#155 | |
![]() Drives: 2017 SS 1LE Join Date: Oct 2015
#156 | |
@SS_1LE
Drives: 2017 SS 1LE Join Date: Mar 2017
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S |
#157 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
So for those of you guys who switched pads, did you switch right away to new pads negating the need to have the rotors ground down? Did you shave the rotors? Or just swap pads and bed them in?
Once I run through these stock pads I will be swapping to DTC60 track / HPS street and I would like to continue to use my rotors (assuming they still have life in them).
#158 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
I switched them right before the first event and didn't follow to bedding in procedure completely but did a few quick stops on my way (when the road allowed). I didn't have to shave any of my rotors so far. They have been just fantastic
#159 |
hmm Im assuming after a full set of stock pads the rotors would require a shave before swapping to Hawks compound eh?
#160 |
![]() ![]() Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
#161 |
That's actually a really good idea. Swap to the 60's at the track, run a full day. After I get home swap on the new HPS's and bed those. Good to go. A successful swap to Hawks compound without shaving the rotors.
#162 | |
I've never had any issues switching between the race pads and street pads on the same rotors
#163 |
#164 |
![]() ![]() ![]() ![]() ![]() Drives: 2023 CT5 Blackwing, 2025 C8 Z07 Join Date: Sep 2016
If you are swapping Hawk to Hawk, you do not need to re-bed.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 2025 Hysteria Purple C8 Z07 |
#165 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
I need to ask: so I have not read a single bad review on a stock pad. So why are you guys moving to different pads? Performance (and if so, in what way different), cost (ditto pls).
Thx! |
#166 |
AutoX. The DTC-30 has almost full 'grip' from cold. Much more bite than the cold OEM pad.
2017 HBM SS 1LE
#167 | |
The only car I've driven with equal OE brakes\pads is Porsche GT stuff. That's one hell of a compliment. |
#168 |
Ok I can see that for autox. Interested in road course findings. Thx!
