Old 06-21-2025, 05:46 PM   #16549
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Hell I’ve seen cars that have the factory suitcase but are missing the two support beams that attach from the rear crash bar to the inside of the lower diffuser. Diffuser goes flapping on the highway
2016 1LT v6
- Totaled
Happiness: Infinite
Old 06-21-2025, 09:02 PM   #16550
p47dman
Drives: 2024 Camaro 1SS
Installed Borla axle back on a friends 2016 SS Vert.
p47dman is offline   Reply With Quote
Old 06-21-2025, 09:53 PM   #16551
d50h
d50h's Avatar
Drives: 2023 Radiant Red 2SS m6
Originally Posted by PowerDemon View Post
Which sound profile did you go for? Sound clips? Are you happy with it?
S tube, very mild, I'm happy, no drone
I don't know how to add a sound clip
d50h is offline   Reply With Quote
Old 06-23-2025, 06:38 AM   #16552
clg82
Drives: 2020 Camaro ZL1
I’ve been running the AWE Touring catback since 2019… if there’s a parachute effect it doesn’t seem to be working on my car lol
Originally Posted by Booher View Post
There is absolutely a parachute effect, and it effects other cars too. The backing plate is a fantastic idea I've been wanting to for for years! Its not enough to effect me, but for racers its a big deal. Alot of people would cut their diffuser to help eliminate it.
Oh stop. There are plenty of "racers" on this forum that don't worry about that "parachute effect".
Old 06-23-2025, 07:56 AM   #16553
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune l GM Lowering Kit
Ported LT2 Intake Manifold l Ported 95mm LT5 TB l BMR Rear Cradle Lockout Kit
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l 480whp/467wtq
SSShark is offline   Reply With Quote
Old 06-25-2025, 01:53 PM   #16554
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Smile CA smog check
I hope this may help someone else.
Earlier this week I finally got my car ready and it passed its first smog check.
The battery had been replaced a few months ago and recently I replaced a defective harness inside the transmission (temp sensor error).
Apparently I had not put enough of the "right" drive cycles on it since then to set 6 of the monitors.
I have a factory service manual for it (2017 MY) and located the required "drive cycle".
It was about as clear as mud on a moonless night and reads something like standing on your head in a dark corner while chanting "la la la" and rubbing your stomach anti-clockwise.
This was clearly written for someone with free access to a test track or a roller treadmill rack, and not for real people in real world traffic on real roadways.
After researching what others had made of it, I distilled it down to the attached "FSM IM readiness drive cycle".
After running through the whole procedure twice, repeating steps 7-14 as noted once, 4 of the 6 monitors completed.
The O2 sensor diagnostic and EVAP diagnostic remained incomplete, as is a very common complaint on this forum.
For them I did the attached procedure "GM O2 and EVAP", which had been posted by someone else on this forum a while back.
The O2 diagnostic completed on the first try.
However, even after repeating it the EVAP would not complete.
So then I tried again using the noted "alternative second part" in the attachment (no stop and go traffic).
For that I only warmed the car up from cold just enough to stabilize the engine.
I then drove it at moderate speeds (30-45mph) to reach the highway which took care of the first step.
The gas tank was about half full, by the way.
Then I drove approximately 15 miles at highway speeds with a couple of 5-10 second no-gas-pedal coasts.
I turned around at the next available exit without shutting it off and drove back home with a couple more coasts in the process.
I then let it idle for 4 minutes before shutting it off.
The highway coasts were not down to "less than 20mph" by the way, as some procedures dictate.
Around here that would have caused an accident for sure.
Just- foot off the pedal completely, no brakes for at least 2 seconds (per the procedure).
A few hours later I checked and the EVAP monitor had finally completed..!
Obviously I can only tell you what worked for my particular car.
But hopefully it will help someone else.
Oh, and no matter what the DMV/BAR website says, you have to have ALL monitors complete to pass smog testing around here (I asked).
FWIW...
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 06-25-2025, 02:29 PM   #16555
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
California is a mess
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 06-25-2025, 02:50 PM   #16556
flobb
Drives: 2022 2SS
The drive cycle process is a mess. I had to do it last year in Missouri. My battery drained too low and reset the system. Having driven the car normally for a few hundred miles before inspection time apparently did nothing. I had to spend two weeks dorking around trying to get the drive cycle procedure to work.
flobb is offline   Reply With Quote
Old 06-25-2025, 04:30 PM   #16557
DIYguy
DIYguy's Avatar
Yes, that is more or less what was happening to me as well.
Even with the "simplified" drive cycle I posted it didn't solve everything.
For this reason I kept searching and eventually found the O2/EVAP-specific procedure.
That one actually made a lot more sense to me, and in the end it worked.
Thankfully...
And yes, California is a gigantic mess.
Old 06-25-2025, 05:51 PM   #16558
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
Paid off the Camaro loan a year and a half early.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 06-25-2025, 10:11 PM   #16559
Congratulations, now she's all yours
Old 06-26-2025, 05:20 PM   #16560
RiverSSide
RiverSSide's Avatar
Drives: 2021 Camaro 2SS Convertible
Nice!
Can't wait to pay mine off soon.
2021 2SS Convertible, Riverside Blue, A10, NPP, MRC, Forged Wheels, emblem package.
RiverSSide is offline   Reply With Quote
Old 06-26-2025, 09:50 PM   #16561
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
Finally changed out my upper seat skin.
I will chase intermittent shorts and dead can bus problems all day and never complain, i absolutely hate doing interior work.
Old 06-27-2025, 10:09 AM   #16562
sklippi2018
Drives: 2021 ZL1 A10
Way to go! Woohoo!
sklippi2018 is offline   Reply With Quote
