Old 08-13-2017, 02:20 AM   #16591
Andrew4180
Bigfoot
Andrew4180's Avatar
Drives: "Doomsday" 1981 Camaro
Well, since i just kinda pop in and out. Heres a small update. Got the camaro ready, raced once at my local track. Did good, 3 consistent passes and the only issue was header bolts coming loose, which is normal.
Drug it 275 miles to a track near the Iowa border, made 4 great passes, going rounds in my class. Then when i made my 5th pass of the day it went good til i let off the throttle at the end of the track, it sounded like spoons in a blender.
Zero oil pressure, and could barely get the car out of gear. Looked under the car to discover a broken transmission bellhousing. Number 6 since i owned the car. I brought it home and tore it apart to inspect the damage, the brand new transmission i had just had built to the tune of $1100 is now trash, luckily i got the motor shut down in time and only have to do new bearings and a cam.
The bad news is, after 6 years, 2 motors, and 7 transmissions, enough was enough. I sold my beloved hot rod and first car. So I no longer own a camaro and have picked up another project drag car. One of these days id like to get ahold of another camaro as just a driver though.
Owner/Driver: AMT Racing's Doomsday 1981 Camaro
383ci SBC, Th400 Trans, 29X10 Hoosiers. Small Block, Small tire, bracket car.
Andrew4180 is offline   Reply With Quote
Old 08-14-2017, 07:49 AM   #16592
Nvincent4708
Drives: N/A
Originally Posted by CamaroDreams76 View Post
505-520hp/500-510tq
Guy nearby with a similar combo ran out of fuel at 5000.. 546hp
However, who knows what it'll do. I'm curious to see!
Nvincent4708 is offline   Reply With Quote
Old 08-16-2017, 03:43 PM   #16593
Nvincent4708
Drives: N/A
So the car made 570 max. But the final safe tune is 560.
Old 08-16-2017, 04:34 PM   #16594
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
I need that
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 08-16-2017, 06:02 PM   #16595
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Well I was a little low
CamaroDreams76 is offline   Reply With Quote
Old 08-17-2017, 07:21 AM   #16596
Nvincent4708
Drives: N/A
Originally Posted by rebelyell22 View Post
I need that
It's officially stupid fun to drive!
Ended up being 10PSI.
Oh and.. clutch is next.. Slips in 4th on hard pulls lol.
Old 08-18-2017, 07:56 AM   #16597
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
2.75"
So overall build..
LS9 Cam / PAC 1218 Springs / ZZP Trunions
1-7/8 Long Tubes / No Cats / NPP Exhaust
DW 65LB Injectors
ZL1 Fuel Pump - Tuned FSCM
2.75" Pulley
Dual Row Heat Exchanger / Bosch pump / ADM Reservoir
Should be 9PSI
Interesting choices for the build. Glad to see it made decent power.
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 08-18-2017, 09:23 AM   #16598
Nvincent4708
Drives: N/A
I don't think I'm done. A bigger cam is probably in order soon. I need to hit that 600+ mark. Well, after a clutch, wheels and coilovers of course.
Old 08-18-2017, 09:58 AM   #16599
GoldCartridgeGamer
What cam are you thinking next? BTR? GP Tuning?
Phoenix (sold)
Old 08-18-2017, 10:17 AM   #16600
Nvincent4708
Drives: N/A
Probably something custom grind to work with AI heads (I'll get mine redone)
Old 08-22-2017, 08:45 AM   #16601
TooManyProjects
Drives: 2012 Camaro 2ss
Took girlfriend to track to WATCH.
Apparently my 350z now belongs to her, and shes already looking at putting the turbo kit I've had sitting around on it.
....shit
TooManyProjects is offline   Reply With Quote
Old 08-22-2017, 02:36 PM   #16602
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
....shit
Rookie mistake. Those mistakes will cost you a lot of money.
hrpiii is offline   Reply With Quote
Old 08-22-2017, 06:13 PM   #16603
rebelyell22
How much would you want for the LS9 cam?
Old 08-23-2017, 07:17 AM   #16604
Nvincent4708
Drives: N/A
$40 when I go that way. I only paid $85 new.
i can haz a tag?
