Old 11-12-2017, 09:22 PM   #155
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
This is why I wanted to keep the AFM.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-16-2017, 10:58 PM   #156
Flash144
Drives: Drop Top SS
That's good to hear. The Borla team are good people.
Heath
Flash144 is offline   Reply With Quote
Old 12-09-2017, 03:12 PM   #157
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
As of today, still no CEL. All is well.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 02-10-2018, 10:23 AM   #158
cocomobile
Drives: 2SS
CEL and Ticking Sounds
I'm glad to hear some of you were able to get your Borla systems running as advertised.
In my case I'm still not at 100% yet. I replaced my old catback system (P/N 60609) last month with their latest redesigned AFM valves and I'm still getting a CEL (P0420), but now accompanied with an annoying ticking sound.
The ticking sound can be slightly heard when driving in V8 mode (more with windows down) and can definitely be heard when the car switches and runs in V4, both with windows up or down.
I've noticed that the ticking sound in V4 mode is also louder when I'm light on throttle gradually increasing speed. Very annoying hearing the ticking on my morning commute when I don't always want to have the radio on. Interesting enough is that running the car in cruise control helps reduce the ticking sound significantly. Of course that is only when the car is running on a flat road or downhill and acceleration is either constant or none.
Could it be that the AFM valve module may have been screwed on too tight restricting swift movement of the valves?
Now what about the CEL? I checked for leaks and multiple muffler shops confirmed that everything is installed correctly. The last time I cleared the code, I saw it come back was when the car converted from V8 to V4.
I'd hate to say it but I'm starting to think that I should have just gone with the axle back set-up and save myself the headaches and money. Not sure if the catback was worth it. I have friends who did a basic 2nd cat delete to their stock setup while running an axle back set-up and have no problems.
cocomobile is offline   Reply With Quote
Old 02-10-2018, 10:30 AM   #159
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
That's not good to hear. The slightest leak on the drivers side where the lap joint is, right behind the primary cat, will throw a code. I had that problem with my M6, a little copper gasket sealant solved the pro let for me.
I've not had an issue after the x-pipe was replaced.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 02-13-2018, 02:50 PM   #160
Ian@Borla
Ian@Borla's Avatar
Drives: Borla
Hi! I'm sorry to hear you are having issues. Please reach out to my customer service manager at ChrisB@Borla.com
Ian@Borla is offline   Reply With Quote
Old 02-18-2018, 05:27 PM   #161
Richkidd87
Richkidd87's Avatar
Drives: 2016 Camaro 1SS Red Hot
Heath
Ive had my system installed over a year and still no CEL.
Richkidd87 is offline   Reply With Quote
Old 04-10-2018, 08:20 PM   #162
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
Sorry to resurrect.
Is anyone hearing buzzing or vibration noises? I don't get a CEL, but something sounds like its either a) loose or b) touching underneath the rear seats.
I have been back to the install shop several times, today, the manager sat in the car, and he confirmed hearing the sound. But he assured me the Borla has ample clearance.
The shop recommended tuning out the AFM to smooth out the sound. I have my doubts, but I ordered a range device to see if this is a fix.
I'm kinda at a dead end.
Borla 11925 and 60610.
ajp is offline   Reply With Quote
Old 04-10-2018, 08:26 PM   #163
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Originally Posted by ajp View Post
Sorry to resurrect.
My wife's daily, but I drive it on occasion. She hasn't said anything to me about it and I haven't noticed anything unusual.
May be touching the crossmember.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-12-2018, 02:25 PM   #164
david borla
david borla's Avatar
Drives: Ford GT
If you have any issues whatsoever with any of our products please call us at 877-GO-BORLA and ask for customer service so we may resolve those issues to your satisfaction.
Thanks!
david borla is offline   Reply With Quote
Old 04-12-2018, 03:28 PM   #165
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Thanks!
You guys took care of me, thanks David.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 04-14-2018, 06:46 PM   #166
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
This thread was poorly named (inferring an issue with all Borla's catbacks) when the OP's issue was was his AFM valves. Not NPP valves or Borla's axle back mufflers- just the catback X-pipe for automatics.
Now the length of the thread with the current title create the impression there is an on going problem. I've got the manual trans (no AFM valves) with Borla's 60606 sleeve clamped to the stock NPP muffler and IMHO, the car sounds like beast!I couldn't be happier. No CEL, no issues.
Thanks Borla and sorry about all the (apparent) bad press. Lets try to stay on point guys or start a new thread.
Ventmaster is offline   Reply With Quote
Old 04-14-2018, 06:55 PM   #167
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I agree the title is misleading. If one of the moderators would be so kind as to retitle this thread. It would help a bunch.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
