Old 04-17-2013, 03:57 PM   #1639
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
That makes a lot of sense, I hardly ever go into parking garages but when I have, I've always dreaded the exit when really steep
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 04-17-2013, 03:58 PM   #1640
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I scrape my cats all the time on speed bumps or driveways. Never really catch the front though
Sent from my Galaxy Nexus using Tapatalk 2
[B]
CamaroDreams07 is offline   Reply With Quote
Old 04-17-2013, 03:59 PM   #1641
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Yup me too.
Just an update on the R1 concepts rotors and HAWK HPS pads.
I went to my first autocross event last weekend (I'm now hooked) and was hard on my brakes. I made seven (7) runs back to back with about 10 minutes in between each run. The course was pretty technical, lots of S-turns and turns that were hard on the brakes. I had zero brake fade and the initial bite was great. For the money I cannot complain at all and would recommend this set up to anyone.
As a side note I only had my R1 concepts and HAWK pads on the front of my car. As fate would have it as soon as I ordered my entire rotor/pad set up I was able to snag a deal for Brembo rear brakes. So if anyone is interested in buying R1 concept rotors and HAWK HPS pads I have the rear set up for the V6. PM me if you're interested.
Here's a video of three of my runs (worst to best):
BaylorCamaro is offline   Reply With Quote
Old 04-17-2013, 04:01 PM   #1642
lscamaro
lscamaro's Avatar
Yea me too, I scrape on speed bumps. I don't scrape the front either but I guess that's because of how it's angled at the bottom. There's been scenarios where I can clearly see that the angle at the bottom has saved me from completely obliterating the front fascia.
Old 04-17-2013, 05:41 PM   #1643
KMPrenger
KMPrenger's Avatar
Backtracking a bit...
The ZL1...yes its not as much the 1/4 mile monster as everyone hoped, but you guys have to remember that when all the stars are aligned, it can run pretty damn fast, as there have been two drivers that got her just under 12 seconds. In perfect weather and all that stuff a stock V6 Camaro could maybe squeak out a 13.9 or 14 flat one day, but we all know most of the time V6ers run low to mid 14s while most of the time the ZL1s are in the mid to upper 12s.
The ZL1 is just heavy, hard to launch well, and suffers badly from heat soak. I'm not really defending the ZL1 either, just saying. Can't use that 13.3 as an comparible run.
Old 04-17-2013, 06:33 PM   #1644
SixCyl
SixCyl's Avatar
Drives: 2010 Camaro CGM V6
Originally Posted by PoorMansCamaro View Post
I don't want to jack that other guys thread anymore, so i'll take the convo over here
18" tsw
Looks great! I legitimately regret getting 20" wheels.
El gato. Mods: Eagle eye headlights, 18" Axis Sport graphite, Roto-Fab cold air intake, Vmax ported TB, 3/8" Vmax Black-Ice, RX single valve catch can, RX breather, Pedders inserts, Trifecta tune, BBK LTH 304 SS.
art/ärt/Noun. Definition: 5th generation Camaro.
SixCyl is offline   Reply With Quote
Old 04-17-2013, 06:34 PM   #1645
lscamaro
lscamaro's Avatar
Why?
Old 04-17-2013, 06:35 PM   #1646
SixCyl
SixCyl's Avatar
This is the reason I dread lowering my car. How much of a drop do you have? 1.25"?
Old 04-17-2013, 06:36 PM   #1647
SixCyl
SixCyl's Avatar
Why?
Well aside from the corrosion (which I believe I've mentioned before) if I had my stock LT wheels it'd be a weight difference of like 40 pounds, or 160-240 lbs of rotational mass. That said, I can still spin these wheels out just fine
Old 04-17-2013, 06:52 PM   #1648
lscamaro
lscamaro's Avatar
I have a 1.3" drop in the front and a 1" drop in the rear. Even with all that said, I would do it all over again for sure! It's by far the greatest cosmetic mod I've done to the car. Without a doubt!
Old 04-17-2013, 06:53 PM   #1649
lscamaro
lscamaro's Avatar
Why didn't you go with some lighter 20" wheels? I plan on 20s as my "show" set but they will for sure be lightweight in case I get lazy and don't want to swap them to race
Old 04-17-2013, 07:35 PM   #1650
SixCyl
SixCyl's Avatar
They are "light," long story short I got screwed and the manufacturer wouldn't take them back.
They are something like 32 lbs for the fronts and 36 for the rears.
I think my guy here has a set of the 1 LT wheel and tires lying around. Once I finish the semester I'll see if he'll just do an even trade. And once I wear out those tires it should be time for a new set of brakes and some 275 wheels
Otherwise I'd get some DR-37's in 18"
Old 04-17-2013, 07:38 PM   #1651
lscamaro
lscamaro's Avatar
The 1LT wheels will make a difference. Especially if you have such heavy tires. You'll feel the difference as soon as you put them on.
That is one thing I want. I want some bigger tires in the rear. Badly
Old 04-17-2013, 07:46 PM   #1652
SixCyl
SixCyl's Avatar
Oh I know, this is why I'm ok with no other mods for a while, the change in weight ought to make a big difference. I want a bigger perma grin! Haha
