#15499 | |
![]() Drives: White 2024 1SS M6 Join Date: Nov 2023
Did you put the 275's on 10" rims ? If so, do they look as they should, or do they look a bit stretched ? |
#15500 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
I was wondering the same thing. Why not stick with the 285s.
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
#15501 | |
Because this is a non-1LE SS and the 1LE / ZL1 sizes you're implicitly alluding to (285/30/20 and 305/30/20) are very different from my stock settings. I used to have 285/35/20s in the front, but the driver side was rubbing a bit at full left lock (there is some metal bracing directly behind the liner, and I was afraid it'd wear through to the metal). In general I'd like to stay as close to the OEM front:rear ratio as possible. Here are some pics, apologies for the dirty wheels/tires and the messy garage, but next week the car is finally going to Finishing Touch in Maryville for an exterior makeover (I figured it was due after 6 years )
#15502 |
That doesn't look bad at all. I want to go with the same size tires when it's time, but was really not sure about the look of a 275 on a 10" rim. I can't find a 9.5" rim in something I like, which I think is the perfect size for a 275. I've also considered going with a 9" front with 275's, and a 10.5" rear with 315's so the tire stretch would look about the same in the front and rear. I've also really grown to like my factory silver SS rims, and have thought about just going with a square 285 set-up with my factory 9.5" rears, and getting another 9.5" set for the front, adding a 15mm spacer in the front for proper clearance and poke.
#15503 | |
I can see the allure of a square setup, but I wouldn't do 15mm spacers, my wheel calculator shows you will have significant front poke with the stock (rear) wheels, because 285/35/20 tires will stick out 21mm more than the stock fronts, see here (I subtracted 15 mm from the stock offset to accommodate your theoretical spacer).
#15504 |
I used this site and came up with about 13mm more poke, did I calculate something wrong ?
https://www.willtheyfit.com/index.ph...9.5&offset2=24 |
#15505 | |
#15506 | |
I would like to go to 315s in the rear of ZL1 when I replace the tires.
#15507 | |
Gotcha, thank you. I knew I had to be overlooking something. It would still be less overall poke than a 10" MRR/1LE with a 285 though ? |
#15508 |
Yes. The difference is 3mm, not much but visible.
#15509 | |
2020 Shadow Gray 2SS
Those tire sizes are what I would like to go to next time I need tires but don't want any rubbing...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#15510 | |
The only reason I see for the rubbing is that metal bracket I mentioned above that pushes in the driver side liner a tiny bit (we are talking an eighth of an inch or so here). Your car is newer and may not even have the exact same clearance issue. These are OEM 1LE wheels. Note that I can only warrant for no rubbing with these specific PS4S tires, others may be slightly taller/wider even at the exact same nominal 275/35/20 size.
#15511 |
Do you want to leave the fronts at 285 or move up to 295?
#15512 | |
Honestly, I'll probably go with the Atturo AZ850's again, I never drive in the rain, they balanced great and they hook nice, and you simply can't beat the cost... So I can have fun burning them up without much guilt!
