Old 03-14-2018, 03:46 PM   #155
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
This happened on my SS 1LE about a month ago. One morning driving to work I was unable to take the exhaust out of stealth mode after pulling out of the garage. Tried turning off the car at a light and restarting, still didn't work. When I left work it was back working.
Old 03-15-2018, 07:47 AM   #156
davef
Drives: 2017 SS 1LE Garnet Red
On my car it seems to correlate with opening the passenger door first. The last two time I opened it for my son to get in the back and this morning to put my gym back in the passenger front seat. I checked and the menu items were missing. I'll probably go to the local dealer today and get an appointment.
I hope they don't screw up my car.
davef is offline   Reply With Quote
Old 03-16-2018, 11:01 AM   #157
davef
I went to the local dealer yesterday and gave them the TSB I printed out from page 9 of this thread: #17-NA-186. The service writer put it in his computer and found, for Camaros only, it superseded to a new TSB that says engineering is still working on it. I couldn't get a screenshot of his computer but it looked like GM thinks that there is a different solution if only the drive modes disappear vs. the drive modes and the comfort settings disappearing as well.
So, in other words, it seems that there's still no definitive fix for me.
Old 03-16-2018, 01:31 PM   #158
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
I think this may have happened to me once, but I'm still keeping tabs. I checked twice yesterday and the drive mode item was there. Someone mentioned opening the passenger door first might be the cause. This is something I do every morning to put my laptop on the seat. I don't use the stealth feature so I haven't noticed it before. Not a big deal in my book.
This was posted earlier in the thread:
Originally Posted by Keifer View Post
The problem can occur if the vehicle is asleep (control modules asleep) and you enter the vehicle from the passenger door (perhaps to place something in your vehicle) and then close the door. Certain control modules wake up when you open the passenger door and then start to go back to sleep after you close the door and walk away. If you return and enter through the driver door maybe 1-2 minutes later and start the vehicle everything in the vehicle wakes up. It's a software anomaly when certain modules start to go to sleep and then wake up again. You can probably replicate it if you follow those steps. Happened to me once also.
It will fix itself at the next ignition cycle (if the vehicle goes to sleep).
I believe the above post is valid, but I'll need to do some more testing if I notice it again. As for 'comfort mode'. I don't have MRC, so that may not apply to me.
Troubleshooting and being around computers for so long, I see this is a minor bug that's not worth a dealership visit. If the menu goes away permanently, then that's another story.
torqueaddict is offline   Reply With Quote
Old 04-07-2018, 11:19 PM   #159
RJTC11SS
RJTC11SS's Avatar
Drives: 2019 ZL1 A10
Driving Mode
Took mine into the dealership Thursday - they’re replacing the radio, per GM. We shall see if that corrects the problem.
RJTC11SS is offline   Reply With Quote
Old 04-08-2018, 02:02 PM   #160
torqueaddict
Since my last post, I haven't noticed the issue.
Old 04-10-2018, 06:35 PM   #161
cwoodard91
Drives: 2016 2SS
I knew I couldn’t be the only person with this issue. Here is a video a made of my car doing this.
https://youtu.be/g6IGaWUkc-E
cwoodard91 is offline   Reply With Quote
Old 04-11-2018, 03:20 PM   #162
Gen5&Beyond
Gen5&Beyond's Avatar
Drives: 2016 2ss Camaro
My 2016 did this last year. I took to the dealer and they replaced the radio. Everything seemed fine until today. Driving mode is gone and the option to change the lighting is also gone. I have headers and no cat's so it's loud with the NPP open. I usually change back to stealth mode for the cold start the next day. I guess it's back to the dealer??
HBM 2016 2SS A8 NPP
427 Pray Head/Cam/Converter, Pray Ported Highram, 103mm TB, Pray Tuned, 3030 Drag Pack, Roark OTR CAI, TSP Headers, E85, UDP
Best times 1/4 n/a 9.23@146.96, 1/8 5.91@118
Gen5&Beyond is offline   Reply With Quote
Old 04-11-2018, 03:32 PM   #163
Gen5&Beyond
Originally Posted by jdasnt3 View Post
Mine does it. And it tells me that I can't switch the lighting colors "in this mode" at the same time. I don't have the options to sync the colors with driving mode or do the "show." Seems to be random and then it will show back up when it wants to. Even turning the car off and on doesn't always work. I returned the car to default to get them back once, but they went away again today.
Could it be something normal based on our selections and not a problem that is in more than one car?
I only have NPP, not MRC.
Contacted my dealer and have a appointment for 7:00am. New Radio again? We'll see. On another note the HVAC system seems to be acting up as well.
HBM 2016 2SS A8 NPP
Old 04-11-2018, 11:03 PM   #164
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
If yours is an A8, try my fix (above). It has worked for me 100% of the time since I started doing it. Painless! Will save you a bunch of hassle...
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 04-11-2018, 11:11 PM   #165
Yep, it works every time, thanks for the workaround.
It looks very much like a race condition during module init, depending on the order and timing of module activation. Doubt it will ever get a fix, these things are not easy to repro with any consistency, and also the devs have very likely moved on to working on something totally different by now.
Old 04-13-2018, 10:21 PM   #166
Gen5&Beyond
Wasn't able to get to the dealer Thursday so I went today. They checked the car and ordered a radio. Not wanting a loaner or to leave my car at the dealership I took my ride to the house. I'll have to take it back next week to have the radio installed.
HBM 2016 2SS A8 NPP
Old 04-14-2018, 08:57 AM   #167
cwoodard91
Drives: 2016 2SS
Hey this fix does work. Hasn’t failed on me one time since I’ve unlocked the car before doing the remote start. Thanks
Old 04-14-2018, 08:59 AM   #168
cwoodard91
Drives: 2016 2SS
No need to get a new radio as i think its the software itself that’s bugged. Do the double unlock then lock then remote start. Or do double unlock before you get in the car. Issues will be gone.
