   #159
canadian_roger
canadian_roger's Avatar
Drives: 2020 SS 1LE
according to amazon they are 19.95 pounds... The stock I think I rear somewhere is 23 pounds.
canadian_roger is offline   Reply With Quote
Old 02-26-2020, 12:52 PM   #160
glamcem
glamcem's Avatar
oh ok , thanks for the info
Old 02-26-2020, 01:38 PM   #161
TrackClub
TrackClub's Avatar
Stockers are 19.33lb
Old 02-26-2020, 04:32 PM   #162
Ummpwr
Drives: Honda S2000
Originally Posted by Ummpwr View Post
I have my 19 in set up pretty dialed in so thought I'd share.
Using 5mm spacers up front with Silverado extended lug nuts, -2.9 deg camber front, did wire tuck in left rear, (no rubbing on fender liner anyway)
19x10 et23 305/30/19 19x11 et43 325/30/19
Goodyear s3 tires 220 tw so I can run BS AUTOX
(4th raw time, 3rd pax out of 80+ cars at first autox with this set up)
Liking it a lot so far.
Eric
How is the feel of the car with this setup? I've been thinking about doing something like this for a track setup and wondering how the wider tires on this width feel. Did you lose any steering response or feel? They look a little pinched but not too bad. Thanks.
Overall I like the feel and even though it does have slightly slower steering response the added grip level dramatically outweighs any other short comings. The tires are slightly pinched, ideally I'd have 11 and 12 in wide wheels but I wanted to stay in B street autox class.
I would definitely recommend the set up. I relocated the left rear wiring harness bit have not had any rubbing in the fender liner anyway.
Thanks Eric
Ummpwr is offline   Reply With Quote
Old 02-26-2020, 05:00 PM   #163
glamcem
glamcem's Avatar
Ah thanks, I just cancelled my order
Old 02-26-2020, 07:48 PM   #164
canadian_roger
Drives: 2020 SS 1LE
Sorry, I had read in a "weight-saving" thread they were 23lbs.
Does anyone make a 2-piece for the rears?
Old 02-26-2020, 08:36 PM   #165
carguy55
carguy55's Avatar
Racing Brakes does, only $1066
Old 02-28-2020, 12:06 AM   #166
TrackClub
TrackClub's Avatar
The rears last forever...
Old 03-03-2020, 05:43 PM   #167
carguy55
carguy55's Avatar
Another one for the lessons learned department, don't buy the cheap aftermarket TPMS in an effort ot save some money. Get the real GM ones from RockAuto. You'll be glad you did!
Old 03-03-2020, 08:23 PM   #168
TrackClub
TrackClub's Avatar
Thanks for the heads up would you have the part number handy by any chance?
