Old 02-22-2019, 04:21 PM   #155
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
The OLM is nothing more than a computer algorithm that factors in time, stop and go, highway and spirited driving among other things, it has nothing to do with the oil or quality. You could park it in a garage for a year and your OLM will read 0%, want it to last longer drive like your mother.
Warrior102 is offline   Reply With Quote
Old 02-22-2019, 08:39 PM   #156
MySS8U
MySS8U's Avatar
Drives: Black 1SS 1LE
LOL thanks I won't be driving like my mother anytime soon
JALB
MySS8U is offline   Reply With Quote
Old 02-26-2019, 08:22 PM   #157
ssmike
BL1ZZRD
ssmike's Avatar
Drives: '16 Camaro 2SS, '20 Equinox Redline
Is this new formulation specifically for track cars? Should I start using it for my ‘16 2SS?
ssmike is offline   Reply With Quote
Old 02-26-2019, 08:24 PM   #158
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
It's designed to work in all conditions so you don't have to run different oil for track and street.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 02-26-2019, 08:58 PM   #159
TrackClub
TrackClub's Avatar
It is designed, so GM can fill them at the factory with Dexos2 oil - which hadnt been the case before.
It is also designed so GM dealers have Dexos2 oil to satisfy needs of those that track their cars - which hadnt been the case before.
Also, since this oil is much more expensive than the original factory fill oil, there likely is a higher margin for the dealers.
Once you fill with 0w40 Dexos 2, or 5w40 Dexos2 oil you do not have to change it between street and track use. It works for both.
Simply said, GM filled a gap as far as their ablity to sell the oil they themselves required for track duty.
It really is that simple imo.
Old 03-15-2019, 11:27 AM   #160
Fatty1707
Drives: 2019 ZL1 A10
Black or dark oil does not mean it's bad. Oil analysis is the only way to tell if oil is good or bad regardless of color. Discoloration is a natural byproduct of heat and soot particles, which are too small to wear out your engine.
Fatty1707 is offline   Reply With Quote
Old 03-15-2019, 02:23 PM   #161
Gasoline_Farts
Drives: 19 SS 1LE
Anyone price this at their dealer? Summit racing wants $60 a case and the dealer here wants $23/ quart!
Gasoline_Farts is offline   Reply With Quote
Old 03-19-2019, 07:42 AM   #162
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
$57.99 for a case of six quarts.
About $9.60 per quart shipped.
That's not bad at all.
The Specialist is offline   Reply With Quote
Old 03-19-2019, 11:56 AM   #163
Z0Tex
@texan.1le
Z0Tex's Avatar
Drives: '18 Camaro 1SS 1LE, PDR
Just bought 31 quarts (5 6-quart cases plus 1 additional quart) from Speedway Motors directly, not through their ebay or amazon stores. Free shipping for orders over $99 and a $10 coupon for signing up for their promo emails. Came out to $276.94 shipped to TX, or $8.93 per quart shipped.
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily
Z0Tex is offline   Reply With Quote
Old 04-01-2019, 03:38 PM   #164
jmhinkle
jmhinkle's Avatar
Drives: 2018 2SS Vert
Summit is advertising $12 rebate per 5 quarts on their product page. Rebate supposed to run from 4/1 to 9/30, but the rebate is not up on the Mobil1 website yet therefore the link from Summit isn't correct. Not sure if Speedway purchases will be eligible for the rebate.
jmhinkle is offline   Reply With Quote
Old 04-01-2019, 04:39 PM   #165
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
Unbelievable...literally just bought 4 cases from Speedway 3/30 and the rebate started 4/1...could have saved $48...
rlarsen462 is offline   Reply With Quote
Old 04-02-2019, 03:43 AM   #166
The Specialist
Should we really use this oil in our Camaro?
Reading through the literature, it mentions Diesel designed filters.
Does the 6th Gen Camaro come with this type of filter or filters or is it only special in the latest Corvette?
Old 04-02-2019, 05:04 AM   #167
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
I wonder if "spirited driving" really plays a factor in the oil life monitor? I change my oil after every track event. The last event I drove 530 miles and averaged 4 mpg (80 miles per tank). The OLM was at 94%, if I remember correctly, after the weekend. Seems to me that time and mileage are the biggest factors in the OLM algorithm.
breakskeet is offline   Reply With Quote
Old 04-02-2019, 11:23 AM   #168
breakskeet
Kevin
breakskeet's Avatar
Guess I answered my own question. From the Performance Supplement:
During track usage, do not follow
the Engine Oil Life System status.
Change the engine oil after four
hours of accumulative track usage.
If 15W-50 oil is used, it must be
changed back to the engine oil
listed in the “Engine Oil” section of
the owner’s manual.
