#141 | |
![]() Drives: 2018 Camaro ZL1 Join Date: Dec 2021
I'm also planning on running flex fuel. I have had a few people say go with the Low-side Pump, I'm really confused here. I should also note that I was planning on running Lingenfelter's lower pulley kit to run more boost... but idk maybe this can be omitted if I can't get optimal fueling. |
#142 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#143 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Looks like if I want to stay on a blend 93/ corn I will need to do cam/ 10% lower and be right around 700 tire. If I decide to go 93 I am thinking blower port, 15% lower, and 103 TB and be around 700 tire. I assume the first setup would be more consistent and run cooler. Thoughts?
#144 |
Chad, in 140+ posts, you've gotten input here from some of the most knowledgeable Camaro guys anywhere. Surely your questions have been answered above?!
2020 ZL1LE A10.
#145 |
Red Bull
Yes sir!! I have a few options from all the great input. Thanks to everyone in here! I will start ordering the parts soon and I will also post dyno results and my drag times this spring!!
#146 | |
Nonetheless I still want to run FlexFuel (E60) or full E85 if the stock fuel system can handle it... I'm pretty certain it can't though... and I'm getting mixed signals on what mods I need to achieve that with or without a pulley kit. |
#147 |
You can always run meth instead of a cam. Some people are into that... me personally I stay away from meth and any kind of standalone unit... if the units malfunction you're looking at a bad time, but I've never personally ran into people who's kits have had issues.
#148 |
Red Bull
I agree ☝ I think meth is somewhat dangerous. I want to stay on some blend E40-E60 for the smell, cooler temps, and extra HP.
#149 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I can certainly help you with flex fuel tuning I have done thousands of conversions Give me a call. 203-753-7223
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#150 | |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
#151 | |
Then if you decide to go further your fuel system is already there. Just get a cam with a 43% fuel lobe and low side if not already(cordes aux is a solid setup). Then you will be able to make big power on E.
#152 | |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
With a DSX low side, a flex fuel sensor, and no other modifications, you may be able to get away with full E85, but you would end up at less peak HP than you could be on pump gas using the same amount of fuel volume. Methanol can be a good route to go as long as you are up to date on maintaining the system. A professionally installed methanol system is not as unreliable as you think, I would just plan on replacing the pump yearly for peace of mind. |
#153 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#154 | |
Your statement on pump gas makes more power on less volume is accurate but it's not important. Upgrade the fuel system and reap the benefits of being able to maintain optimal timing even at elevated manifold temps with Ethanol. That is the problem on 93, these engines are knock prone. The stock blower on stock boost still generates enough heat that you are consistently up against the threshold of KR and timing pull from heat and not enough octane. Ethanol fuel even blended down to E40 will allow full timing even with 30+ degrees higher Manifold temps compared to Pump gas. Stock blower stock boost car is going to see MAT go into the 140's on a 70 degree day with the engine up to temp. ECU is set to pull timing with anything above 132 degrees. Switch over to Ethanol you can bump that table up to not pull timing until 155-160 degrees and the engine is still happy. No KR and the MAT likely will not hit those temps...so no timing pull ever even on a hot day. I get that some of you big shops have to think about the average customer and his/her abilities. So you spec packages out to keep it simple...but let's not pretend that E isn't superior then every way other then it can require a little more effort on the end user.
