#155 | |||
![]() Drives: broken Join Date: Aug 2009
![]() Quote:
Can we really draw a straight line from a parts bin package like that on the turbo back to what they did for the SS 1LE? With its mag shocks, trick LSD, wider wheels front and rear? I mean, I don't know. I haven't driven a turbo 1LE, so I can't compare even anecdotally. I want the turbo 1LE really good. I want it to be better than the non-1LE. I'm just unconvinced that it is and I worry a little that it could be slower in an autocross environment. 1LE or not, for DS what the Camaro needs are shocks. If I was thinking about buying one today, I'd talk to Jeff at Pro Parts about theirs. The quickest option may be a non-1LE on those shocks and running 18" wheels.
clyde
Team WTF?! what are you gonna do? :dunno: |
#156 | |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
18" wheels and yokes!
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
#157 |
![]() Drives: Boost Coupe Stewie formerly '01 Z28 Join Date: Jan 2007
Well, we went and did it: A 2018 1LS is in our hands and now the tire shopping begins.
A little help please: Does the "tread width within a half inch of wheel width" rule apply to the A052's, and possibly the Falken RT660's? Both of those tires come in a 255/40R18 that measures 9.4" of treadwidth. |
#158 | |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
That said, for autocross or road course usage I'd also look at two other options. One would be the 245/40/18, which is a bit narrower and shorter but is less "pinched" on the wheel. It might actually work better for you because of that - I seriously doubt it would be slower. Also, you could try the 255/35/18, which is just as wide but an inch shorter than the 255/40. That would lower your CG and roll centers a useful amount and effectively shorten your rear gear ratio. This could be helpful it doesn't cause you to have to shift between 2nd-3rd on most courses. Both tires come in those two alternative sizes.
Matt Miller
2020 SS 1LE |
#159 | |
What are the thoughts on mixing sets such as a BFG rear and Bridgestone front, since contingency is not a factor? |
#160 |
I'm no autocross super-star or expert, but I've never tried mixing different brands of tires and can't really see a good reason to do so.
Matt Miller
2020 SS 1LE |
#161 | |
![]() Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
I have some RE71Rs coming, so once I finish the Rivals, I'll see how they do.
#162 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
#163 | |
#164 |
This is exactly along the lines of what I'm thinking of. We generally know that the Bridgestone has the better lateral feel and grip with the BFG being generally better longitudinally.
#165 |
Yep. He hated the bfgs upfront. So did I on my fifth gen. They felt good only after I stiffened up the front coilivers from middle to the stiff settings.
#166 |
A bit more clicking around reveals an interesting option: The Yokohama A052 in 265/45R18. The tread width runs 9.2" across, so it's slightly pinched but not overly so on the wheel. The diameter is within 2/10's of an inch of the OE size, so gearing is preserved (not sure if that's good or bad) for the bigger national courses.
#167 |
Video of the first outing of the new to us 2018 Camaro 1LS in D-Street from ysterday's local NNJR SCCA event. I asked my friend Tony Savini to co-drive to provide feedback and coaching. He managed a P3 finish in a car that we basically put some RE-71R's inf ront and Riva S 1.5's in the rear. I came in a distant P4, but am happy to see some potential with more seat time and prep.
As always, feedback and critiques are welcome - |
#168 |
![]() Drives: 2009 370z Join Date: Jun 2019
If you were local, I'd let you try mine (actually a few swapped runs would be fun as I'd like to compare the 1LE v LS. I've only got one event and one track event for this year and the season has been a mess with local site issues. I was really sad I couldn't make the Peru tour event this weekend too. Really as far as AX is concerned, my only big complaint is so far is the throttle response. More camber would be a majorly welcomed addition. I have a feeling after this season I'm going to be frustrated and end up in cam with a tune to resolve the throttle issues, camber plates and some 285 or 305 squared shoes.
