Old 10-22-2018, 05:16 PM   #1597
Racereadyfab
Drives: 2017 Camaro 2SS
Not going to make this list but ran out of time this night. Going back this week with a set of 26s to try and get out of the hole a little quicker and knock some rotating weight off. These 28s are on a c6 rep and weigh in at 60lbs each hoping the new setup will be about 50lbs mounted on race stars. This is also with me tuning it which is a learning curve and probably some left in it, the pass after this was 118.60mph when I gave it some more timing with a high 1.9 60'. Keep in mind this is a M6 car just wanting to be as fast as a A8
Tires used on the pass: 28" Mickey street S/S
Performance Mods (if any):long tube headers no cats, roto fab intake and my tuning
Category submitted for: Please List the Category or Category #3
R/T .364
60' 1.840
330' 5.075
660' 7.729
660’ 92.92mph
1000' 9.997
1320' 11.927
1320’ 117.43mph
Name of the track: New england dragway
Date of pass: 10/19/18
Weather conditions: Include Density Altitude if known. (Optional not required)
2017 Camaro 2SS M6 100% stock at the moment
1.839 60' 12.113@114.95MPH 6/9/17
12.267@115MPH 5/17/17
12.374@116.83MPH 5/10/17
Racereadyfab is offline   Reply With Quote
Old 10-22-2018, 06:08 PM   #1598
FastCarFanBoy
Drives: 2013 GB GT
Congrats 1ss and others.
FastCarFanBoy is offline   Reply With Quote
Old 10-22-2018, 07:00 PM   #1599
laynlo15
Drives: 2022 Lt1 A10
Nice pass raceready
Old 10-22-2018, 07:20 PM   #1600
parish8
Drives: 17 SS a8
First trip to the 1/4 didn’t go so well. Boost controller crapped out and I “broke” an aftermarket axle as soon I tried to hit it harder off the line. This was my best run at just 9psi and a soft launch.
Tires used on the pass: mt dr's
Performance Mods (if any): turbos, drop in rods and pistons, port injection, converter
Category submitted for: Please List the Category or Category # stock displacement power adder
R/T.......... .568
60'............. 1.59
330'........... 4.19
660'........... 6.35
660’ mph... 113
1000'.......... 8.24
1320'.......... 9.83
1320’ mph… 141.49
Name of the track: Kearney dragway
Date of pass: 10/14/2018
Old 10-22-2018, 07:45 PM   #1601
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Tis' the season... some nice runs coming in
driven2exceSS is offline   Reply With Quote
Old 10-22-2018, 08:45 PM   #1602
smokinzx14r
smokinzx14r's Avatar
Drives: 2018 1SS
anyone going to update the list ?
smokinzx14r is offline   Reply With Quote
Old 10-22-2018, 10:46 PM   #1603
Racereadyfab
Realized I never posted this time from back in July before doing exhaust and tune tried the 100hp jets stock tune to see what it would do. Once I get comfortable with my current tune and setup I’ll spray it again, this should get me on the power adder list at least.
Performance Mods (if any): nitrous express plate kit w/100hp jets and plugs otherwise stock intake,exhaust,stock tune, drag radials
Category submitted for: Please List the Category or Category #5
R/T .200
60' 1.757
330' 4.839
660' 7.420
660’ 96.55mph
1000' 9.620
1320' 11.470
1320’ 122.19mph
Date of pass: 7/18/18
Old 10-23-2018, 06:18 AM   #1604
laynlo15
Merc will update it when he gets a chance. He takes care of other lists beside just that Camaro.
Old 10-23-2018, 08:35 AM   #1605
Korosion
Korosion's Avatar
Drives: 2016 2SS
Originally Posted by wnta1ss View Post
Firestone Indy 500 tires do not fit the Bone Stock Category. Check the rules on the first page of this thread, and you'll see that the correct category for your entry is #3. Lighter/stickier tires, and lighter wheels, are performance changes for sure.
How is that a performance upgrade?? Also, this was done on my stock 20in wheels. My Apex Wheels are for the track not drag.
Korosion is offline   Reply With Quote
Old 10-23-2018, 09:00 AM   #1606
6spdhyperblue
Drives: 2SS 1LE
You need to use factory oem replacement spec rubber or anything for that matter for a stock time to count(Delco airfilter etc). That’s where they drew the line, it’s a slippery slope and it’s gotta be somewhere.
Old 10-23-2018, 11:59 AM   #1607
Korosion
Korosion's Avatar
Drives: 2016 2SS
That's a dumb line to have considering you can change to a worse tire than the stock ones and still be considered "performance mods"
Old 10-24-2018, 12:52 PM   #1608
CryptonZL1
Drives: 2017 zl1 Camaro with Nickey stage 1
Hello Guys. I have had my A10 Crypton Green ZL1 for a while now and recently had the guys @ NicKey Performance in Saint Charles, Illinois, install their Stage I kit. Drove it to our local track / US 41 and here are my best run(s) results.
Tires used on the pass: Stock Front / M/T 305 Drag Radials
Performance Mods : Nickey Stage I option. Lower Pulley, Ported Snout, 103mm TB, RF-CAI, Nickey Headers and -Xpipe. Tune
Category submitted for: Please List the Category or Category #8
R/T...........0.0605
60'.............1.57
330'...........4.49
660'...........6.89
660’ mph...102.56
1000'..........
1320'..........10.687
1320’ mph…130.97
Name of the track:US 41 in Morocco, IN
Date of pass:10/21/18
Weather conditions: Include Density Altitude if known. 50 degrees
CryptonZL1 is offline   Reply With Quote
Old 10-24-2018, 02:56 PM   #1609
Redlinez
Shifts under load
Redlinez's Avatar
So, I've been twice in a year and a half in this car. When I tried to get the revs up before getting out of the hole, the car would roll forward. I'm gonna try over inflating the front tires next time. I forgot it has launch control, but I don't think that holds it still. I had to leave at idle, so next to no spinning. Stock car on Michelin Pilot 4S's. Full interior, 1/8 tank, 6 speed manual 1SS NPP. I weight 198.
Category 1- bone stock manual trans
I gotta go back and get more seat time and try launch control just to see. 6 speed manual. I did all of them in sport mode with competition mode engaged. Hopefully I did respectable.
Fayetteville NC Fayetteville Motorsports Dragstrip 10/21/18 62 degrees
22 Suzuki GSX-S 1000GT blue
Old 10-27-2018, 05:00 AM   #1610
wnta1ss
Drives: 2017 Camaro 1SS
Update for my SS with bolt-ons category #3. Still has cai, 95tb, intake manifold, e85 tune, driveshaft loop, smaller battery, drag pack with radials. Still has completely stock exhaust system. Removed the passenger and rear seats.
Tires used on the pass: MT ET Street S/S 275/40-17 rear, MT Sportsman SR 26x6x17 front
Performance Mods (if any): DRs and Skinnies, CAI, 95TB, IM, E85 tune, W/R
Category submitted for: (3) Camaro SS 2016+ Bolt-Ons NO Internal Mods (Stock Displacement)
R/T.............. .124
60'............. 1.590
330'........... 4.550
660'........... 6.983
660’ mph... 102.49
1000'.......... 9.094
1320'.......... 10.888
1320’ mph….125.46
Name of the track: New England Dragway
Date of pass: October 26, 2018
Timeslip below, right lane
