Old 05-29-2025, 04:47 PM   #141
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Originally Posted by DamonZ28 View Post
I looked mine up, and it still shows the status INCOMPLETE.
How did you look yours up?
2SS Capt is online now   Reply With Quote
Old 05-29-2025, 05:25 PM   #142
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
https://experience.gm.com/ownercenter/recalls
2016 1LT v6
- Totaled
Happiness: Infinite
Old 05-29-2025, 05:40 PM   #143
2SS Capt
2SS Capt's Avatar
Mine still shows incomplete as well...
Originally Posted by Bumbleboy92 View Post
Thanks!
Old 05-29-2025, 07:04 PM   #144
wang970305
Drives: 2021 Camaro 2SS
I have progressive for insurnace and they show me the status of any recalls I have on my cars
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 05-29-2025, 07:51 PM   #145
Bumbleboy92
Long hauler
Thanks!
No problem! I had my BCM enhancement done on March 11th but the website says completed March 13th.
My TCM Recall was done yesterday (28th) and still shows incomplete. Probably a few more days to update
Edit: Shows done on 5/30
2016 1LT v6
- Totaled
Happiness: Infinite
Old 05-29-2025, 10:35 PM   #146
2SS Capt
2SS Capt's Avatar
But both of mine were done nearly a month ago... BCM shows complete, TCM shows incomplete...
Old 05-30-2025, 07:38 AM   #147
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
The FAQ on the website says that it can take up to 30 days to be marked as complete.
My Camaro Journal
DamonZ28 is online now   Reply With Quote
Old 05-30-2025, 07:44 AM   #148
DamonZ28
DamonZ28's Avatar
I just noticed that it doesn't say whether the remedy is available, or unavailable. I'm pretty sure that, in the past, it has said that the remedy is unavailable. Interesting.
I also read in the FAQ that the status INCOMPLETE just means that the recall hasn't been performed yet, not that the recall availability is incomplete.
My Camaro Journal
Old 05-30-2025, 08:29 AM   #149
wang970305
On my progressive app, it does show if the Remedy is available and I have called my local dealer twice, they are basically just telling me what I see on my end. I just noticed the remedy shows available now and I called the dealer yesterday. The lady said they have done it on couple cars, and should be able to schedule my TCM software recall and I did verify they will update the TCM software with installation.
And AGREE, the Complete or Incomplete only means if the recall has been fixed.
Old 05-30-2025, 01:03 PM   #150
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by Roddrz View Post
Thank you for providing the update.
However, there are significant concerns regarding the long-term impact of the valve body design flaw.
This issue is causing gradual and potentially unnoticed damage to the transmission.
The primary concerns are:
  1. Leaky aluminium valves instead of steel
  2. Leaky paper gasket plates instead of metal
  3. Dislodged gasket screens that plug fluid channels
These problems lead to a loss of hydraulic pressure over time, which may result in extensive damage to other transmission components as stated by NextGen Drivetrain.
Given the severity of this issue, would GM have plans to address the long-term consequences by replacing damaged transmission parts caused by this design flaw?
For context, there has been a report of GM replacing both the engine and transmission in a Cadillac sedan following a wheel lock-up incident, which may be relevant to this situation.
I decided to invest in repairing the valve body for several reasons:
  1. To gain peace of mind
  2. To improve the vehicle's performance
  3. To potentially extend its longevity
While the long-term benefits of this upgrade remain to be seen, I believe it's a worthwhile investment.
This decision aligns with the principle that regular maintenance and preventative care are often necessary to preserve an asset's value and functionality.
By addressing potential issues proactively, we can often avoid more significant problems and expenses in the future.
Thank you for your continued support of the Community!!!
A couple questions, please:
  • Is this the pump you used?:
    VEVOR Water Transfer Pump, 120V AC 360 GPH 1/10 HP
    https://www.vevor.com/water-transfer...xoC_J4QAvD_BwE
  • Regarding the tranny cooler:
    Did you just obtain the fittings for the cooler connections and just add enough hose to collect the old fluid in the drain pan? If you recall - do you remember, either, the sizes or part numbers for the fittings?
I'm sorry for the continued questions, but I plan on jumping into this little project in a couple months and am collecting the remainder of what I don't have so I'll be prepared when I jump under the car.
Thanks again, VERY, much!!!
Chuck
'20 ZL1 Black "Fury"
Old 05-31-2025, 12:15 AM   #151
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
GM Confusion: GM told me specifically because of my engine modifications they cannot cover this valve body with a warranty.
Now I found this which is the extended warranty GM added for the valve body issue.
So which is it GM? And which valve body are they replacing it with? The same defective part, or Next Gen's solution?
Old 06-02-2025, 07:51 PM   #152
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
We all know the game…next week, next month or perhaps next year, the verbiage will change, based on another lawsuit. Anything from GM goes in one ear and out the other till the dust settles (at least my ears) I’m not getting their ridiculous pressure loss limp mode tune either. It’s not like they had a bad run of window regulators (that would almost would be acceptable) When GM goes they go big…trannies, lifters and camshafts(engines).It’s stunning to hear from non mechanical guys that they’re fully in loop on what’s going on and are pissed. Lasting reputational damage is going to be huge unless they do the right thing(s).
Old 06-04-2025, 10:34 AM   #153
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Mine both show as complete now:
Old 06-04-2025, 12:47 PM   #154
2SS Capt
2SS Capt's Avatar
Mine is still showing incomplete, I'll have to call the dealer...
