Old 04-02-2016, 06:31 AM   #155
RyanR3KC
"1/LE Rebel Alliance"
RyanR3KC's Avatar
Drives: 18 Black 1SS 1LE “Siouxsie
just put a Vette Z06 against the Hellcat and that will pretty much sum it up.
RyanR3KC is offline   Reply With Quote
Old 04-02-2016, 07:14 AM   #156
Jeffro19
Jeffro19's Avatar
Yeah plenty of those match ups on you tube. Some the Z06 wins some the hellcat wins. The new ZL1 with the 10spd will change things a lot though.
Old 04-02-2016, 09:40 AM   #157
tones2SS
tones2SS's Avatar
Drives: '13 Roush S3 '16 Ram Sport 4X4
^^^This!
tones2SS is offline   Reply With Quote
Old 04-02-2016, 01:19 PM   #158
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Originally Posted by tones2SS View Post
^^^This!
What type of racing?
2cnd chance is offline   Reply With Quote
Old 04-02-2016, 01:31 PM   #159
Jeffro19
Jeffro19's Avatar
Mainly roll racing on the highway from what I've seen.
Old 04-02-2016, 03:22 PM   #160
2cnd chance
That's what I thought. Roll racing has waaaaayyyyy to many variables to be scientific. In another words take it with a grain of salt.
BTW at a track or drag strip using the same pro driver on the same day a Z06 will "always" win.
Old 04-02-2016, 03:23 PM   #161
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
B-b-b-b-but 707 HP!?
Old 04-02-2016, 03:33 PM   #162
Jeffro19
Jeffro19's Avatar
I agree from a standstill the Z06 and the new ZL1 with the 10 spd auto will win. When roll racing, weight doesn't have as much of a factor as it does when standing still.
Old 04-02-2016, 03:53 PM   #163
2cnd chance
It's gearing and HP.
Old 04-02-2016, 03:54 PM   #164
Jeffro19
Jeffro19's Avatar
Exactly
Old 04-02-2016, 04:39 PM   #165
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
I really don't think the 10 spd is going to provide much if any benefit in a straight line over the outgoing transmissions. There's only so much gearing the engine really needs when it's making so much torque.
Sent from my SGH-M919 using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 04-02-2016, 05:11 PM   #166
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
If you can't put it to the ground like the Hellcat, then yes it wouldn't help. But if putting the power down isn't an issue, the extra gears(assuming they didn't drastically changes ratios from the 8L90) means higher effective ratios, which can make make a major difference. The 8L90 Camaro is faster in the 1/4 than the M6 for this very reason.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 04-02-2016, 05:18 PM   #167
Zeke.Malvo
Zeke.Malvo's Avatar
Yes and no. I fully understand how gearing works.
There's a reason cars that go 0-60 in two gears do it quicker than those that need a third shift. There's a point to where the additional gearing doesn't do much, ESPECIALLY on a high torque engine. A Honda or something else with a small power band definitely needs all the gearing it can get, but a SC 6.2 making 640 tq, not so much.
Old 04-02-2016, 05:26 PM   #168
SuperSound
SuperSound's Avatar
0-60 isn't the only thing that matters and then when shifts take less than a pro driver with a manual...the difference becomes even less an issue.
And remember the 10 speed has only one extra power gear than the 8. We aren't talking about enough gear changes to hurt. And you can't deny that the A8 cars from every manufacturer run faster than their manual equivalents.
Will it make 4 tenths, not a chance. Will it improve by a tenth or two over the 8L90. Quite possible. But I do believe this new 10 speed is more about the track and squeezing MPG higher than anything.
