Old 05-25-2016, 09:30 AM   #155
big hammer
Drives: 2002 ws6
Yeah basically everything is a bolt on except aftermarket cam, heads or ported stock heads. Or anything FI and nitrous
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
big hammer is offline   Reply With Quote
Old 05-25-2016, 10:49 AM   #156
SpeedIsLife
Drives: Current Camaro-less
Converters are never bolt-on mods.
Bolt On:
CAI
Intake Manifold
Throttle Body
Exhaust (headers, etc)
A converter requires you to drop the transmission, and everything involved with it. It's the same as when people don't consider heads and cams to be bolt-on's.
Old 05-25-2016, 01:24 PM   #157
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Bolt On:
CAI
Intake Manifold
Throttle Body
Yup, agreed. How is a cam not a bolt on, but a converter is?
I've done a few converter installs, they are a pain in the ass for the DIY guy, a bolt on is meant to be a simple EASY to bolt on item like a CAI or intake...
Old 05-25-2016, 04:39 PM   #158
big hammer
Drives: 2002 ws6
A "bolt on" car has always been a loose term meaning stock cam and heads basically. And yes a converter is considered a bolt on.
Old 05-25-2016, 08:11 PM   #159
ULTRAZLS1
ULTRAZLS1's Avatar
I don't really agree....but converters are in fact considered bolt ons. At least on most every fast list/forum ive been on over the past 10-15 years.
11.6 with full bolt on, e85 and converter? lol...more like high tens...and not a stripped tin can. Of course with good DA. Someone will probably get an 11.6 stock with a drag pack...we are already at 11.7.
Old 05-26-2016, 06:32 AM   #160
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
When my previous Mustang was on the S197 fast list they had a better breakdown, but much more cars.
My car had a converter and was not on the "bolt on" list as that was reserved for true bolt ons...they had a separate category between that and "power adders". Forgot what it was called, something like "extensive bolt ons"...
Old 05-26-2016, 07:37 AM   #161
jdasnt3
jdasnt3's Avatar
Drives: 18 Silverado 1500
So what will the official ruling for torque converters be on this forum's fast list? Bolt on?
Old 05-26-2016, 08:01 AM   #162
Snowblind
Snowblind's Avatar
I believe GTKLRSS posted this 11.54 slip on Facebook some time ago, if it's the same slip then he claimed this pass was with a nitrous tune in it (did not use it obviously)and that would make sense.
******As owners will quickly discover, 2016 Camaro's are very fast cars that require driver skill and experience to coax out all of the performance potential built-in by the engineering and production arms.
The Fast List will have numerous sub-lists, as submissions warrant:
Bone-Stock on Stock Tires. This means completely stock with no performance changes whatsoever; must have stock tires, stock exhaust, stock airpath, stock “untuned” computer (ECU/PCM), etc.
Bolt-Ons without Internal Engine Modification (e.g. modified airpath, headers, PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires)
Internal Engine Mods plus Bolt-Ons (e.g. stock displacement with bolt-ons plus heads and/or cam)
Power Adders (Nitrous, Turbo, Supercharger) *****
I agree that the torque converter is in the "gray area" of bolt-ons but the rules for posting times clearly state that an aftermarket clutch for the M6 is NOT an internal engine mod so that should resolve the issue right there.
Old 05-26-2016, 08:19 AM   #163
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
In my opinion, category 4. "Bolt ons with internal mods" is where a converter car should be.
Old 05-26-2016, 08:22 AM   #164
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
A clutch is a wear item, a converter is not. IMO they are not the same thing. Unless your clutch is slipping a new clutch won't improve ET, an aftermarket, higher stall converter will...
Old 05-26-2016, 08:46 AM   #165
SpeedIsLife
+1
A converter would be a "Bolt on with internal mods" category.
A bolt on is anything you can easily add or remove without disassembling a portion of the drivetrain.
LT's, exhaust, CAI, TB, intake manifold, UDP=Bolt On
Converter, DS, transbrake, cam, heads=Internal Mods
That's what I would consider fair.
Old 05-26-2016, 08:59 AM   #166
R3DLT1
Toyota Tech
R3DLT1's Avatar
Drives: 2SS A8
AGREE!
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114
Sold 2013 Chevy Crzue LTX
R3DLT1 is offline   Reply With Quote
Old 05-26-2016, 10:00 AM   #167
jdasnt3
jdasnt3's Avatar
+1
I agree with this.
Old 05-27-2016, 09:14 AM   #168
Gtkilrss
Gtkilrss's Avatar
Drives: 2016 SS
Originally Posted by KyleL View Post
What brand converter are you running? Last I heard, yank was still developing one for the 8 speeds, but that was about 6 weeks ago
Circle D. This was a test converter but I'm
Almost positive same converter is on the market. It's a 3000
Gtkilrss is offline   Reply With Quote
