Old 11-07-2016, 11:21 AM   #155
tecboy
tecboy's Avatar
hers are the x4 pin outs....
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 11-07-2016, 11:22 AM   #156
tecboy
tecboy's Avatar
connector pic..
Old 11-07-2016, 12:53 PM   #157
ctrlz
Originally Posted by tecboy View Post
here are the x4 pin outs....
Thank you. So we definitely need a MOST decoder to get a full range audio signal to work with.
Does anyone know if there is a standard for encoding this type of data stream?
Old 11-07-2016, 03:58 PM   #158
Snoman
H-Town Camaro Club
Snoman's Avatar
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP
False
Two complete instructionals have already been posted and well documented.
Full Stereo Upgrade Build on 2SS with Bose
Guide on how to add a sub to a 1SS nonBOSE system
Snoman is offline   Reply With Quote
Old 11-07-2016, 04:32 PM   #159
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Originally Posted by Snoman View Post
False
That's output from the amp. Take a look at Tecboy's diagrams. It definitely has MOST data into the amp.
Using output from the amp means you are subject to it's output which is not full frequency. It can be used but will not be a clean signal. People wanting an "unmolested" signal need something to decode the MOST input from everything I've seen.
Old 11-07-2016, 06:22 PM   #160
Snoman
H-Town Camaro Club
Snoman's Avatar
Apologies. I was informed wrong and you are correct. The new 6th gen is using MOST. You'll need to find a DSP that accepts MOST or can simply pull the signal off the output side of the stock amp. There is however, an insignificant difference in doing so therefore, it's pretty much the only place to get a signal from at this time. Basically, it is clean enough and you aren't going to notice a difference.
Old 11-07-2016, 06:22 PM   #161
tecboy
tecboy's Avatar
if you want to get rid of the bose amp..then yes...you will need to find a company that makes a MOST adapter....i have not found any yet...the other way mentioned above...is taking the speaker outputs of the amp....to power aftermarket amp solution...you need to use some sort of sound processor that takes all the channels...and sums them up...then offers rca output to connect to an amp...what i understand is that each set of speaker outputs of the bose amp...are eq'ed ...so you need to sum all the outputs to get a full range signal...
everyone who has started a thread adding amps and speakers to the bose system...stop short of posting final results for some reason...
Old 11-07-2016, 07:01 PM   #162
ctrlz
I currently drive a saab 93 with 3 amps linked by optical MOST. Back in 2003 over at saabcentral we worked out a frequency map for the speaker outputs. You need some software and an oscilloscope for that. The solution for that car was pretty simple: 1) replace the stock speakers for mids and highs. 2) Amp the subwoofer output (stock was 6x9's) to a new 12" sub in the trunk. The only weak amp was the subwoofer amp.
This Bose amp needs to be mapped. Amar Bose is known for boosting and cutting certain frequencies to compensate for differences in audio perception. It's the core Bose philosophy, and many people love their stuff without realizing any of the tech behind it. But where other manufacturers strive for "flat audio reproduction," Bose does not.
Old 02-28-2017, 05:54 PM   #163
GroovyJesus
Drives: 2004 Lexus RX330 (Getting a Camaro)
Originally Posted by chris227 View Post
Just wanted to post some pics of the trunk area opposite the battery. quite a bit of space behind the carpet wall. I have a 2LT Auto, RS, Bose 9 speaker system. added a pic of the bottom of the Bose amp.
Would it be possible to install a low-profile sub in there? I would love to have some extra base, but I don't want to lose all of my trunk space doing it.
GroovyJesus is offline   Reply With Quote
Old 02-28-2017, 06:28 PM   #164
chris227
chris227's Avatar
don't need a low profile sub, a standard sub will fit in there just fine.
Old 03-01-2017, 11:45 AM   #165
Snoman
H-Town Camaro Club
Snoman's Avatar
...This Bose amp needs to be mapped. Amar Bose is known for boosting and cutting certain frequencies to compensate for differences in audio perception. It's the core Bose philosophy, and many people love their stuff without realizing any of the tech behind it. But where other manufacturers strive for "flat audio reproduction," Bose does not.
There is nothing "Bose" in the 6th gen behind the paid advertising sticker found inside the vehicle. The speakers are $5 paper cones out of china and the amp is some misassembled jumble of circuits that produces something barely qualifying to be called sound.
Don't misunderstand me, technology has come a long way in a decade or two and the threshold of "quality sound" compared to the human ear has plummeted to levels any amateur hack with some materials can replicate in his garage. But there is absolutely nothing "Bose" in the vehicle as any nominal person would conceive as being Bose as it relates to their $500-$5,000 speaker technology.
Want to talk about the epitome of false advertising and oxymoron? Car Audio as described by a Car Manufacture
Old 03-01-2017, 11:47 AM   #166
Snoman
H-Town Camaro Club
Snoman's Avatar
The "trunk space" as you understand it is false. GM introduced false panels to make the trunk appear square, there are miles and miles of cubic feet behind those trunk panels. Remove the panels and your trunk would damn near double, easily.
Old 03-01-2017, 05:47 PM   #167
GroovyJesus
My problem is that I don't want it to look like a DIY job. I like my mods to look as stock as possible. I would put it behind the seats, but I don't want to lose some of my trunk space (this will be my dd, so I need it to have some practicality). Has anyone put a sub opposite the battery, and if so, could someone post pictures and describe their process? Thanks!
Old 03-01-2017, 09:22 PM   #168
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I am waiting for the same thing you are.
1) Some way to intercept the signal before it goes to the amp. I happen to like my noise cancellation and I would like to keep it. All I want to do is get a subwoofer channel before it goes into the amp and leave the rest alone. I like my NPP exhaust, and I like the way there is ZERO drone. I am not ready to give that up to get more bass.
2) Someone to build a driver's side sub box. I am shocked nobody is selling one yet. They are staples on 4th and 5th gens. Just a matter of time for this one. Definitely the easy one of the two, and nobody even has it yet.
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
