Old 08-23-2016, 02:34 PM   #155
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
Also my gmc truck does this as well, I turn the heat on defrost for a moment until it clears then reduce heat
Slem is offline   Reply With Quote
Old 08-23-2016, 08:05 PM   #156
cigarfan
cigarfan's Avatar
Drives: 16' Camaro 2/SS BlackMosaic A/8 NPP
T-Storm rolled through yesterday. Temp was 90+. The dewpoint/humidity went north after it ended. Dew on the shield with the A/C cranked @ 71. Yes, not surprised it happened.
cigarfan is offline   Reply With Quote
Old 08-24-2016, 06:08 AM   #157
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
This morning it was 63 degrees, very low humidity. Air was nice & crisp/dry. Set a/c at 70 (so we could have the windows closed) and it still started fogging up.
GM, you better find a fix for this quickly.....
classicrockr is offline   Reply With Quote
Old 08-24-2016, 01:45 PM   #158
Camaro2ss808
2017 2ss 6MT
Camaro2ss808's Avatar
Drives: 2017 Camaro 2ss
I picked up my 2017 2SS yesterday and salesman showing all the features of the radio and onstar while car is running with air condition on and fogging shows on my windshield. We tried to figured it out and even take it to the service advisor to the service department but no luck. They advice me to set an appointment so they can look it out further other than its an awesome car.
Camaro2ss808 is offline   Reply With Quote
Old 08-24-2016, 01:58 PM   #159
Wheel Team 6
Wheel Team 6's Avatar
fogging windshield
It happened the same way for me when I ordered mine. While parked idling going over things with my salesman and on the phone with On-Star it did the same thing. This was back in May when it was very hot and I literally thought oh just a new car no biggie it will be OK. Still the same now after 3 trips still the same. Last week I drove the car and had to put both zones at 78 fan on low to keep the windshield from fogging up excessively. Was a hot day and uncomfortable ride. I bumped the settings down to 75 to cool off and the windshield immediately fogged up bad. I never turn the re-circulation on or I would have to pull over because then I can't see out the windshield at all.
Wheel Team 6 is offline   Reply With Quote
Old 08-24-2016, 02:27 PM   #160
JaxChris
And you're in Hawaii, which has way lower humidity than the mainland. Thanks for another example.
Old 08-24-2016, 02:30 PM   #161
TMasticTB91
Tampa Bay Camaros
TMasticTB91's Avatar
Drives: '16 Hyper Blue 1LT
Had a 45-minute drive this morning, low 80s, high dew point and humidity, temp set between 73-76 and torso vents only, and I still started to fog up. Threw my mousepad up and it at least covers the left vent, so my view in-front of me isn't obstructed. The right-side is still exposed and will fog, but it DOES cut down on the amount.
I'd recommend anyone here to pick up a cheap black mousepad on Amazon and keep it in the glove compartment for days when it fogs up, at least to have SOMETHING to block the vents and keep the fogging to a minimum.
2016 Camaro 1LT | V6 | A8 | Hyper Blue
TMasticTB91 is offline   Reply With Quote
Old 08-24-2016, 02:39 PM   #162
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
So has anyone heard back from the GM rep? Is there a fix coming?
Old 08-24-2016, 02:46 PM   #163
Camaro2ss808
2017 2ss 6MT
Humidity here right now is high 80s to low 90's sometimes.
Old 08-24-2016, 04:00 PM   #164
JaxChris
Vent actuator replacement fail. They need to find where the cold air is blowing out of.
Old 08-24-2016, 04:38 PM   #165
nbryant
nbryant's Avatar
Drives: 2016 2SS Red Hot
Look at their weather today. Mid 80's with mid 70's humidity! Not much different from lots of places on the mainland. Lived there 7 years, it does get moist from time to time.
2SS, A8, NPP, Nav, Sun Roof, Bose Audio, MM Catch Can, RPI chin splitter
nbryant is offline   Reply With Quote
Old 08-24-2016, 07:54 PM   #166
cigarfan
cigarfan's Avatar
Wow...63 degrees, low humidity?
I expect to see temps that low come November in my world.
When I do...No A/C w/windows/roof cracked open enjoying every second of that feeling. Perhaps defrost on 70+ ish.
Old 08-24-2016, 08:01 PM   #167
Camaro2ss808
2017 2ss 6MT
2:58pm 85*F humidity 72 at this moment. Set my a/c @ 62*F circulation off and no fogging at all.
Old 08-24-2016, 09:01 PM   #168
JaxChris
Generic copy/paste PM from Chevy CS saying they are looking into it blah blah blah... there is enough sample data by now. If those in Michigan don't understand or trust the service managers down here, then fly on down. But wait... every model of Camaro since 2009 has been tested in Florida during the summer. How was this not seen when the 2016 SS and 2017 ZL1 were testing?
