Old 08-22-2016, 12:17 PM   #15457
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Originally Posted by Tricksta View Post
really!? Weird
5.1 for a home theater is awesome. 5.1 for car audio sucks.
hrpiii is offline   Reply With Quote
Old 08-22-2016, 12:19 PM   #15458
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
What about 7.1.
I'm really considering at the very least just changing out the amplifier. Everything I read says it's the weakest point and you won't regret it.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 08-22-2016, 12:21 PM   #15459
Tricksta
Tricksta's Avatar
Does the FARK harness eliminate the center speaker for me, or will I need to get into the dash and disconnect it myself?
Modifications
Old 08-22-2016, 01:02 PM   #15460
hrpiii
AKA "Beefcake"
hrpiii's Avatar
What about 7.1.
That is very very very true!!! The amp makes a hell of a difference.
you don't need to disconnect it. when you replace the amp, nothing will be driving it anymore. I am trying to remember how that is all hooked up now. May want to go back and read on that a little, it's been 4 years since I replaced it, and I had help.
Old 08-22-2016, 01:12 PM   #15461
Tricksta
Tricksta's Avatar
Sub thump had a short instructional help video on how to install the harness I'll use.
Modifications
Old 08-22-2016, 01:17 PM   #15462
hrpiii
AKA "Beefcake"
hrpiii's Avatar
I believe the FARK harness was for hooking in a separate sub as a filter/pass for the bass.
Old 08-22-2016, 01:22 PM   #15463
xc_SS/RS
Drives: 2010 Camaro SS/RS
Just the FARK alone won't kill the center speaker. I have the FARK to add a sub to my BA system and I still have the center speaker. Gonna try and disconnect it tonight though and finally see the difference
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-22-2016, 01:23 PM   #15464
Tricksta
Tricksta's Avatar
From what I understood it was for both, if you wanted to hook in for a sub, you had to have an amplifier that also had RCA out and not just RCA in, that way you could hook to a 2nd amplifier for the subs. But I could be wrong.
Modifications
Old 08-22-2016, 01:27 PM   #15465
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
really!? Weird
a lot of people unplug it.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 08-22-2016, 01:31 PM   #15466
hrpiii
AKA "Beefcake"
hrpiii's Avatar
I think you are correct there.
Old 08-22-2016, 01:33 PM   #15467
Tricksta
Tricksta's Avatar
Did you have your trunk dyna matted at all?
Modifications
Old 08-22-2016, 01:56 PM   #15468
hrpiii
AKA "Beefcake"
hrpiii's Avatar
yes, about 80%. the main flat areas and into the battery/center hole. I did not do the sides or the trunk lid
Old 08-22-2016, 02:05 PM   #15469
Tricksta
Tricksta's Avatar
Suppose I wouldn't need to do that until I would add a sub.
Modifications
Old 08-22-2016, 02:16 PM   #15470
hrpiii
AKA "Beefcake"
hrpiii's Avatar
it also helps curb some of the road noise and exhaust into the cab. Thus improving your music/sound.
i can haz a tag?
