#16283 | |
![]() ![]() Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
#16284 |
Done.
#16285 |
![]() ![]() ![]() ![]() Drives: 2017 Camaro 2LT RS 3.6L Join Date: Mar 2016
Finally able to drive it! Beautiful 82 degrees here. Need to work on my photography skills.
2017 2LT RS 3.6L A8.
#16286 |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit |
#16287 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#16288 | |
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
#16289 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Finally got rid of the damn 'swim goggles'.
I absolutely hated them. Auto Addict's C8 clones, and the best part is the white LED reverse is at least 50% brighter than the stock ones. Now I hope they last... considering picking up a spare set.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#16290 |
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
Had the BCM Recall done....
Slightly dumb question - for the 45k mile service, GM Recommends the following: 1. Manual Transmission Fluid swap 2. Rear Axle Fluid Swap (Differential fluid swap?) Are these things I could/should easily just go to my local mechanic and have done or is it worth heading to the dealership for any weird GM/Camaro quirks? They quoted me about $500 for items 1+2 above. I am new to not having a 20yr old car and not having access to a driveway or a lift anymore. Secondary: what are the specific fluids? Manual says 'see dealer', which is wildly unhelpful.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
#16291 | |
#16292 | |
I don't have the facilities or tools to do it myself anymore, well I have the tools but not the facilities, DC life. My question was more independent mechanic or dealership, I guess they are roughly the same.
#16293 | |
Having a spare set is wise, electrical aftermarket parts are riskier. I have a spare LED side market kit, too, even though it looks like I hit the jackpot with the ones I've had working flawlessly since late 2018.
#16294 |
#16295 |
JW Motorsports, they seem to have gone defunct since then. My spare kit is from Diode Dynamics.
#16296 |
LOL, I have never heard them called swim goggles before, now I won't be able to unsee nor unhear that comparison!
I have really wanted a set of the Auto Addict lights, but for some reason I haven't pulled the trigger on them yet. Probably because I'm not looking forward to removing the rear bumper to install them.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
